Results 1 to 20 of 20
    Veteran Member Four Rings PKmode's Avatar
    Sep 19 2005
    Milwaukee, WI USA
    ZF8 Fluid - To flush or just change
    Let's talk maintenance for a second. My 2012 Prestige (APR DP) is getting old on me. Last Fall I did the TB, WP and carbon cleaning along with a basic tune up. Now I just cracked 100K the other day and really got to thinking about doing some PM to the trans. I realize at 100K, I should have probably done it sooner but also feel like that isn't completely out of line as ZF recommends servicing at 80K miles. Of course Audi's stance is 'lifetime' but we know better than that.
    I'd like to do a full flush so I get ALL the fluid changed and pumped out of the Tq convertor and valve body but I know that can be somewhat risky, usually with higher miles though. So, taking into consideration the miles (100K), do I do a full flush and risk possible contamination from old oil contaminants clogging up the channels in the valve body; or just change the fluid and filter all call it a day? I have VCDS and can do the DIY change but would rather have a shop do the full flush if it's deemed 'safe'.
    Who has done either or and what was your experience? Thoughts and input appreciated.
    Do it right, or don't bother.
    Feb 12 2019
    n54, B8.5
    Rhode Island
    Drain & fill baby!
    May 20 2010
    On my B7, the first time I changed the fluid was at 108k miles. At that time, I just refilled with the fluid (incl cleaning pan, replace filter, etc). Felt better.
    Second time, took it to the shop and they used Lifeguard 8 (previously Lifeguard 6). Trans starting slipping on the way home, so brought it back. Shop owner recommended Redline D4, and to do several drain and fills to remove the old fluid. They did exactly that (said the old fluid was very watery; not as viscous and oil-like as it should have been). Trans felt so much better, and shifts were crisp again.
    My recommendation is to just do the simple drain and fill. But if you want to get as much out as you can would be to do several drain and fills in succession--should get you closest without ripping the thing out
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Oct 02 2005
    The Moon
    I recently did this.
    I first did a drain and fill and 1k mileage later performed a drain and replaced the filter. I did it this way as the drain and fill only removes approximately 50% of the fluid and a flush seems too risky.
    After a short period of new time with the new fluid it helps clean the internals and at that point did the second round.
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    I want to change my 2012 but at this point I am almost afraid to. The original owner followed the fill for life Audi mentality. I bought it at 142K and now have 171K on the ORIGINAL FLUID. The tranny shifts fine and is very smooth but I am afraid of changing at this point and wind up flushing shit out of the nooks and crannies.
    Mar 11 2007
    Colorado Springs
    I wouldn't touch it. Been driving Audi Cars with ZF slush boxes for 30+ years. The recommended service interval was 30k miles on the 3 speeds in my C3 cars. I was faithful and got my ass burned 3 times. Between 2-5k later I'd have a failure. AoA did replace one unit for me gratis.
    My C5 has 300K it's my winter beater now and I've never cracked a pan screw. That "lifetime" fluid is doing just fine... I tried to have Audi change it at 30k, and 60k and they wouldn't do it. I stopped asking...
    If you really want to do it for peace of mind, when I lived in Chicago, I had ZF rebuild one of mine, they use to have a service center in Vernon Hills (Northern burbs) Not too far from you in Milwaukee. There is another place in WI that used to do great work on ZF units called BlauParts Service, you probably know it? It might not hurt to give them a call and pull their coat tails about a best course of action.
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Sep 19 2005
    Milwaukee, WI USA
    p3u, Sounds like a good way to go.
    A6Sport, you had flushes done, yes? If at the dealer, then yes. That's what I was saying was risky as far as clogging an internal channel in the valve body. I don't think draining and replacing fluid and filter would net the same results. Also, I know the Blau guys. They aren't too far from one of my customers up towards Sheboygan.
    Thanks, guys.
    Mar 11 2007
    Colorado Springs
    Not on the 8 speed nor the C5 5 speed tip. These days I just roll the dice.
    2012 A8L 4.2
    May 20 2010
    Find a good indy shop and you can cut out some of those ungodly stealership prices
    Senior Member Two Rings dorothy_c7's Avatar
    Aug 21 2018
    New Jersey
    I've seen another zf8 trans fluid replacement. It was like an all day affair for the guy. Hey would do exactly what everyone has be saying. Drain some drive fill some drive drain some drive. A little bit at a time. I was like sheeesh this is a process that could result in error. I'm having my indy shop I trust dearly, do this for me.
    [SideNote]: I work for a little local residential and commercial fertilizing company. Any time we flush products with other liquids. We do the same thing, always keeping fluid running throughout the pumps to prevent damaging any components. It makes since to be easy and not do a complete flush
    Sent from my SM-N950U using Audizine mobile app
    Aug 21 2018
    New Jersey
    Quote Originally Posted by p3u View Post
    Idk if u or anyone else have the official Audi c7 workshop guide. (Literally has everything for $30). I believe I found it under [Servicing 8-speed Automatic Transmission] section 7.2 Filling and Draining ATF page 78. Also I'll ask my 2 friends that work at the same Audi as techs. One is actually the floor supervisor.
    Oct 02 2005
    The Moon
    Quote Originally Posted by dorothy_c7 View Post
    You can't drain more than half the fluid at any given time. That's why that person did it as described and why I did it on two separate occasions.
    Oct 02 2005
    The Moon
    You can't do the job for $30. If you are DIYing fluid alone for the correct type would be $80 minimum (4 liters) for ZF Lifeguard 8 and OEM filter kit $60.
    Aug 21 2018
    New Jersey
    That's for the guide book. But u right u right lol
    Aug 21 2018
    New Jersey
    Not buying it but why would they sell them in 9x 1liter increments? Europarts ftw tho. I love locally be able to pick up goods. https://www.europaparts.com/automati...k-8-speed.html
    Oct 02 2005
    The Moon
    You only get ~4 liters out on a drain and fill, about 5 if replacing filter. Torque converter holds about half of the fluid...
    Jun 14 2019
    Rockville,MD
    Coming from bmw with years of experience with zf transmission. Always Drain & Fill. Never flush. The one time I flushed the transmission it died 3 weeks later. Please do not hit the lifetime fluid crack pipe.
    Sep 19 2005
    Milwaukee, WI USA
    FCP sells a similar kit. I'll compare. https://www.fcpeuro.com/products/aud...iABEgKnj_D_BwE *Edit, it looks like the FCP kit includes the filter while Europarts does not.
    As p3u stated, the 9L of fluid accounts for the whole system including what's in the torque convertor and valve body. If you just drain, you're not getting 1/2 the oil changed. That's why the dealer does a "flush" which uses a pump and pulls new fluid in as the old is pushed/flushed out. As mentioned above, THIS is when larger contaminants could potentially come loose and will flow through the system, potentially causing a clog in the valve body.
    Additionally, to Doroth_C7, It's true the fluid needs to come up to full operating temp before being topped off. If you drain twice in the same day with a drive in between, I can see it taking a while. It shouldn't be all day though. Especially if you have access to a lift.
    Veteran Member Three Rings jrsAudiA6's Avatar
    Oct 11 2011
    2018 A5 SB
    Riverside, California
    You might want to check this thread for more info on this subject. https://www.audizine.com/forum/showt...d+transmission
    2018 A5 SB Matador Red Premium Plus
    2012 A6 Garnet Red, Prestige Pkg, Innovation Pkg, B&O, 20" Sport Pkg, H&R RSS + Coilover, Alcon Mono6/380mm front brakes, S6 rear rotors(356x22mm)/caliper carriers.
    034 DL fr suspension arms, 034 Track DL engine mounts, Eurocode Front and Rear sway bars & Alu Kreuz front brace, 034 ECU/TCU tune, DP PR 3.11, JHM Hx
    CTX 50% Tint F. S. Windows, CTX 30% Tint R. & R. S. Windows, 3M Pro PPF, hood, L & R fenders, AWE Exhaust w/o down pipes
    Sep 19 2005
    Milwaukee, WI USA
    Thanks. Read it quick. I think I'm planning the DIY fluid drain and refill and add new filter, etc. I'm not doing the diffs as I'm not tracking the car. I'll report back down the line when I have time to tackle this.
