Had to push the key in this morning to get it to turn over for longer than usual. After that, saw CEL, so check code on OBD scanner, and got the P0016
I did drive it, but nursed it for ~3 miles
Sounds fine when engine not under load, but when try to accelerate it is way down on power. I am not planning on driving it now it is in my garage.
THere's tons of threads I know, but I couldnt find answer to my first question on compression check
Questions for diagnosis...
- Can I do a compression check (coil power leads off etc), or just the act of rotating it could cause issues?
- What's the best way to try and figure out if chain has jumped before I go investing in a new chain (and assume old tensioner)
- Will the inspection window for the timing chain tell me anything?
- I changed an ignition coil recently, assuming no correlation, but would putting the old one back in help? old one was fine, just didnt match the other 3 R8 red coils
Any help would be greatly appreciated!!!
