Looking to stir up some discussion regarding 034's recent live q&a mentioning a new hardware upgrade yielding 30whp. Something in the fluid dynamics realm perhaps?
2015 Q5 3.0T S-Line | Glacier White |10.96 @ 126mph ! | 034 Stage 2+ E40 octane tune | Fluid Damper Crank Pulley 200mm / Griptech 60mm SC Pulley | Jokers Ported blower with APR UC TB | BG SQ5-HPT TCU tune| Snow WMI injection kit 400cc @ TB, 300cc @ BPV | Merc Racing C7 HX / CWA 100-3 pump 100% DC | APR open intake W/carbon UC pipe | Vogtland Springs | Nuespeed RS102 20/9.5/et25 rims |
2011 6MT PHANTOM BLACK PEARL, 034 STAGE 2+ WMI 034 INTAKE 034 MOTORSPORT ENGINE MOUNTS 034 DRIVETRAIN MOUNTS BILSTEIN B8 SHOCKS 034 STRUT MOUNTS H&R SPORT SPRINGS CTS HX CTS CATBACK EXHAUST CAP TEST PIPES CAP V2 CARBON DIFFUSER CAP HIGH KICK CARBON SPOILER iABED THROTTLE BODY JXB SS INSTA: @613_B8S4
1995 camaro with taurus SHO engine
2001 audi a8 gutted because race car
2009 chevy express 2500 duramax built 4L85E trans and tuned for around 400hp
2014 Audi S8
2015 Audi A6 2.0T
2013 Audi RS5
2018 Audi RS3
2015 White S4/Lowered/034 CAI/034 STG 2 Tune/034 Upper & Lower Crank pulleys/19" Peelers/Black Leather with brown inserts/full CF inlays/Full LED interior lights/ Prem+
1999 A4 Avant | Cactus
2001 S4 | Silver | 6MT
2021 Porsche Macan Turbo | Carrara White
Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
°2011 A4 | 6MT
Pauter 4340 Chromoly Cross-Beam Connecting Rod Set Pauter 153/22 4340 Chrome Moly Cross-Beam Connecting Rod Set is designed and engineered for Audi EA837 3.0T Supercharged Engines. Forged from 4340 Chrome Moly, their unique cross beam design rod structure has proven extremely strong and reliable. Sold as a set of six, balanced end-to-end, ready to install. |
Wagner Tuning Pro Series Main Stud Set The Wagner Tuning Pro Series 18.8 Cylinder Main Stud Set is designed to replace the original main studs with high-strength Pro-Series 18.8 studs. This upgrade is necessary when making large increases in power and engine performance, such as higher boost levels beyond what the factory hardware is designed for. |
034Motorsport MLS (Multi-Layer Steel) Head Gasket Set If you’re looking to maximize power and reliability from the 3.0TFSI, the 034Motorsport MLS (Multi-Layer Steel) Head Gasket Set is an optimal upgrade over the factory head gasket. The 034Motorsport MLS Head Gasket Set utilizes 4 layers of coated steel that ensure a strong seal between the engine block and cylinder heads, and is designed for high boost and high-stress applications, perfectly suited for B8 3.0T Stage 2 and beyond. |
Wagner Tuning Pro Series Head Stud Set The Wagner Tuning Pro Series 18.8 Cylinder Head Stud Set is designed to replace the original cylinder head studs with high-strength Pro-Series 18.8 studs. This upgrade is necessary when making large increases in power and engine performance, such as higher boost levels beyond what the factory hardware is designed for. |
2014 Q5 3.0T S-Line | Glacier Grey |034 Stage 2+ 93 octane tune | CTS Crank Pulley 192mm / APR SC Pulley 57.75 | BG HPT ZF8 Tune | 2 CWA-50 pump / Custom HX + custom reservoir (Divorced Coolant Loop) | K&N filter/mod stock box intake /4" Intake Tube/ TB 84mm | 034 HPFP piston | Long tube headers/custom exhaust 2,5" | tires 265/45/20 |
