Results 1 to 25 of 25
    Account Terminated Four Rings
    Oct 15 2013
    Ramps for oil changes
    I'm planning on using four ramps to do oil changes. Do ramps provide enough clearance? What do you do? Of course a proper car lift is out of the budget.
    May 20 2010
    Ramps for the front should be sufficient. I have Rhino Ramps and they provide more than enough clearance, imho. Additionally, since the oil drain plug faces the rear, I would be inclined to think rear-angled would help drain more old oil out.
    If it were Tiptronic fluid change, I'd agree with 4 ramps (still unsure how you'd get there though) or jackstands.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Oct 15 2013
    These ones look good and provide 7" lift...
    https://www.summitracing.com/parts/bti-rr-40
    Veteran Member Three Rings griga's Avatar
    Jun 30 2017
    Central Jersey
    I use whatever ramps harbor freight sells and they work fine
    Silver 2008 A4 2.0T | Thermal R&D Exhaust | Cupra R Lip | 034 Mounts | Peelers w/ Spacers | Custom Intake | Paint Matched Reflectors | B5 Perches |
    IG: https://www.instagram.com/rigadesigns/
    Apr 04 2012
    Calgary/ Alberta/ Canada
    I just reach under the car and undo the plug? If it’s not lowered you have plenty of room
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Race Ramps
    2019 SQ5 Prestige
    Oct 15 2013
    Quote Originally Posted by Redryuu View Post
    What about the filter?
    Oct 15 2013
    Quote Originally Posted by texasboy21 View Post
    Race Ramps
    Does the oil drain out well enough with just the front end ramped up? I thought the car had to be level to drain the oil out completely.
    If it does need to be level, I wonder if the car has enough clearance for the ramp to fit between the front and back wheel.
    I would have to back my car up to my level garage because the driveway is sloped.
    Apr 04 2012
    Quote Originally Posted by esandes View Post
    I go from the top with the 2.0t
    Oct 15 2013
    The b7 filters are down low.
    Oct 15 2013
    Or can they be reached from the top?
    Apr 04 2012
    They can be reached from the top
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    I do mine from the top too and drop it into a thick plastic bag.
    Ramps are on sale at Napa this month, the Sceptre ones work fine and give enough height. 51.99 unless you can score something cheaper.
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    Apr 04 2012
    Quote Originally Posted by Jay-Bee View Post
    Plastic bag!!!! That’s a great idea. I’ve just been letting it dump and hoped I caught most of it haha
    Feb 15 2016
    Cambridge,Ontario
    i have 4 rhino ramps .. they go great under all 4 wheels of the van and i just drive up and can do undercarriage work no problem .
    they wont go under the back wheels of my b7 . Not nearly enough clearance.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Aug 04 2015
    Kansas City
    Two ramps up front work great for me. Socket with extension to initially loosen the filter from below, then I unscrew it and remove it from above. I’m not aware of any way to get the car on four ramps due to lack of rear clearance. I always use wheel chocks and jack stands too, just in case.
    Veteran Member Three Rings texadelphia's Avatar
    Jul 05 2016
    2008 A4 Avant 2.0T Tiptronic
    Quote Originally Posted by KJack View Post
    I've considered either buying 4 ramps, or 2 ramps and 2 wheel cribs and driving onto the front ramps and then jacking up the rear and setting the wheel cribs or second set of ramps under each tire. lotus-on-car-ramps-and-jack-stands.jpeg
    Sent from my moto x4 using Audizine mobile app
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by texadelphia View Post
    that will definitely work , but i have wondered the effects of jacking one side at a time to get the back end up with the front so far off the ground. I think last time i did that i put i piece of 2 by 8 under the rear diff and jacked the whole back .... Not sure about this method though as i fear a great cracking sound coming from the rear diff.
    1976 Yamaha XS 360
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    x2. I dont even remove my skid plate to do oil change.
    The '' filter housing oil drain tool'' is the way to go to not spill oil on the skid/floor.
    Aug 04 2015
    Kansas City
    Quote Originally Posted by oVeRdOsE View Post
    Agree 100%. I got mine on Ebay for less than $20. It’s a great tool.
    Veteran Member Three Rings Ray1031's Avatar
    Nov 01 2015
    San Antonio, TX
    The plastic bag works and i've also cut a milk container in half and get it under the filter to catch the oil as I remove the filter and it works great. No spills anywhere.
    May 15 2019
    2007 Mercedes C230 Sport, 2006 Chrsler Serbring, 2006 Volvo S60 2.5T, 2006 A4 Quattro 2.0T
    Bellevue, WA
    you might not believe me but my car had no bellypan, I can easily remove oil pan bolt and oil filter without any lift or jack. I have enough clearance to poke my face under the car feeling extremely safe.
    May 15 2019
    Bellevue, WA
    I like those wheels, where did you get those wheels from?
    Jul 01 2015
    Mtl
    Quote Originally Posted by Jeevan View Post
    need a drop yo
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    Quote Originally Posted by Ray1031 View Post
    Washer fluid bottles work great for this too. Cut it in half but leave a long section that goes between the engine and filter housing to act as a shield.
    You can usually snake the bottle in there if you move your coolant reservoir out of the way.
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
