Results 1 to 21 of 21
    Dec 26 2013
    Newcastle, WA
    First C7.5 in USA w/Matrix Audi Headlight Retrofit
    I'm very late to post this but wanted to get the info out! Alex and I worked together after WidebodyFX successfully did his RS7 conversion. Once we ironed out fuse locations and such, he sent me the necessary cable for the Matrix lighting!
    When going from LED>Matrix, the original Modules will not work. You'll need to purchase a set of Matrix lights that come with their necessary modules and fans. Going from LED>Euro LED was a simple afair, simply swapping modules over from existing North American headlights. After many weeks of hunting I finally found a set of GOOD condition Matrix lights. I'll suggest to simply order the entire light assembly from Alex and sourcing your own pair that is honestly in good enough condition to swap into your vehicle is really tough.
    Full Matrix Conversion from Europrice, soup to nuts: https://europrice.us/headlights-a6-s...t-packages-oem
    Matrix Coding+Harness if you're supplying your own lights/modules: https://europrice.us/installation-pa...ift-matrix-led
    Without further ado, here are a few video's in action. My car has a Europrice conversion harness with OEM Audi European Tail lights along with OEM Audi Matrix headlights. Alex performed the coding necessary once we did a test-fit with harness, once we verified all functions worked as expected, I was told to finalize the install!
    Dark roads with Automatic lights switched, you can actively see the lights dimming around cars and signs. Once glare is noticed the lights switch off that beam while illuminating everything around the sign/glare, very cool but very odd seeing your brights "on" while facing incoming traffic.
    Full video here, you can see the "startup" sequence of the Matrix lights.
    Chris
    2018 Nardo Gray
    |HRE|H&R Module|OEM Euro Headlights|OEM Euro Tailights|Akrapovic|
    2013 Glacier White S6 |APR Tuned - Sold
    Feb 25 2015
    Phoenix
    Nice! What’s the approximate cost for the conversion?
    Dec 26 2013
    Newcastle, WA
    Quote Originally Posted by Chiromikey View Post
    Depends on if you're purchasing the full meal deal or sourcing your own lights. I was able to sell my Euro LED's to recoup a large portion luckily. I'd say ~3k on the low-end
    2018 Nardo Gray
    Veteran Member Three Rings DocTJ's Avatar
    Jul 29 2016
    PA
    gorgeous.
    Prior: '16 A7 3.0T Prestige, '16 S7 Prestige, ‘17 S8 Plus, '18 Porsche Panamera Turbo S - E Hybrid
    CURRENT: '23 Nardo Gray RS5, Carbon Black Optics, '18 Q7 Prestige
    My S8 modified exhaust: https://www.audizine.com/forum/showt...Muffler-Delete
    Mar 11 2007
    Colorado Springs
    That's great work. The Matrix lighting is really special. 3k is a pretty good deal too...
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Veteran Member Three Rings Speedooooo's Avatar
    Sep 13 2015
    Cincinnati, OH
    That's a good looking car, and headlights look crazy. What cars come with the matrix headlights? RS6?
    2018 Glacier White A6 3.0T | Driver Assistance | Sport | Black Optics
    2016 Mythos Black Q5 3.0T SOLD
    Established Member Two Rings vrod's Avatar
    Oct 02 2018
    Germany
    All C7.5 variants (Europe) have the Matrix option. RS6 however have completely been blacked out inside the headlight whereas A6/S6 have silver paint inside the headlight.
    Veteran Member Four Rings 97B518TQM's Avatar
    May 31 2009
    CA. USA
    For $3k+ I’ll happily continue rocking the stock led lights. These look great without a question but damn that’s a lot of money for a cosmetic thing and especially given how nice the stock led lights are to begin with.
    SOLD: B5 S4 Tial 770s with meth @652hp
    Current: C7 S6 - SRM +4mm RS turbos, SRM inlets, SRM fuel lines, DS1 stage 4 custom tune, HPFPs, X-pipe, H&R lowered
    Senior Member Two Rings DB22's Avatar
    Feb 12 2014
    So Cal
    Yes, it costs a lot of money to make the USA watered down version into the high tech version that the ROW get. If anyone in the US government could drive then they might get off of their duff and allow some technology that was invented after WW2.
    2014 A6 Prestige. VCDS, Chipwerke.
    Veteran Member Three Rings DoItAllGarage's Avatar
    Oct 29 2013
    WA to ID
    Those headlights are pure sexy!
    Sent from my SM-N960U using Audizine mobile app
    Veteran Member Three Rings SeattleiteA6's Avatar
    May 08 2015
    Simply stunning. Well done!!
    2014 Phantom S6/B&O/Innov/BlkOptx
    Pixel 2 XL using Tapatalk
    2014 S6 Phantom w Black Int & Carbon Atlas//B&O//Innovation//Black Optics//RS front clip//E-code Dynamic Tails//Carbon Diffuser w carbon tips//VCDS -15mm//Straight Pipes//JB4
    2018 Q7 Night Black w Black Int//Technik Trim (CAN origin)//Luxury Pkg//Black Optics//Adaptive Air//euro tails and other mods forthcoming...
    2013 Q7 3.0T Prestige S-Line Plus
    2013 RS5 Ibis w Black Int//e-code tails//20" HRE FF01
    2012 A6 3.0T Prestige//Sport Pkg
    Veteran Member Three Rings weagle1856's Avatar
    Dec 15 2015
    Audi TT 225, Audi A4 Avant, VW CC, BMW X5
    Denver
    Quote Originally Posted by DB22 View Post
    This.
    Also, incredible! Looks great!!
    Sent from my Nokia 9 using Audizine mobile app
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    This is pure sex!!! Great job getting it done.
    C7 S6 / AWE Touring / -14mm / EuroTails /
    Feb 12 2014
    So Cal
    Quote Originally Posted by ichi d View Post
    You must be doing it wrong!
    Established Member Two Rings Prak98's Avatar
    Apr 15 2017
    WI
    Beautiful.
    Aug 08 2018
    New Hampshire
    I so want these for my car but just can’t justify the $$ outlay.
    Feb 12 2014
    So Cal
    We should all tell our dealers that we want this feature as an option so, hopefully, the feedback will get back to the mothership. The cost is prohibitive because you have already bought thousands in lights and hardware that you then leave in the garage and replace with the real thing at heavy additional cost. The time to push is when you buy the car and threaten not to purchase because they are trying to sell you inferior product.
    The manufacturers association should really push the government authorities to wake up to advancements in technology. There is something wrong when third world countries get advancements that the USA cannot get.
    Stage 2 Banner Advertiser Four Rings
    Aug 07 2008
    Dallas, TX
    Car looks great and glad everything is working well.
    Thanks for being the first A6/S6 C7.5 in NA with these and helping out.
    If anyone has questions about the setup don't hesitate to ask or PM/email: [email protected]
    Cheers!
    Alexander van Gerbig
    www.europrice.us
    [email protected]
    Dec 26 2013
    Newcastle, WA
    Audi would love to sell them to us in North America.. It's the NHTSA and Fed's :)
    2018 Nardo Gray
    Feb 12 2014
    So Cal
    Quote Originally Posted by dudley123 View Post
    Only Audi USA can petition the us government, the consumer doesn’t have the resources. Our only recourse is to complain to the dealer and hope it eventually gets back to corporate.
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    I've read that Audi is trying to get them into the USA, but it takes a lot of time to get the law/rules changed.
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
