Hello all, thank you ahead of time for the help. Thank you to EvolutionArmory , Theiceman, and Nollywood for their help so far. Hoping to revive this fight and try to keep moving towards a solution to my car.
I can't figure out this g31 map sensor for the life of me and it's driving my crazy. I've searched for months and while I have found many threads with people having what looks to be the same problem as me, I haven't found a single thread with someone figuring it out. I have taken it to a foreign auto repair shop and they were no help. Here is the information and codes:
16621/P0237/000567 - Manifold Pressure / Boost Sensor (G31): Signal too Low
17026/P0642/001602 - Sensor Reference Voltage A: Circuit: Low
000566 Manifold Pressure/Boost sensor (g31), Implausible Signal
I've checked the wiring to the MAP sensor and i'm getting 5.6 volts with the key on. It's supposed to be 5v right? I've tried replacing the map sensor. I've tried a different ECU and still no avail. I know it's an electrical issue because when i clear the codes they automatically come back when i turn the key on again. I've checked the wiring to the MAP sensor and it looks okay and tests out okay. The car was driving great, then CEL came on and it wouldn't boost anymore. I then jacked it up, took a look at some more wiring, specifically around the diverter valve and n75 valve, could not find anything out of the ordinary. Noticed some zip ties were on the n75 wiring pretty tight, so i removed the zip tie and CEL was gone. Drove it for 30 minutes and it came back again, car stopped boosting. Numerous people think it's a wiring issue but I can't figure it out. I've checked the fuses for the ECM and they are good. Checked the fuses and relays in the ECU box and they look good. Tried new diverter valve and n75 valve for the hell of it, didn't change anything.
What should i do next? my map sensor is definitely getting power.
The wiring loom to the map sensor also has some wires that run underneath the car. Anyone know where those go to? What's up with the sensor circuit low? Could it be another sensor that isn't getting power?
SO grateful for anyone who reads and takes the time to try and help me. I dont have the money to take it to a specialist audi shop right now. Thank you thank you thank you for the comments and help.
-Lucus
