Originally Posted by
Recklessb5
Soooooooooo... for everyone's enjoyment just to note for all those that like to store there nuts in there as.s
I completely re-did the TB job and was way within all the timing marks but just for shi ts and giggles i pinned the crank and lined the cam and chain marks up and slapped it back together still nothing so i did a compression test and all cylinders where at 100-110 psi and the leak down was within 15 percent of each other granted this motor has a hundred and sixty thousand miles, then i went along and checked all grounds and wiring to my coils and individual tested each one and all had more than enough spark, large white hot. so if we could please step beyond the bent valve BS,
i had my scanner on today and got a clear reading of about 170 rpm with a 1000 cca battery on a charger so could a crank sensor still be a chance? i did see a few reading in the past from this same sensor that showed no reading or intermittent readings, im pretty damn lost this motor ran flawlessly this cars been sitting since November in a garage.
One last thing my dumbass forgot about this was a TIP car and when i cleaned and installed the subframe i cut the tip harness could that play any role
Where was the air leaking from when you did the leak down tests??
Crank sensor definitely wouldn’t hurt to swap out especially if you had issues with it in past that probably would have been my first try.
Cutting the Tip harness could be a possibility but I don’t know much about the wiring so hopefully someone else can chime in about that.
Not sure where the hostility is coming from but no one was rude or anything to you. Your posts are very hard to understand and when you use wrong terms like chains vs belt it throws us off even more. Everyone in here is only trying to help
