Results 1 to 18 of 18
    Jun 09 2019
    Gamecock Country
    Proper tire width for 9.5" wheel?
    I'm looking to buy a set of 9.5" wide, 20" wheels for my A7. Stock tire size is 265/35/20, but that is on a 9" rim. Would that also work on the new wheel or would 275's be better? I don't want them stretched, just normal size/width.
    If 265's look right and fit, I'd rather use those as I can get them significantly cheaper.
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Well only going 1/2" wider, so if ua already jave them, throw them on. Won't be much stretch, will look fine. If ya font like, go next size bigger. But I would just try them first, since you already have them. Just my thoughts.
    Sent from my VS995 using Audizine mobile app
    Jun 09 2019
    Gamecock Country
    Quote Originally Posted by Jayz691 View Post
    What's on the car now need to be replaced (badly) so I'll be getting new tires either way. Thanks for the input.
    Jan 21 2018
    frackville, pa US
    Ah, well you can mount them, just to see. Only cost couple bucks to mount, don't need to balance. Or if your concerned about having a little stretch, bump it up 1 size. 10mm wider will almost make up for 1/2" wider wheel.
    Mar 30 2018
    long island
    i think 275 is proper.
    265 will not be a problem though.
    Sep 09 2010
    Destin, FL
    Veteran Member Four Rings 97B518TQM's Avatar
    May 31 2009
    CA. USA
    265 and 275 will both be fine. Anything bigger than 275 on 9.5 is too wide and you are putting constant stress on the sidewall at an angle it is not designed to be in. 275 on 9.5 has the sidewall perfectly even with the wheel face without any stretching. I would say for a 9.5" wheel I would comfortably run tire widths in the range from 245 to 275 so you pick.
    SOLD: B5 S4 Tial 770s with meth @652hp
    Current: C7 S6 - SRM +4mm RS turbos, SRM inlets, SRM fuel lines, DS1 stage 4 custom tune, HPFPs, X-pipe, H&R lowered
    Jun 09 2019
    Gamecock Country
    Quote Originally Posted by The Infiltrator View Post
    Thank you! I kept searching for a tool like this and couldn't really find it.
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by Twineffect View Post
    No problem. It's also not good to push tires to the minimum or maximum. Just do your research and you'll be set.
    Oct 08 2012
    Bloomfield Hills
    I got the 275/35R20 on my 2016 A7 with the 20 inch rims and they run perfect. I have the Michelin Pilot Sport 4S and love it. 265 is such a dumb oddball size, dunno why Audi chose it for the A7 and the 275 mm width for the S7...
    Feb 12 2019
    n54, B8.5
    Rhode Island
    How wide are your rims?
    Oct 08 2012
    Bloomfield Hills
    Quote Originally Posted by DrSilverShot View Post
    Mines are 9 inch wide front and rear.
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by rexus300 View Post
    You put a 275 on a 9 inch wheel? That's a little much. A 9.5 wheel with a 275 tire is max. You might want to do some research versus what looks cool.
    Mar 30 2018
    long island
    what's wrong with a 275 on a 9" wheel?
    that's the OEM setup for a S7 and RS7.
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by daytona rs7 View Post
    Stock wheels on an RS7 are 9"wide?
    Mar 30 2018
    long island
    yes. 20" forged, 21" blades, and 21" performance wheels are all 9" wide. all come with 275 tires.
    Sep 09 2010
    Destin, FL
    Well fuuuuu*****. Now I'm a little upset at Getyourwheels.com for talking me out of it and all the reasons to go with 265's on my aftermarket setup... then again there are a lot of sites that back them up on what they told me. Odd but really happy with my setup either way.
    Sep 21 2015
    Plano, Texas
    You're just fine with 265s and it looks good, not to mention your speedometer calibration is just about 100%. It's a far bigger sin to go the other way, with a wheel width far larger than the tire used. Unfortunately I see that trend far too often.
    Also note there are some small discrepancies in the tire contact patch depending on make. The shoulder block and construction of the Michelin PS 4S is just slightly wider than the Continental ExtremeContact Sport at the same size. The Pirelli P-Zero appears wider at the sidewall than it really is due to its 'rim protector strip' construction.
