View Poll Results: Does this guide work?
Voters
51. You may not vote on this poll
  • Will rather pay $155 to get CarPlay activated
    33 64.71%
  • Followed this guide. It works!
    6 11.76%
  • Followed this guide. It does not work!
    12 23.53%
Page 1 of 3 123 LastLast
Results 1 to 40 of 104
    Junior Member One Ring
    Apr 10 2019
    Washington
    Post C7.5 2016 A6 (and others) CarPlay / Android Auto Activation DIY Guide
    Disclaimer / Warning:
    I personally paid to get CarPlay activated on my 2016 Audi A6 Prestige Quattro with MMI Navigation Plus as suggested in another thread. I'm writing this after extensive research on the subject.
    These instructions are almost identical to the ones provided in the original thread (minus the remote assistance steps). Follow these instructions at your own will. I'm not responsible for bricking your car's MMI.
    Is it really DIY?
    Yes! It is actually DIY! If you want professional help along the upgrade, follow the instructions on the original thread.
    What do you need?
    Download the firmware for MMI: https://mega.nz/#!MCpwCYQS!9MS1YWoki...CFTT9geqmZB3-I
    That's it!
    Procedure
    Bottom-left, Top-left buttons listed below are the ones surrounding the rotatory wheel
    1. Format your SD card with Fat32
    2. Extract all files to SD card from RAR file - (such that you end up with a lot of folders are at root of the card)
    3. SD card with files to SD1 slot of car
    4. Turn on ignition (not the engine)
    5. Press Radio
    6. Hold Back + Bottom-Left buttons for 6 seconds - Green menu appears
    7. Tick the following option: production -> rcc_prod -> swdl_prod
    8. Press Radio
    9. Hold Back + Top-Left buttons for 6 seconds - Red menu appears
    10. Click update -> SD1 -> User defined
    11. Click Update on bottom right
    12. Enter into Bose6416A_P. Click All -> NONE -> All (if you don't do this, your Bose audio will not work until you get it fixed by a dealer)
    13. Press back and verify that N is written next to Bose6416A_P
    14. Scroll down all the way and click Start Update -> Start
    15. Wait until the process completes. Will reboot several times.
    16. In the next list that appears, scroll to bottom and click Resume -> Cancel version compare
    17. Wait until the process completes. Will reboot several times.
    18. If MMI is turned off at this time, press Start button to turn it on. Don't start engine.
    19. Reboot MMI by holding for a second or two Menu + Rotary Control + Top-right button
    20. Enjoy CarPlay or Android Auto
    Can't activate Green / Red menu?
    Search the web for solutions on how to activate using VCDS or OBDEleven or SD card method. You can be sure that some method will work.
    Error Codes?
    Yes, there will be error codes in control module 5F. Personally, I have 3 persistent error codes. Don't attempt SVM or other funky stuff; they won't go away. Simply clear all of them and ones that have to stay will stay.
    What about D-Link, remote PC access, laptop and other things that I've heard?
    Turns out, they are simply not required.
    Some Screenshots of the Update Process (in-order):
    IMG_20190618_235810_978 (1).jpgIMG_20190618_235703_181 (1).jpgIMG_20190618_235724_303 (1).jpgIMG_20190618_235729_525.jpgIMG_20190618_235738_476.jpgIMG_20190618_235755_920.jpgIMG_20190618_235810_978 (2).jpg
    Apr 05 2019
    Europe
    Quote Originally Posted by sabaatworld View Post
    I spent $155 to get CarPlay activated on my 2016 Audi A6 Prestige Quattro with MMI Navigation Plus as suggested in another thread. I'm writing this after extensive research on the subject.
    Follow the instructions at your own will. I'm not responsible for bricking your car's MMI.
    Is it really DIY?
    Yes! It is actually DIY! If you want help and want to pay, follow the instructions on this thread: https://www.audizine.com/forum/showt...arPlay-actived!
    What do you need?
    That's it!
    Procedure
    5. Press Radio
    8. Press Radio
    18. If care MMI is turned off at this time, press Start button to turn it on. Don't start engine.
    Can't activate green menu?
    Error Codes?
    What about D-Link, remote PC access, laptop and other BS?
    Turns out, it's just for creating a nice impression on you!
    Owsome stuff Sabaat bravo to you sir.
    Jun 03 2019
    Belgium
    Woooot ??? Why you have not found that 2 weeks ago ?😀😀😀 (Still i not regret those 155$ that i've spent)
    You'll be the hero of the ones who don't yet have AA and Carplay.
    Powerfull found man !
    Cheers
    Mar 29 2014
    Hampshire, UK
    I paid Carplay, and don’t regret it one bit. One of the best $155 I’ve spent.
    Complete respect to him for figuring it out and providing assistance pretty much 24x7 globally.
    If the Mega.nz is his file, he can change the file name any time he wants.
    He also provides assistance to those of us who are non technically inclined, and outside of the USA.
    I’m sure he will be delighted that your trying to undermine his business.......
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Aug 08 2018
    New Hampshire
    I don’t think the laptop and the D-link are for nothing, he uses them to enable the green/red menu, neither were enabled by my using OBD11 or VCDS on my C7.5 and I was able to get into them during this process when working with @carplay_audi so I’m pretty sure he must have enabled them using the laptop connection.
    Apr 10 2019
    Washington
    Quote Originally Posted by RAF_S7 View Post
    Agreed. However, these update instructions are easily available online on other websites as well.
    Quote Originally Posted by kebabman View Post
    You are probably right. Red / green menu may have been enabled using the remote connection, but they can be enabled using other methods.
    Mar 08 2007
    He has you take the SD card out of the 5F and back into the laptop then back into the 5F because there are a few files he loads to activate CarPlay after the main update and I notice that file disappears after it activates. These instructions alone will not activate it and will only update you to the new software. I watched it done 3 times cause I did a couple co workers cars also. He uses the D-link just to activate the green menu I believe
    2016 A6 Ibis White 3.0 TDI Premium Plus S line sport package LED headlights
    Gone
    2017 Allroad Glacier White Premium Plus Tech Package Sport Package
    2017 A4 Ibis White Premium Convenience Package
    2013 Allroad Glacier White Premium Plus
    2001 A4 Quattro Silver RNSE
    Senior Member Three Rings ClaudeG's Avatar
    May 27 2017
    2023 Audi Q7 3.0 | Daily 2006 Mazda Speed6
    Santa Clarita
    Awesome write up! I did pay CarPlay too, I don't regret it but this is great for everyone else!
    2016 S6 Prestige, Sepang Blue, Black Optics, Lunar Silver Interior | APR Exhaust | VMR V802 Matte Bronze wrapped in 275/35/20 | Silly Rabbit Intake | NeuSpeed SS Brake Lines | Lowered via OBDEleven | JL Audio XD7005V2 | JL Audio 10"W3
    GONE BUT NOT FORGOTTEN 2017 A6 3.0 Prestige, Brilliant Black, Black Optics
    Daily... 2006 MazdaSpeed6
    Established Member Two Rings Prak98's Avatar
    Apr 15 2017
    WI
    I'm assuming this is only for C7.5+ with MIB2?
    Aug 08 2018
    New Hampshire
    Quote Originally Posted by Prak98 View Post
    Yes, 2016 in the US, some 2015s in Europe.
    May 30 2016
    Lake Forest, CA
    My mmi needed a firmware update to a newer mmi version before updating and enabling CarPlay. Doubt these instructions are enough. I know the dlink is used to access the shell and reach root.
    Established Member Two Rings Brav's Avatar
    Aug 27 2007
    64 Riviera, 2010 RR S/C
    Huntington Beach, CA
    I can't seem to get into the green screen. I'm on MHI2, software 0387. I can get into red engineering screen, was able to update from 2016 maps to 2018/2019, but no green screen, no matter what I try. How can I get in or force firmware update? I activated 5F with VCDS successfully too, no luck tho.
    2016 A6 2.0T Quattro
    Apr 10 2019
    Washington
    Quote Originally Posted by Brav View Post
    This might help: https://upgrademyaudi.net/tutorials/...ript-and-vcds/
    Or this ( if you have VCDS): https://www.youtube.com/watch?v=d9XHft7zpYc
    Established Member Two Rings FEROCIOUS's Avatar
    Oct 23 2017
    Thank you
    Aug 27 2007
    As mentioned, I did it with VCDS, and the channel 6 value changed to 1. Still can't get in. Strange that the link you sent says that MIB (the system we have?) says hidden menu button sequence "NOT AVAILABLE"
    I did watch that youtuber who did the VCDS method, and had to tried 5-6 times holding down the buttons, and it finally worked eventually.. maybe I just didn't try enough.
    Apr 10 2019
    Washington
    Yup. Seems like that it does require that you put the buttons simultaneously. Found another guide: https://docs.google.com/document/d/1...h.4vdg5bashogt
    Did you try Setup+Car or Menu+Car?
    Aug 27 2007
    I tried every combo I could find on the internet lol. Will keep trying tonight.
    Veteran Member Three Rings Wkraus's Avatar
    Sep 25 2017
    Prior lake minnesota
    I have another way you can try. Pay the pro $155. It will be done right. 😉
    Apr 11 2019
    Dublin
    Quote Originally Posted by Wkraus View Post
    I 2nd that.
    Established Member Two Rings TXautobahn's Avatar
    Jan 17 2017
    Houston
    Hi guys, just picked up a 2016 A6. Can someone point point me in the direction of the $155 activation that keeps being referenced?
    2016 A6 Prestige TDI
    2013 VW GTI
    2008 Corvette Z06
    Some previous rides:
    2011 S4 Prestige 6MT
    2008 Corvette Z51
    2006 Subaru Legacy GT
    2003 BMW 330i
    2002 Corvette Z06
    1996 Corvette LT4
    Aug 08 2018
    New Hampshire
    Quote Originally Posted by TXautobahn View Post
    Message a guy called @carplay_audi on Telegram, more details in this thread:
    Aug 13 2014
    Czech
    Hello, does someone have link to EU version of newest firmware?
    MHI2_ER_AU57x_P3634
    I think that your manual should be amazing, but are you sure, that carplay does not need any telnet activation ? (via DLINK Ethernet cable etc?)
    Thank you
    Jul 11 2018
    Fareham
    Before i brick my MMI, will this work with a 2012, with the latest firmware.....?
    Mar 08 2007
    2016 only, must have the usb’s Under the armrest already.
    Gone
    Jul 11 2018
    Fareham
    Jun 11 2019
    Seattle WA
    I'm hitting a snag, I wonder if anyone can help:
    [LIST=1][*]Format your SD card with Fat32
    [*]Extract all files to SD card from RAR file - (such that you end up with a lot of folders are at root of the card)
    [*]SD card with files to SD1 slot of car[*]Turn on ignition (not the engine)[*]Press Radio[*]Hold Back + Bottom-Left buttons for 6 seconds - Green menu appears[*]Tick the following option: production -> rcc_prod -> swdl_prod
    [*]Press Radio[*]Hold Back + Top-Left buttons for 6 seconds - Red menu appears
    [*]Click update -> SD1 -> User defined
    I can get to a point where I click SD1, but then it scans the SD card and throws an error, I never see 'User defined', I just get the above error. Anyone seen this before?
    Mar 08 2007
    Try this:
    Go to RCC-tools-0-default, then take the file “update persistence” and move it to the root folder also. Then try the update again.
    Gone
    Jun 11 2019
    Seattle WA
    Thanks for the reply!
    Same behavior, I'm afraid. I noticed a 'logging' section in the red menu now though, which listed a number of updates through 2018. The car had Audi Connect when I bought it, I wonder if that's different than the norm.
    Mar 08 2007
    The logging screen is normal. The update won’t take because it sees it’s not compatible. “He” did something real quick in the beginning that enabled the green screen and also changed the software level to something higher so it would trick it to accepting the update. Can anyone else who paid for the update verify that he installed a program on their desktop?
    Gone
    Apr 05 2019
    Europe
    Dear Guys,
    just a little update on the matter of instrument glitches.
    I took my car to Audi dealership, they tried 4 days to to fix my sporadic optical bus error after android/car-play firmware update. Since i had removed the 5f controller faults related to SVM by doing adaptation with OBD tool they could find anything telling that firmware was tempered or upgraded by third mean.
    they called me today and said they tried updating software or something but its not working (they had ordered a firmware update from Audi). They brought this problem to Audi, Audi told them that ECU is faulty (they said its their fault, i dont know what this means ) and they will replace my ECU with actual software (Audi will do all this in warranty).
    i am interested to know what ECU are they talking about ? and secondly will it reset everything? I asked that guy if i would still have access to all the features, he said yes i would.
    Mar 08 2007
    I’m assuming the ecu they’re replacing is the actual instrument cluster. If they were to replace the 5F module then you would not have CarPlay anymore.
    Gone
    Jul 03 2019
    Craiova, Romania
    Hey guys,
    I just watched the videos that @Gunmeister did and i doubt the above will work. He creates a Team Viewer VPN and through that he does something on his local machine that feeds information through the DLink.
    Would strongly advise not to try the above because i also saw that whatever you download from Mega is not complete, something is missing which he adds once the installation begins.
    Videos can be found here: https://drive.google.com/folderview?...xDOLsmrzfa3sSa
    @sabaatworld i still apreciate what you posted and its very good in figuring out the solution for all out there but we need to dig more :)
    Aug 11 2016
    CA
    Quote Originally Posted by Poison View Post
    Dear Guys,
    Did you tell the dealer you did the update?
    Apr 05 2019
    Europe
    Quote Originally Posted by gta7 View Post
    No
    Veteran Member Three Rings Gunmeister's Avatar
    Feb 03 2019
    Spokane, WA
    Hey for the record I never guaranteed my video would help in anyway I recorded it for myself for my records lol. Ignore my terrible camera skills and my handicap brother and I being retarded lol.
    2016 A6 TDI*|*Mugello Blue, Pearl EffectExterior | Alabastar White Interior | Audi Exclusive Line | Eucalyptus Natural Wood Decorative Inlays | Prestige Package | Comfort Seating Package | Driver Assistance Package | S Line Sport Package | 20" Black Optic Package | Cold Weather Package | 18% Ceramic Film Windows | 70% Ceramic Film Windshield | Thinkware F800 Pro Dash Cam | Audi All Weather Mats*|1 of 1 for 2016
    2016 A6 TDI | Mugello Blue, Pearl Effect Exterior | Alabastar White Interior | Audi Exclusive Line | Eucalyptus Natural Wood Decorative Inlays | Prestige Package | Comfort Seating Package | Driver Assistance Package | S Line Sport Package | 20" Black Optic Package | Cold Weather Package | 18% Ceramic Film Windows | 70% Ceramic Film Windshield | Thinkware Q800 Pro Dash Cam | Audi All Weather Mats |1 of 1 for 2016|
    Aug 27 2007
    Just got my carplay to work on my 2016 A6. I paid Carplay_Audi, since I could never get the green screen to activate on my own. small price to pay.
    However, my wifes Iphone 7 works great, but the car will not recognize my iPhone X. I reset all settings, allowed Siri, etc. still nothing.
    Feb 15 2017
    Rochester Hills, MI
    I'm using Iphone X, no issue at all. Maybe you could try different wire or port
    2016 RS 7 Sepang Blue, Milltek Non-Res Exhaust, AWE S-Flo 2.0 Intake, APR Stage 1, Neon Yellow Caliper, Black RS7 Performance Wheels, Escort Passport 9500ci Radar Detector with AL Priority Laser Jammer
    Aug 27 2007
    Quote Originally Posted by allenzhang215 View Post
    Not sure.. same wire and port work fine on the other iPhone. Probably some stupid setting is off. Will update when i figure it out.
    Mar 29 2014
    Hampshire, UK
    A few of us have found that switching the cable to the other USB port cures a couple of problems. No idea why, but it works....
    Aug 27 2007
    Awesome, will try
