found out that Audi's new software does in fact check for how many times an ECU is flashed. Regardless of what tune, if you flash the tune on or off, they will see the amount of flashes on the ECu, it will now get flagged as TD1 as I understand and no way to prevent this. From there, as I was told, your car is TD1, but, if they dont see a tune your car, the TD1 goes to a TD1 deactive status, so they know it was flashed, but TD1 is not active on the car, but again, ita flagged as TD1 deactive.
Not sure what this could mean if an issue arises if youre in "deactive" status, but thought I'd share this. I wouldn't let this stray from a tune, but if you are going APR, id recommend their "plus" option to cover the powertrain that the TD1 may void. just understand the risk vs reward (my tune stayed, no way i am going back!)
sorry if this is common knowledge, but I did confirm this to be the case and wanted to share.
