Hey all! I've posted my ride all over Facebook but wanted to have a place to log all of the changes that have gone into my build. The hard parts were taken care of by Our Technik in Burnsville MN. If you're ever in Minnesota and need work they would be the go to! My ride started off as a basic 2005.5 A4 Avant that was well loaded. I started like most with upgraded wheels and suspension (ST Coilovers). Beyond that I just tried to keep up with the maintenance! Again, it was fun but....basic. That's when I reached out to Nur Tecnik to see what my options were to give the car some extra go and I initially was going to go for a full Stage 3+ APR setup but the issues were I was still rocking the Tiptronic and it kept getting in the way of me having fun! I decided if I have to swap for a manual transmission it better be worth it! Soo after some long hard thoughts, looking at my bank account balance, and a few hard shots to drink I decided I needed a 2.7T with K04 upgrades and a 6spd manual swap to make this car perfect!
All the supporting maintenance and mods were added to the list to get the 2.7T ready to be installed. I went with the similar stuff that everyone else does with bolt-on upgrades:
2.7T BEL Engine resealed, timing bet, and water pump replaced
03A 6 Speed Manual
SRM K04 RS4+ Turbo
1 BAR Wastegate upgrade
V2 SRM Intercooler Kit with RS4 Hose Kit
034 Stainless Steel Bi-Pipe Set
EV14 52lb Injector Set
AMD Clutch Kit Stage 3+
flywheel ?
034 Street Density Motor Mounts
Poly snub mount
Walboro 450lph Fuel Pump
Fast Intentions Exhaust System X Pipe 2.5
SSAC 3” Downpipe
JEGS Dual Fan Controller
Stage 3 AMD tune
Suspension /brakes: I went with a Rotorlab.com for their 18z front kit with 345mm cross drilled rotors and S4 rear with 300mm cross drilled rotors. I will be adding a RS4 rear roll bar soon and swapping out the ST coilovers with Airlift V2 performance suspension. I'm running 18x8 enkei ekm3 wheels in gunmetal grey but looking for a decent set of 19's currently.
Interior: For the Interior I sourced a set of Magma Red B8 S5 seats front and rear. Everything works electrically but the Airbags are still a work in progress. I installed a Ricks Custom Wheels B7 A4 flat bottom steering wheel in red and black leather. I made custom black leather with red diamond stitching door cards with piano black trim. RS4 pedal set installed. I will be upgrading the arm rest, shift boot and ebrake handle in the same red leather to tie everything together! I ordered black trim and side panels from a B7 S4 and will be covering the headliner and anything that is cream will be wrapped with Alcantara.
Exterior: The most obvious upgrade is the DTM front end conversion! I sourced it part by part and it is by far my favorite mod to this car! I have Carbon Fiber Relak side skirts, a RS4 Style rear spoiler, and I'm currently looking for a S4 quad tip DTM rear bumper to graft onto my rear bumper. For wheels I've narrowed it down to a couple but my favorite so far are the TSW Mechanica in Gunmetal and black.
Electronics and sound: I installed a Xtrons Android 8.0 deck with CT Sounds Meso 6.5 components in custom spacers front and rear with 2 JL Audio 10W0V3-4 subs in custom enclosures. its all powered by a set of JL amps, one JX400/4D for the doors and a JX500/1D for the subs. The doors, floor, and side panels are covered in Kilmat sound deadening to keep everything nice and crisp sounding! The Xtrons deck is fitted with a reverse camera, aTPMS module, and ODB2 connection to the ecu.
I think I covered everything and if I missed something I'll add it!
https://www.instagram.com/generalzero76/
