Results 1 to 27 of 27
    Aug 08 2018
    New Hampshire
    Question Heat wrap downpipes - pros and cons
    So I’ve got a set of APR downpipes to fit to my RS7, and one thing I always notice about this car is the sheer amount of heat that accumulates in the engine bay, even after relatively short drives often it’s so hot it’s hard to even remove the engine cover without gloves. So I was thinking before I fit the downpipes maybe I could reduce some of this engine bay heat by heat wrapping the downpipes, are there any downsides?
    I’ve read about the nasty fiberglass fibers when wrapping, the bad smell at the beginning as the wrap gets cooked, and the fact that the wrap can actually shorten the life of the downpipes by trapping water and salt in contact with downpipes. I can cope with the fibers during fitting and the smell (as long as it goes way after a while), and I would mitigate the water/salt problem by spraying it with high heat silicon spray coating after wrapping.
    Any other downsides or reasons not to do this that I’ve missed? Will it have the desired effect of reducing engine bay temps by a noticeable amount? Any other pros I might not have thought about? I don’t want to go to the effort of wrapping and spraying the downpipes if I get no appreciable benefit (not bothered about the aesthetics).
    I plan to use this wrap: https://www.amazon.com/dp/B002R4U7G4..._CogaDbH1FAT4F
    And this silicon spray coating: https://www.amazon.com/dp/B000MY3ML8..._CqgaDb0KV9P2R
    Veteran Member Three Rings MolonLabe300's Avatar
    Aug 16 2017
    Chattanooga
    I used this and was happy with the outcome.
    https://www.heatshieldproducts.com/i...hield-products
    Sent from my Pixel 2 XL using Audizine mobile app
    13 S6 SRM +4mm, Flex Fuel lines with ethanol sensor, Milltek turbo back, SRM Red Long intakes, NGK race plugs, AMG coolant pump. Merc HX, DS1 OTS stage 4, SRM TCU
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    I actually used the exhaust metal insulation heatshield armor on my dp's/hotside turbo/manifolds:
    https://www.heatshieldproducts.com/heatshield-armor
    S6 C7 avant '13 estoril | ceramics | DS1 OTS stage 2 | Lightvan | Milltek non-res X pipe | TS1 | 034 trans-diff mount | CETE ASC-EVC | FL tails & dynamic signals | Thermo ZO catless DP | SRM a2a | BC Forged 20" HCA162S | custom spoiler sideskirts | Maxton front lip & diffuser | Armor heatshield mani-turbo-dp | B&O led tweets (repli) | Forge boost hoses | FIS mmi gauges | R8GT steeringwheel | alcantara interior | SRM inlets | R8 exclusive seats | JXD driveshaft | Tial WG
    Jan 09 2014
    2012 a4, 2015 s4
    TX
    Quote Originally Posted by kebabman View Post
    Straight from product description "Design Engineering Hi-Temp Silicone Coating spray is NOT recommended for DEI Titanium wrap"
    Sent from my SM-G965U using Tapatalk
    Mar 30 2018
    long island
    id suggest a ceramic coating instead. its a much cleaner look with none of the problems of heat wrap.
    all your cons for heat wrap are true. I've used it on previous cars. the itch when installing. the smell after driving (does go away though). and the corrosion is true, although i didn't experience it since i didn't have the car for long.
    Aug 08 2018
    New Hampshire
    Do you know how much it would cost roughly to have a pair of DPs ceramic coated? Don’t really know where I would get it done but I’ll do some research, thanks for the suggestion.
    Quote Originally Posted by mintytoo View Post
    Where do you see that? I don’t see it on Amazon, I see this:
    “For use with all DEI exhaust wraps, HT Silicone Coating penetrates, seals and protects as well as helping to extend the lifespan of all DEI exhaust wraps. See special instructions below for best adhesion on Titanium exhaust wrap products.
    Titanium Application Instructions
    While not required for Titanium exhaust wrap, HT Silicone Coating will protect and prolong the life of the wrap. DEI recommends a minimum of three coats, each heat cycled for curing before applying the next coat. To cure, HT Silicone Coating needs to reach a temperature of 400°F for approximately 2 hours. Allow to cool before applying the next coat.”
    Thanks for the heads up though, looks like I might not need the spray coating with a titanium wrap, and if I do apply it I need to heat cycle between coats....not gotta happen once it’s on the car but I guess I could try and fit my DPs in the oven or something. I know my wife would love that.
    Jan 09 2014
    2012 a4, 2015 s4
    TX
    In the description for the wrap, from Amazon,
    Sep 07 2010
    Belgium
    Quote Originally Posted by daytona rs7 View Post
    Not sure if ceramic coating is simular to thermo ZO coating (i think it is simular?)...anyway, my russian catless pipes were treaded with that but kinda sceptic about how effective that coat is. Afaik i does help (don't have my temp records at hand) for a bit but nothing helps better then some good old insulation and heat shield afaik. Like said i used the thick version and after a run i can almost put my hands on the turbo's/dp's while seeing though gap the turbo's are smoking red. Oh yes, that is bit the downside, while it is all good and nice to keep heat trapped inside the tubes, things inside get hotter and longer...
    and i suppose that is why i frequently need to replace my coolant o rings (yeah i use cheap one compaired to the overpriced OEM ones but last as long...things just get hotter down there, luckly only inside and not outside).
    *ignore the heat wrap around the intakes, has been removed ;).
    Mar 30 2018
    long island
    these are the coating i was referring to.
    https://www.jet-hot.com
    good reviews for looks and ok for heat. but still better than no coating.
    there is also this one, which has better reviews for heat reduction
    http://swaintech.com/race-coatings/a...s-price-sheet/
    Aug 24 2014
    Denver
    Another ceramic option I used is Cerakote. I don't have any data on how it affects temps I just put my DPs on. But it looks really clean.
    Sent from my SM-G955U using Audizine mobile app
    Sep 09 2010
    Destin, FL
    I found this on Amazon and might put it on my Mike's Dowpipes.
    Heatshield Products 110614 Inferno Shield 6" x 14" Aluminum Heat Shield https://www.amazon.com/dp/B002UPL61U..._wXsaDbK4R8E5Z
    Sep 07 2010
    Belgium
    Quote Originally Posted by The Infiltrator View Post
    It appears to be just alu (flexible) shield without insulation...not sure if that will help much. I think that product is more designed to reflect heat instead of keeping heat inside....you better of with what i used also from Heatshield but the armor shield that comes with insulation (uhu more expensive but on ebay often deals...buy 3 pay for 2 etc).
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by Dasquade View Post
    Click the link and look at it again. It's insulated and is meant to wrap. Even has a video, crappy video but still shows it.
    Aug 16 2017
    Chattanooga
    If I ever decide to swap my Milltek DP's I'm going to get Mike's and will have them Jet Hot coated. They coat the inside and out and it will not tarnish or change color.
    Feb 25 2015
    Phoenix
    Quote Originally Posted by MolonLabe300 View Post
    I’ve had a few sets exhaust components Jet Hot coated over the years and unless they’ve improved something or you choose flat black, it definitely looses its color and the finish turns dull.
    I’ve also seen first hand how exhaust components can fail with wraps. Many people think it’s because salt/water gets trapped by the wrap and causes the metal to corrode but it’s actually a process called hydrogen embrittlement. The metal is forced to retain more heat than it can handle and it disintegrates as if it had been rusting for decades. The parts just crumbled away as the wrap was removed. It doesn’t usually happen with good stainless steel but I’d be careful around any lesser metals.
    Aug 16 2017
    Chattanooga
    Quote Originally Posted by Chiromikey View Post
    They now have 3 tiers of coating options. Back in the 90's I had some headers coated for my Mustang build. I never noticed a color change but, it was not a turbo car so maybe the coating wasn't pushed to it's operating limits.
    Aug 08 2018
    New Hampshire
    Sent my downpipes off to Jet-Hot for the 2500F high temp version of their coating, should have them back end of the month, will let you guys know what I think once they’re on the car. May wrap them as well...not sure yet.
    Aug 08 2018
    New Hampshire
    Oooh, purdy 🤤
    Sep 09 2010
    Destin, FL
    So glad this popped up again. I ended up wrapping the top parts of the pipe right off of the turbos. The CAT's didn't have any melting around it or the piping after the CAT's. But for the short time I didn't have them wrapped you can see that the piping off of the turbos melted the heat shielding. Holy hell!!
    I had to take some of the bay apart again to wrap the top portions for now and seems to be good. I'll wrap the bottom half soon here but damn. Wrap your pipes people, it's hot in that bay! And no, nothing was touching and had plenty of space so I'm not sure how this happened and I haven't seen anyone else with this issue that didn't wrap them.
    Wrap I bought:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Aug 08 2018
    New Hampshire
    Thanks for the pics Infiltrator, I’m gonna wrap the top section of my downpipes over the ceramic coating with the same stuff you used, anything to keep heat out of the engine bay!
    May 20 2010
    If you have not thought about it, you should also look into getting the exhaust side of the turbo (turbine housing & flanges) coated as well.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Aug 08 2018
    New Hampshire
    That would mean I couldn’t drive the car for a while, unless I bought spare housings and had them coated. Seems like too much hassle.
    Belt and braces on the downpipes:
    Sep 07 2010
    Belgium
    I kinda dought just coating the hot side of turbos would give you that much benefit over the hassle. Wrapping them with tape isn't realy an option....i went for wrapping thrm with isulated heat shield and helps a lot especially with the manifold done aswell...still things get hot down there. Maybe one day i explore a more heat extraction way to keep the bay cooler.
    Mar 26 2010
    US
    One could add hood heat extractors as was done on the Dodge Hellcat to reduce underhood heat, but it does not look very nice.
    BMW M3 Competition X-drive
    Aug 16 2017
    Chattanooga
    Be sure to run a tap through all the threads to clean out any of the coating out of the 02 bungs and anywhere else has threads. I learned the hard way that it will save time later if you do.
    May 20 2010
    Hassle is relative for everyone. I mean, if OP's (or anyone else's) turbos go because of oil starvation, sounds like a great time to do it. Or if a non-RS7 owner decides to throw RS7 (or other) turbos on.
    Aug 08 2018
    New Hampshire
    Thanks for the tip, we did that and they went on pretty easy. Holy crap they make quite a bit of difference to how the car sounds.
