Results 1 to 8 of 8
    Senior Member Two Rings jorte014's Avatar
    Apr 16 2013
    Mercedes-Benz ML 350
    Coral Springs, Florida
    ABS Module Incorrectly Coded: Fault Code 01044
    I did a Carista scan recently and kept getting "ABS Module Incorrectly Coded 01044" code. Kept coming back even though I reset the faults.
    I have not changed anything through VCDS or anything like that either.
    Don't notice anything different with the car really so what could be causing it and what could I try to fix it?
    2014 S4 6MT - Milano Red | Premium Plus | Black Optic | Bang&Olufsen
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    Quote Originally Posted by jorte014 View Post
    have you disabled DSR? i did that years ago and have had the code since
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
    Apr 16 2013
    Shit I do, but I disabled that over a year ago. Weird that it started showing up now. I'll reenable it and report back.
    Apr 16 2013
    Ok, that ABS code is gone now but now I got a myriad of other codes?!! WTF
    Parking brake:
    463360
    Airbags:
    9444356
    Engine:
    11837
    Car is running fine from what I can tell. Can anyone shed some light on these? Google search did not turn up anything conclusive.
    Jan 27 2018
    B6andB8.5S4
    Houston TX
    Battery?
    Apr 16 2013
    I got a reply from Integrated Engineering that code 11837 is caused by an over rev scenario. I didn't bounce off the rev limiter but I did push the car hard recently.
    Codes
    Parking brake:
    463360
    Airbags:
    9444356
    Still remain a mystery.
    - - - Updated - - -
    Quote Originally Posted by sikbuck View Post
    Battery?
    Interesting...what should the voltage be on a healthy battery?
    Aug 23 2011
    NH
    i missed a shift yesterday (floored it from 3rd to 4th but hit the gate missing 4th) and like 18 codes popped up (some i generally have from having test pipes)
    ABS codes, sport diff fault, - the list went on. i pulled over, ran a scan, cleared the codes and restarted the can ran another scan and almost all were gone
    point is that sometimes one random thing seems to trigger several codes. go figure
    Apr 16 2013
    Left my battery charging over night on a battery tender. So far no codes. I think all is well and I freaked out for no reason.
