Results 1 to 8 of 8
    May 29 2019
    1988 Ford Sierra Sapphire RS Cosworth
    Bucks/UK
    1.8T "cold start" problem
    So I'm nearly 12 months into my first A4. It's my second best dream Audi...there weren't any RS4s for £500 at the time but fell in love with the B6 and after driving a Seat Cupra for several years love the 1.8T 20v engine
    For £500 I knew I this 1.8T (163) B6 was going to be a bit of a fixer upper but it was solid, un-bent, largely untampered with, and had 9 months of (apparently questionable) MOT left on it.
    The problems I knew about when I bought it were:
    • "A weird cold start problem"
    • various buttons and switches worn down
    The problems I found when I got home (and since) were:
    • The same "weird cold start problem"
    • NS rear window winder handle broken
    • Rear OS window doesn't move
    • Electric window switches sticky/intermittent
    • Driver's seat back hanging off
    • Front doors don't always shut properly
    • Brakes all close to legal limit
    • Poss loose front exhaust heat shield
    • Air con needs regassing
    • Heater doesn't offer heat
    • Radio reception's become very poor
    • Glove box lamp doesn't work
    With my Fisher-Price toolkit I've fixed:
    • Failed water pump (never want to do this job again!)
    • Failed battery
    • Air bag light (driver's upper igniter wiring)
    • Recirculation flap stuck
    • Refitted several relays that had worked loose
    • Replaced thermostat & housing
    The rest is on the to do list but the "cold start" problem is the biggest one that needs dealing with. I'm not new to fixing my own car (20+ years with an old Ford have helped cut my teeth on running problems, EFI, engine building, auto electrics etc) but the "cold start" problem has me completely stumped, but I'd sooner do it myself than spend £hundreds getting someone else to check it and fail to work it out so any bright ideas will be welcome!
    Symptoms are: failing to start after being left for more than roughly 40-60 minutes - turns over but doesn't fire, may occasionally catch one or two strokes but will stall, almost like a timing fault or fuel supply problem. It may, after repeated attempts and temporary disconnection/reconnection of fuel injectors start eventually but it'll be rough for a short time then run perfectly fine after it's burned off whatever's in there. It has taken up to 20 minutes to get it going on some occasions and on two occasions flattened the battery.
    The seller said "Sometimes it'll be really hard to start from cold. But if you drive it after it's started and come back to it when it's warm it'll start first time". Off that, my initial thought was a simple coolant temp sensor ruining the cold start mixture. Nope - replaced this with a new sensor and still behaved the same.
    The car had very little history with it so I started from scratch and assumed nothing had been done with it.
    Completed stuff that's made no difference:
    Replaced Coolant temp sensor (rear of head)
    Replaced Crank position sensor
    Replaced Spark plugs
    Vacuum test - OK
    Starting with TPS, MAF, CTS and ACT disconnected
    Currently the only way I've found to 'manage' this is to relieve the coolant pressure (I know, bear with me) when I've pulled up after a decent drive - if I do this every time, it'll start again first time. If I forget, it'll revert to previous behaviour. I've had a sniff test done on the coolant which was negative, so I think that rules out a failed head gasket or cracked head/water jacket - my thinking was that if there was a failure there, coolant may have been drawn into the cylinders after a time, causing it to fill up and make a non combustible mixture, but is it safe to rule this out based on a sniff test? I just can't see how relieving coolant pressure can affect anything else.
    The other 'element' that I think is related, is the heater not doing much in the way of heating (although if you have no fans on for a while, some heat will come out briefly), the radiator fan doesn't seem to run when it should, and the bottom hose from the thermostat housing to the rad is generally a lot cooler than I'd expect it to be despite bleeding the system several times. A while back the water pump failed, so I replaced the pump, timing belt, and 'just in case' replaced the thermostat and its housing, so everything there should be in order.
    Next to replace is the radiator and possibly the heater matrix to rule out any blockages that may be causing excess pressure but any input is welcome!
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    You might try posting in the A4 forum.
    Old Geezer, formerly known as Stud Muffin
    Nov 03 2011
    All Over!
    Quote Originally Posted by QIKRNU View Post
    True. But a fuel issue remains a fuel issue, regardless of the engine type. You could still help the poster, if you wanted to.
    @ Chris: It’s possible you have a leaking, or sticking injector. Start by pulling the fuel rail, and check the spray patterns (clear bottles for each injector). Post results, and we’ll take things from there.
    1986 Type 85 Audi 90 quattro
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    Quote Originally Posted by cosworthchris View Post
    This sounds exactly like my leaking injector I had on my Allroad, I literally replaced anything fuel related, ended up needing to have the injector replaced, what it is doing is it is leaking into the cylinder, so when you attempt to start it it takes a longer time until it actually fires up and then works fine for the interim, that is is until you stop and let it sit for a bit, during that time fuel is dripping into the cylinder again and not letting it ignite correctly. mine was a pain in the arse because it didn't throw any codes or misfires. once it the car actually started it was fine... you can get some relatively inexpensive injectors on ebay, or on the forums for your car. hope that helps.
    Jun 18 2010
    East of Cincinnati
    If it's an injector problem, try www.mrinjector.us. Good stuff at reasonable prices.
    Veteran Member Four Rings Gosser's Avatar
    Jun 05 2013
    2005 A4 1.8QMT, 2006 3.2 Sedan and Wagon auto, 2004 S4, 1990 300zx TTRHD, 1988 Buick Lesabre T-Type
    Ottawa
    I agree on the injector front. 1.8t injectors are dime a dozen in the junk yards, I would just grab a set from there and get them rebuilt to save down time.
    I know my 3.2 is GDI, but I has the same cold start problem. I replaced everything, hpfp, filter, sensors, intake, thermostat/sensor, cam phase sensors, vvts, crank sensor, ecu/cluster... turned out it was two leaky injectors.
    Smell your oil, mine reeked of fuel. Now it doesnt.
    2007 RS4 Avant
    2006 A4 2.7 MT Avant
    2007 A4 2.0 AT Avant
    2013 Q5 3.0 AT - Wifes
    Oct 05 2015
    Billings, MT
    Couple videos of how to check and clean injectors if you go this route.
    Oct 05 2015
    Billings, MT
    any resolution or updates?
