Results 1 to 24 of 24
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    The APR RS6/RS7 Catback Exhaust Suite is Here!
    Product Page
    http://goapr.io/c7rs40ex
    The APR Catback Exhaust System personalizes your sound and performance. Beautifully hand-crafted T304-stainless-steel components adorn the system with stunning TIG-welding throughout. Our straight-through brushed-finished mufflers smooth the exhaust note to a deep growl, without adding restrictions. Strong high-quality bracketry and OEM-style clamps hold the system steadily in place, making the install or removal a snap, and fitment simple, yet precise. Cast 2.75” to dual 2.5” rear splitter creates an ultra-smooth transition, steadily feeding exhaust gasses out of the system. Our cast valve housings enable the vehicle to be fitted with the factory electronic valve actuators, retaining OEM valve operation. An optional center muffler / Center muffler delete is available.
    Quick Facts
    - T304 stainless-steel construction
    - Argon-back-purged TIG welding throughout
    - Dual 2.75" to quad 2.5" mandrel-bent brushed tubing
    - Ultra-smooth cast 2.75" to dual 2.5" splitters
    - Brushed-finished straight-through sound-absorption mufflers with an optional center muffler or straight pipes
    - Cast valve housings and brackets for OEM electronic actuators
    - Rugged and precise mounting brackets
    - CNC bent and laser cut tunnel brace for added chassis rigidity
    - OEM style slip clamps
    - Direct fit to the OEM and APR Race DP exhaust systems
    - Low-profile design, suitable for lowered vehicles
    - Larger diameter piping compared to stock
    - Larger diameter tips compared to stock
    - Designed, developed, assembled and quality controlled in-house
    - Easy to install
    - Limited lifetime warranty
    System Overview
    Our exhaust system uses larger piping compared to the factory exhaust system, yet weighs less in the base configuration. We use dual 2.75" OD piping, which then splits to a quad 2.5" design. The factory system uses 2.375" piping . Finally, our system’s 4" exhaust tips dwarf the factory tips, giving the rear of the vehicle a sportier look. The system shown below includes the optional center muffler.
    Component Details
    Mufflers
    The mufflers are responsible for reducing the exhaust note and do so without adding unnecessary restrictions to the system. Each unit features two straight-through perforated tubes that are tightly wrapped with stainless steel and fiberglass material. With the valves closed, the system is tamer, but once opened, the system sounds deep, throaty and aggressive! The mufflers have a beautiful brushed finish, and are tucked high in the exhaust tunnel, making them perfect for lowered vehicles and a treat to see when looking at the vehicle from the rear.
    The optional front muffler is responsible for reducing sound volume further. This configuration is recommended for customers who have our Race DPs and want a tamer exhaust note.
    Cast Splitter
    We cast the rear muffler splitters to maximize the system’s performance by keeping exhaust velocity high and back pressure low. This is accomplished by gradually splitting the system from a single 2.75” pipe to dual 2.5” pipes. The organically shaped casting allows us to make this transition gradually as to not disturb the flow of gasses.
    Exhaust Valves
    Our system features two valves that allow control of the volume of the system via the factory exhaust valve actuators. In doing so, the system can go from tame to aggressive instantly! Unlike pneumatic systems, and other common valves found in the market today, our system maintains identical OEM operation all the way down to the factory valve actuation angles. Furthermore, the system is compatible with aftermarket exhaust remotes, allowing end users to manually open the system at the click of a button.
    We cast the valve housings out of T304 stainless-steel. Internally the system uses CNC-machined T303 components and brass bushings, which have stood up to our extreme torture testing. All necessary hardware is welded into place and is designed to combat heat and vibration for years to come.
    Brackets
    Our brackets ensure a strong and precise fit, every time. With our design, you’ll never need to worry about the brackets sagging and losing their shape over time, or the post slipping out of the hangers. The brackets are rigid, exact in their position, fit snugly in place and are made to stand the test of time.
    Tubing
    We use T304 stainless steel tubing throughout. We brush and de-burr all pipes, use mandrel bending techniques to ensure the pipes keep a constant diameter throughout, and use argon-back purged TIG welding for a strong and attractive weld.
    Tips
    The factory exhaust tips are integrated into the rear bumper valance. APR retains this layout and places the exhaust outlets within, making the system compatible with factory and aftermarket tips.
    Tunnel Brace
    The factory stamped steel tunnel brace leaves little to be desired. We’ve redesigned ours to sit slightly lower in the tunnel to allow for larger exhaust tubing. As an added benefit, the CNC-bent laser-cut brace adds additional structural rigidity to the chassis!
    Clamps
    Our system uses OEM-style low-profile slip clamps and T304 stainless-steel Torca AccuSeal clamps for the exhaust tips. Our clamp selection allows the system to sit high in the exhaust tunnel, as is favored by lowered vehicles, with ultimate compatibility no matter what DP you may have. The clamps make for easy swapping of the exhaust tips, and slide out of the way to make adding or removing a Race DP easy. Each connection point is strategically placed to ensure the system has minimal opportunity to rotate during install or during years of heavy driving.
    DP Compatibility
    We’ve designed our system to be 100% bolt-on with the factory exhaust DP and APR Race DP.
    Videos
    APR Catback Exhaust System with Center Muffler
    Purchasing Information
    All items ship free from www.goapr.com
    CBK0010 - $2,399.99 - APR Catback Exhaust System
    CBK0015 - $2,599.99 - APR Catback Exhaust System with Center Muffler
    CBK0025 - $499.99 - Optional Center Muffler Delete
    CBK0023 - $699.99 - Optional Center Muffler
    RS100004 - $29.99 - Exhaust Valve Extension Harness (Required for C7.5 / Facelift Vehicles)
    Product Page
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    Mar 13 2018
    Do the extension harnesses come in pairs or is that price for just one?
    2017 Audi RS7 APR Stage 1
    2019 McLaren 720s
    2022 Tesla Model S Plaid
    Forever in my heart but no longer in my garage:
    2017 Acura NSX
    2015 Alfa Romeo 4C
    2013 Lotus Evora
    2009 Porsche 911
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    Dyno #s would be sweet!
    2018 C7.5 A65 3.0 S BB Bone Stock - for now.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
    Aug 23 2008
    Auburn, AL
    Quote Originally Posted by phaphaphooey View Post
    You only need one.
    Established Member Two Rings uplandsway's Avatar
    Dec 16 2018
    United Kingdom
    Quote Originally Posted by Arin@APR View Post
    Product Page
    Quick Facts
    - Easy to install
    System Overview
    Component Details
    Mufflers
    Cast Splitter
    Exhaust Valves
    Brackets
    Tubing
    Tips
    Tunnel Brace
    Clamps
    DP Compatibility
    Videos
    Product Page
    Within any doubt this is going on my UK APR Stage 2 RS6 !
    Cheers,
    Stevie F
    UK 2016 C7.5 RS6 Performance APR Stage 2 http://www.goapr.co.uk/
    Aug 23 2008
    Auburn, AL
    Awesome!
    Dec 16 2018
    United Kingdom
    Awesome!
    Someone @ APR get onto Awesome in the UK then lol..
    Cheers,
    Stevie F
    Mar 13 2018
    You only need one.
    Can you explain? From my experience on the RS platform both cans have valves and both are fairly tight when connecting the factory electronics to aftermarket exhaust.
    2019 McLaren 720s
    2017 Acura NSX
    2015 Alfa Romeo 4C
    2013 Lotus Evora
    2009 Porsche 911
    Aug 23 2008
    Auburn, AL
    Only one was needed on one side.
    Aug 08 2018
    New Hampshire
    Had my RS7 up on the lift yesterday, installer commented that the exhaust was an amazingly good fit, I have mid muffler option with standard downpipes right now as my downpipes are off with Jet-Hot being coated. Still evaluating the sound at different rev ranges / throttle positions but it certainly is a lot more vocal than standard with the valves open but in comfort mode with the gearbox in D setting it’s pretty much as quiet as stock, which I wanted (wife friendly mode). Thumbs up so far APR.
    Dec 16 2018
    United Kingdom
    Cheers,
    Stevie F
    Veteran Member Three Rings Ace22's Avatar
    Oct 26 2013
    Ohio
    Kebabman...thanks for sharing. I am having mine installed today, only difference is without mid muffler. Let us know what you think with the center muffler, looks nice!
    2021 RS7 Unitronic Stage 1+, Akrapovic, Eventuri intake, Performance Wheels, IE lowering links
    2023 SQ8 Stock
    Aug 08 2018
    New Hampshire
    Well, this system certainly isn’t quiet...or maybe I’m just old!
    I’d advise anyone to go with the mid-muffler option I can’t imagine how loud it is without. With it and standard downpipes it has a nice deep sound, lots of bangs and pops on overrun (my my car had those with the standard sports exhaust too), and sounds really mean at higher revs. I’ll be honest though it is borderline obnoxious. With it in S/dynamic with the valves open for me it’s a little too loud for daily use and there is some definite drone around 3000rpm on a steady throttle, in D though it’s not much louder than stock so that’s nice but you lose the pops and bangs. Overall I’m happy with it apart from the drone, hoping that will settle in as the system carbons up, although it’s only about a 200rpm range it does it so not a deal breaker.
    Slightly concerned how it’s going to sound with the APR downpipes on when I get them back from Jet-Hot at the end of the month though.
    Aug 08 2018
    New Hampshire
    Update: with the APR downpipes this system is LOUD with the valves open. Like old lady coming out of her house to shake her fists at you as you drive by loud.
    I really wouldn’t advise anyone to go for this system without the mid muffler, it must be ridiculous. Fortunately with the valves shut and a very light foot it’s not too bad, and also the drone I was getting at about 3000rpm cruising on the highway seems to have died down, so that’s good. Wife is not happy though says I am having a mid-life crisis and it sounds stupid.
    Aug 23 2008
    Auburn, AL
    We have a new addition that many of you may want to pick up if you already have our race DPs and catback:
    For vehicles with an APR Race DP and APR S6/S7 Catback Exhaust System, or APR RS6/RS7 Catback Exhaust System, the APR X-Pipe is a must have. This upgrade creates a smooth transition between the two systems and integrates an x-pipe that reduces backpressure. This upgrade smooths out the exhaust note for a more refined sound profile while also increasing peak torque. Like the rest of the system, the x-pipe is constructed from T304 stainless steel, beautifully TIG welded, and includes all new APR slip clamps. Purchase one here today!
    Aug 08 2018
    New Hampshire
    Arin what does a “more refined” sound mean? Quieter? Do you have any videos of an RS7 with this fitted so we can get an idea?
    Aug 23 2008
    Auburn, AL
    It just sounded better to me. The tone was different. I'll get a video as soon as I get access to the car again, but it will probably be hard to tell.
    Aug 08 2018
    New Hampshire
    Ordered one so I’ll post my thoughts here once it’s on the car. I’m hoping it’s a tiny bit toned down from how it sounds now.
    Aug 23 2008
    Auburn, AL
    Thank you! We can't wait to hear your feedback!
    Jun 09 2017
    Signature
    GTA
    So will this bolt up to non-APR down-pipes? I'd like to get the APR cat-back and this X-pipe, just not sure what needs to be done/customized to fit the X-pipe...
    Current Line-Up:
    2008 911 Turbo Cabriolet Manual
    2012 VW Golf R - APR in-house build Stage 4
    2002 Audi TT 225 Quattro Roadster - Big Turbo
    1995 Camaro Z28 6 Speed - Just Bolt-Ons
    Gone: 2015 Audi S6 - Stage 3 / 2015 Audi S4 - Stage 2 / 2012 Subaru Sti Hatch
    Aug 23 2008
    Auburn, AL
    It's designed for our full 3" downpipes. I have not tested it with anything else.
    Established Member Two Rings 300zx2g35's Avatar
    May 03 2016
    SoMD
    To install the x-pipe, do you have to cut off the neck downs on both the exhaust side and the downpipe side?
    2021 Nardo Gray RS5
    2015 Allroad RS5
    2014 Matte Daytona Gray RS7
    1st B8.5 US Avant Conversion
    2014 B8.5 S4 Prestige Avant
    Aug 23 2008
    Auburn, AL
    Yes, that's the only way to make it all fit.
    Junior Member Two Rings
    Jul 10 2019
    Orange County, CA
    I’ve been looking everywhere for a comparison of this APR setup vs a Milltek. Has anyone here heard both of these in person, non-res and with center muffler?
