Skipping a lot of the prelude to this query....
I started up my car after doing a major service including the timing belt and cam chains. It ran like hot garbage for a minute until the ECU sorted everything out and then it ran beautifully for about 10 minutes. I turned it off and restarted it twice after which it ran and idled beautifully.
While I was letting it idle after the second restart, it just shut down like I had turned off the key. I checked but there were no codes. I poked around for a minute to make sure som,ething hadnt come unplugged then tried starting it again. it turned over vigorously but wouldn't start. After cranking on it a little bit I finally pulled a P0343 "Cam position sensor Circuit High".
Just to give it a whirl I put the Cam position sensor out of my failed motor in and got a p0342 "Cam Position Sensor circuit low".
I had a brand new CPS that I installed and still get the P0343 code. I get this regardless of if the sensor is plugged in. I double checked my timing belt and it isn't off, and I am quite certain my timing chains are on correctly as well, because the first time I tried this job I Installed them one tooth off and was getting codes about "too advanced"
I visually checked and then checked the resistance of the wiring to make sure the wiring was good and so far as I can tell the wiring is fine.
This is driving me insane. Is there something I am not considering or don't understand about this system?
