Results 1 to 17 of 17
    Jan 04 2019
    Philadelphia
    3.0T Fuel Injectors DIY
    So recently my Check engine light came on as well as the EPC light after I started up the car and it was shaking violently. Turned the car off and back on and the issue went away. Dealer did a diagnostic and found no misfires on cylinder 4 & 6. A few days later the issue came back and now the dealer is recommending replacing #6 injector and quoting me $1500 bucks!
    Anyone know the part numbers so I can shop around online to get the injectors myself? Is this an easy DIY job?
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    It is NOT an easy DIY. Direct injection uses dangerous levels of fuel pressure. Obviously it can be done but extreme caution needs to be used.
    The injector itself is $150-$200 but more parts than just the injector might be needed.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Aug 21 2015
    2018 SQ5, 2010 Q5 3.2
    Naperville, IL
    Our 3.2 Q5 had misfires and shaking and I took off the throttle body and cleaned it on both sides. This may not resolve your issue but it sure is a cheaper option to start with and it can't hurt to have a clean throttle body.
    Sent from my SM-N950U using Tapatalk
    Deactivated Four Rings
    Jun 23 2011
    You would want to change the plugs first and see what the cyl 6 plug looks like, could be a leaking intercooler.
    Oct 02 2005
    The Moon
    Quote Originally Posted by gk1 View Post
    It is NOT an easy DIY. Direct injection uses dangers levels of fuel pressure. Obviously it can be done but extreme caution needs to be used.
    I have to disagree. I've been in there multiple times and there is no need for "extreme caution." Anyone that can turn a wrench can easily do this.
    Jan 04 2019
    Philadelphia
    Here’s a little background from my first visit to dealer last Monday:
    ”Tech found 2 faults for cylinder misfires in #4 and #6 ; both sporadic. Checked for misfires with engine running. No misfires at this time. Swapped spark plug # 4 with spark plug # 1 and plug # 6 with # 3. Swapped coil pack # 4 with # 2 and coil pack # 5 with # 6. Re-checked system and still no misfires. Tech put in 1 can of fuel additive in gas tank and left customer with another can of fuel additive to use at next fill up.“
    Two days later, check engine light and epc came back and this is what the dealer said:
    “ We cannot get this car to misbehave for us. The check engine light is on, but the epc warning is not. And it started right up for us. Please tell me when exactly this is happening,. Because we cannot reproduce your concern. 1 fault happened 1 time for sporadic misfire on cylinder 6. The last time it was 4 and 6. My tech would like to order and replace the fuel injector.”
    Jan 04 2019
    Philadelphia
    Quote Originally Posted by p3u View Post
    Is this something I can just do? It sounds like one injector needs replacing. Can you give me some pointers before doing this?
    Oct 02 2005
    The Moon
    Quote Originally Posted by Shahzeb719 View Post
    Either way you're going to have to pull the supercharger, so you'll know if you have a leaking intercooler causing your problem (my guess based off description).
    Aug 06 2014
    NJ->CO
    Really? For you sure, but for a novice?
    "WARNING
    There is a risk of injury because the fuel is under very high pressure.
    ♦ Reduce the fuel pressure down to residual pressure before opening high pressure area of the fuel injection system"
    Pretty strong warning if you don't already know what you are doing....
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Jan 04 2019
    Philadelphia
    Is that an easy fix ?
    Jan 04 2019
    Philadelphia
    Dealer says Tech confirmed there is no intercooler leakage. For parts, dealer quoted me $697. I was able to source all the parts off of AudiUSAParts for $383. This is my first time replacing injectors, any tips and steps? I might have my local mechanic do it for me if it’s not too expensive for labor.
    Oct 02 2005
    The Moon
    "WARNING
    Step 1, unplug fuel pump fuse.
    Step 2, turn on car until it dies from lack of fuel, depressurizing the system.
    Aug 06 2014
    NJ->CO
    Exactly. But to the unknowing novice.
    Step 1, proceed to disconnect fuel line.
    Step 2, Call 911.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Senior Member Two Rings dorothy_c7's Avatar
    Aug 21 2018
    New Jersey
    Step 2, Call 911.
    This is from the official workshop guide on the Audi a6 c7 tsi. U can depressurize the system via vagcom or obdiiScreenshot_20190701-193330_Drive.jpeg
    Sent from my SM-N950U using Audizine mobile app
    Nov 18 2014
    2001A6,2013A7 C5 allroad
    Hartford
    Supercharger is off with 6 bolts
    The old injectors come right out/if stubborn wiggle it out gently
    Replace all seals /o rings Everytime you remove an injector .use OEM parts only
    I had all mine tested and flow matched etc
    You can go that route instead of replacing maybe
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Details for changing the water pump but the beginning shows what is needed to yank the SC. https://www.audizine.com/forum/showt...Removed-(Pics)
    Video for same job. https://www.youtube.com/watch?v=xyZL...ature=youtu.be
    Look at these to get info on what has to come apart to get the SC out.
    Since you have the SC off to do this, might be a good time for a new thermostat, water pump, and PCV / oil separator. All three of these involve yanking the SC off the engine.
    Jan 04 2019
    Philadelphia
    Quote Originally Posted by Valpo A7 View Post
    Thanks! My mechanic is working on it now, new therm, checking the injectors and replacing the 2 if necessary from original diagnostics and will work on the carbon build up in the intakes.
