    Jul 30 2018
    Lafayette la
    Car randomly dies while driving
    So I just finished driving my car from Louisiana to Colorado and I kept having a weird issue where the car would randomly die while driving and then wouldn’t start again. If I’d wait about five minutes and try again it would start right up and drive just fine.
    Could this be the crank sensor or one of the cam sensors?
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    If it’s a crank sensor you will have a fault stored in the ecu for the crank sensor so first step would be to check the ecu fault memory. Sounds like it could be your fuel pump overheating at times causing fuel pressure to drop and the engine to stall. Does it crank but not start when this happens?
    Jul 30 2018
    Lafayette la
    Quote Originally Posted by Corradovolksb View Post
    Yeah it cranks but doesn’t start. If I wait about 5 minutes it starts right up
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    Ok. Check the ecu fault memory fist and see it any faults are stored. If not you can install a fuel pressure gauge and monitor fuel pressure and see if it drops when the engine dies. If it does it almost always a fuel pump but it could be the fuel pump relay.
    Veteran Member Four Rings JustManson's Avatar
    Oct 11 2016
    Connecticut
    ^ do that.
    A fuel pump swap if it is bad is easier than you can imagine.
