Originally Posted by
[email protected]
So long as you currently have drive select settings such as comfort, auto, dynamic, then yes you are able to control the valves through the MMI. They would behave like how a CETE valve controller works on an S3:
- Dynamic - Valves are Fully Open at All RPM
- Automatic - Standard Factory Valve Behavior
- Comfort - Valves Remain Closed until 5000rpm
- ESP Double Tap - Immediate Closing or Opening of Valves
Cheers,
Hey Alexander, apologies for raising an old old, but I have a problem based on a similar topic:
I have an 8S 2016 TT Quattro. Recently I retrofitted the TTS exhaust with valves.
Successfully wired the valves to the ECU and activated them in the 01 module. The signal is coming from the ECU to both of the valves and they respond.
Issue - eventho the ECU communicates with the Valves, they live their own life. The valves do not respond to the Drive Select modes.
Current behavior - valves are open at idle to 85%, close to 15% when I drive, and open again to 85% during hard acceleration.
Expected behavior - fully closed at Auto and Comfort and open in Dynamic.
Do you know if anything in the 09 or 19 unites have to be coded? (the car has an oem drive select and artificial exhaust imitation sound)
