Hi,
I have a 2008 A4 Q manual Avant with 60K miles.
Car is in fantastic condition and I get compliments from Audi/VW fans everywhere.
I am a very avid DIY and have worked on Audis / VW for years now.
Last year, the car started having a very strange A/C problem. It would stop working randomly for a few minutes, then cool just fine 90% of the time.
Since I was really busy with work around the house and other problems, and I know that in general, when you have A/C issues, it's best to leave it to the "PROS".
So, I brough the car into my local dealer.
They diagnosed bad compressor. So I went ahead and replaced Compressor, Condenser, Drier, Orifice tube, G65 sensor and re-charge.
After they replacement, the A/C worked great, for like 20 minutes, until the fans kicked in.. then the exact same problem as before showed up.
Went back and complained, they said they could not replicate.
Now, the issue became more frequent (since it's hotter outside) and cannot drive the car without A/C.
So, I started troubleshooting the issue with VCDS and found I have a code 00819:0 16 for the G65 sensor (High Pressure switch) cuts on/off intermittently only when the fans are running. When the car is in ACC, the switch shows a steady 6 bar pressure. I have confirmed that the refrigerant pressures are fine (75 static) and do not fluctuate when the fans are running.
Once the fans start, G65 jumps to 33 bar (Maximum value) and triggers the code - Value too high (Outside Spec) which in turn turns off the A/C Compressor.
Once the fans turn off, everything works great and A/C cools just fine.
I am stumped, I have tried so far:
-New G65 sensor: Same outcome
-Used HVAC panel/module: same outcome
-Unplug fans connector: A/C runs but since there are no fans, the pressure rises steadily and eventually (after 20 min) the system shuts down the A/C because it doesn't see the fans and the pressure reaches 28 bar (verified with manifold).
Here's a video of the issue:
https://www.youtube.com/watch?v=7VKLI5DSUVQ
Any help is greatly appreciated.
Thanks
