Results 1 to 6 of 6
    Jun 16 2018
    nh
    3.0 Waterpump Replacement
    My waterpump is leaking fluid so I have to replace it. Rather than go to Audi and spend $700 I'd rather do it myself.
    Someone on a FB group said you can do it easily without removing the bumper if you had a few specialty tools. I inquired but he never got back to me. Does anyone know what these tools would be? Thank you!
    TL:DR - What tools make changing the water pump simple?
    Nov 03 2010
    2019 Audi A5 Sportback, 1986 MB 560SL
    Fallbrook, CA
    Deleted; wrote about wrong series engine.
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Try this thread from the S4 forum
    https://www.audizine.com/forum/showt...Removed-(Pics)
    I know you asked about tools and i thought that was in that thread but it looks like it’s just the steps. I am guessing a set of triple squares might be needed. Those seem to be specific to the Germans
    Veteran Member Three Rings AudiC7Owners's Avatar
    Jan 14 2016
    Wilmington, NC
    Kwikstix DIY Video Thread
    //2013 A6 Prestige 3.0T |IE Stage 2 Single Pulley | Berk TCU Tune | Injen Intake | Cende Valvetronic Full Exhaust | Gutted OEM Catalytic Converters | Merc Racing HX | H&R Sport Springs | 034 Motorsports Control Arms & Engine Mounts | Eurocode Drivetrain Mount Inserts | Eurocode Front & Rear Sway Bars + End Links | P3 Multi Gauge | StoneCarbon2009 RS Style Grille //
    Jun 16 2018
    nh
    The supercharger really has to come off?
    Jan 14 2016
    Wilmington, NC
    Quote Originally Posted by Prlme View Post
    Yes. and while you are in there you should do a full tune up:
    -Temp Sensor
    -Thermostat
    -PCV
    -Water Pump
    -Valve Cleaning
    -Supercharger oil change
    Then you won't need to mess with it again. Make sure the shop checks the PCV lines going to the PCV as well.
