Results 1 to 3 of 3
    Active Member Two Rings dithmartfitness's Avatar
    Apr 28 2019
    2000 A4 Avant 5speed Quattro
    moline Il
    Wheel bearing grease type?
    Cant find this answer anywhere, even chiltons wont tell me. Is this stuff going to work for a wheel bearing replacement? I've posted this in my other thread just hoping someone stumbles across this tonight so I can get this dang car done
    Sent from my SM-G960U1 using Tapatalk
    Veteran Member Four Rings Blazius's Avatar
    Mar 15 2018
    Europe
    u need moly grease. im p sure cv joint grease works too
    Established Member Two Rings Pumpkinslap's Avatar
    Oct 11 2017
    00' S4 track car, 97' A4 soon to be 4.2, 01' A4 2.8, D3 A8L, 2023 5.0 F150, 2022 Mustang GT 6MT
    Washington
    Quote Originally Posted by Blazius View Post
    i second this, when i was at the dealer some of the other techs used stuff like this, personally i used just a typical moly based grease as that is typically what is recommended by the manufacturers, and yeah if you have some cv joint grease laying around, use that instead.
