Results 1 to 30 of 30
    Mar 27 2019
    Michigan
    Windshield Washer Nozzles Suck
    Not sure if this is all a3/s3/rs3, but on my 19 rs3 the windshield washer fluid sprayers are absolutely terrible. They just shoot a couple tiny streams of fluid with no spray/coverage or anything, then wipers smear it around. Basically doesn’t do shit....
    Anyone else notice how awful they are?
    19' Ara Blue RS3, Milltek Mid pipes, XPEL front of car, ceramic coat on rest of car, 15% tint
    Dec 14 2009
    Houston, TX
    Quote Originally Posted by dvan5693 View Post
    With a little searching you could have saved yourself the trouble. But hear you go, buy these part numbers. They are a6 nozzles I believe, have them on mine. They mist instead of the stream.
    Part numbers:
    4G0955988A
    4G0955987A
    Feb 17 2018
    California
    Yes they suck. Search..... you’ll see threads ranting and links for replacement solutions from other models.
    Mar 27 2019
    Michigan
    Quote Originally Posted by Rocketsauce16 View Post
    Part numbers:
    4G0955988A
    4G0955987A
    Much appreciated! Just wasn’t sure if I was being over dramatic or if all Audi’s were like this(my first Audi).
    Dec 14 2009
    Houston, TX
    No problem, I personally used them to deter tailgaters, lmao.
    Veteran Member Three Rings 0000 RS5's Avatar
    Jul 13 2015
    So if let’s say Jeremy Clarkson was swapping out the washer nozzles on your RS3, he obviously would not notice the super convenient quick disconnects and would try removing the elbow from the heat shrinked tube. In doing so he would then break the quick fit connection.
    Does anyone have the part number to replace the quick fit plug/90 degree elbow?
    Once discovered, I, I mean he, made quick work of the second nozzle.
    Mar 27 2019
    Michigan
    LMAO. Maybe I’ll keep them.
    Dec 05 2010
    Los Angeles, CA
    Can someone post a brief install video. I’m sure it’s easy but I’d probably f### it up.
    Thanks
    2019 Nardo with all OEM options
    Jun 07 2019
    2017 S6
    NC
    Quote Originally Posted by BzzzBom View Post
    Thanks
    This might help.
    Veteran Member Three Rings RS3TP's Avatar
    Dec 22 2018
    Richmond Hill, Ontario
    While we’re on this topic. Is there a way to turn off the headlight washers? Those are a pain in the arse too!
    May 10 2017
    Lewisberry PA
    Quote Originally Posted by RS3TP View Post
    Do ours pop and spray or pop, rotate then spray? I think the rotate type are worse...
    2017 Ara Blue RS3
    Dec 22 2018
    Quote Originally Posted by nesbit View Post
    Good question, I'm not sure. I will need to have my wife hit it while I am standing out front to check that out.
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    Pulled from another thread:
    Disabled headlight washers:
    09 - Central Electronics
    -Long Code Helper
    -Byte 13
    -Bit 3
    Nov 28 2019
    MD
    Sorry to bump this thread, just did the install and the strength of the actual nozzle barely passes half of my windshield. Gonna try to soak the part and see if there's something blocking it.
    Btw it took 3 months for my nozzles to come from cars234 lol.
    Feb 06 2018
    Tail of the Dragon
    I've been waiting more than 3 months, they've been in Chicago for over a month and haven't moved. They told ME to file a claim - lol?
    Mexico Blau RS3.
    Nov 28 2019
    MD
    Mine was stuck there forever too. USPS apparently having delays with international shipments coming in.
    So got everything to work. If using OBDeleven go to electronics (9) then search for front wipers then go to the option that has 2000ms. Then change to 500ms. I was trying to follow an older post on the obd forum but the naming actually changed a bit.
    Established Member Two Rings RSgoals's Avatar
    Sep 14 2018
    My badges from cars234 are currently stuck in Chicago as well...
    Senior Member Two Rings Rare Ara S3's Avatar
    Jun 30 2020
    Michigan
    Mine it way up high and nearly over the windshield
    Ara Blue 2019 RS3, Ultra Blue 2022 SQ5
    Nov 28 2019
    MD
    Use a torx to adjust it near the nuzzle. What I did was set it up to the highest setting which yours probably is at on default then do two and a half whole rotation to lower it and it's perfect. I'm surprised how flimsy it is. Be careful not to keep rotating it, the actual nozzle will start to go inside or come out of the actual housing lol.
    Jun 30 2020
    Michigan
    Quote Originally Posted by crazyprac View Post
    I’m confused. Maybe because I haven’t dissected it but it looks like a rubber piece with 3 outlets.
    Nov 25 2013
    Ottawa
    The OEM nozzles are 3 outlets. The replacement A6 fan/spray nozzles use a #8 torx to make an adjustment. I have switched to the A6 version and find that having some spray go onto the roof ends up giving the best coverage.
    Jun 30 2020
    Michigan
    Quote Originally Posted by steve111b View Post
    Thanks !
    Junior Member One Ring
    Jun 28 2019
    2014 Tacoma TRD Offroad.
    Ventura, CA
    Question RS3 Windshield Sprayers
    Quote Originally Posted by Rare Ara S3 View Post
    Thanks !
    I have a 2019 RS3 and was glad to see a solution to the lousy OEM windshield sprayers. I contacted Cars245, but they are saying that the part #'s listed previously in this thread are not compatible with my car?? Sounds like others have used them, but I want to confirm that they will work before making the purchase.
    Nov 27 2020
    Florida
    Quote Originally Posted by AH101 View Post
    Confirmed. I've used part numbers listed to replace the the stock windshield sprayers on a 19 RS3 and 15 S3. Technically they are A6 windshield sprayers which is why company is saying the parts are not compatible. But they fit perfectly.
    Jun 28 2019
    Ventura, CA
    Quote Originally Posted by noseyp View Post
    Thanks for the confirmation. I will be ordering them soon.
    Jun 30 2020
    Michigan
    I bought one from an A6 after finding the part number here. It was the same shit. So I swapped my old one back and moved on.
    Jul 13 2015
    The A6 ones create and actual spray pattern, where the 3 series ones are a straight stream. Not the same shit at all.
    Mar 09 2018
    2018 RS3
    A6 fan spray pattern is better. I used to dread using the stock windshield washer...
    I wonder if there is a way to change the spray duration?
    Florett RS3+DS1+034TCU
    Nov 27 2020
    Florida
    Quote Originally Posted by tegxsi View Post
    You can with vcds. See below:
    Windshield Washer Spray Amount
    Module: 09 Central Electronics
    Select Channel: Front_wiper-Mindestwaschzeit_Frontwischer
    Select value: I chose 1000 ms others use 500
    Mar 09 2018
    2018 RS3
    Thanks! I'll look into this...
