Results 1 to 28 of 28
    Mar 14 2014
    North Texas
    AC Help - system won't charge
    I have the ECON button won't go off problem. I replaced the pressure switch by the headlight. Fuses 1 and 6 are fine.
    Using a rented vacuum pump and gauges. The system held vacuum for at least 30 minutes. Trying to fill from the low side it seems it will not take freon into the system.
    The compressor will not come on to draw anything in. If I start the car and turn on climate control the econ light stays off for a few seconds. Then I can feel the compressor kick on for maybe 2 seconds. Then the econ light comes back on.
    Any ideas?
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    Do you have a set of pressure gauges on the high side and the low side?
    Mar 14 2014
    North Texas
    Quote Originally Posted by Kevin C View Post
    Yes. The low side was up around 90. The high side wasnt getting about 55 or so.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    That sounds like you have a clogged restrictor valve. Clicky click®
    Mar 14 2014
    North Texas
    awesome thanks. In your clicky what do you mean by clean the system? Can I replace the restrictor valve and vacuum the system again, then charge? Or is there something else?
    Dec 28 2006
    Western Maryland
    I would start with just checking/ replacing the restrictor valve and going from there with a vacuum and recharge.
    Mar 14 2014
    North Texas
    Swapped it out. Vacuumed. Recharge. Same results. What's next?
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by 5spdJunkie View Post
    What is your high/low static gauge readings? What happens when you then engage the compressor? Is the low side still reading higher than the high side?
    Jan 24 2010
    Paramus,NJ USA
    If the restrictor valve had alot of gray/metalish residue in it chance are it needs a compressor. However lets not assume anything yet. I would check compressor function first. Look at mvb 001 in 08 ac climate control head. It would show you current and duty cycle of compressor.Also scan for faults while your there. Normal operation of compressor should show around .6amps and a duty cycle of 64% showing a pressure of about 20bar in circuit. ECON light that wount turn off is normally because the system is empty and has less than 0.20kg of freon in it. IIRC thats the threshold for minimum operation.Normally on these cars charging is either done with a dedicated ac machine.Also the ac system needs to be put in a vacuum in order for it to draw or pull the freon into the system. You need to make sure you dont have any air in the supply hose coming from the refrigerant source your using to recharge the system.
    Ziddy Autowerks
    Mar 14 2014
    North Texas
    I can't get the compressor to engage. The ECON light just stays on the whole time.
    Low side about 90psi
    High side about 75psi
    I don't have a vag com so I can't scan for faults.
    Jan 24 2010
    Paramus,NJ USA
    They look almost even. It is possible you need a compressor but I cant rule that out without further checks.
    Ziddy Autowerks
    Mar 14 2014
    North Texas
    Quote Originally Posted by EuroxS4 View Post
    I definitely didn't do this. I dont see how I could with my setup. I vacuumed the system. Let it sit for half an hour. Then I disconnected the vacuum pump hose and hooked that up to my refrigerant can.
    Mar 14 2014
    North Texas
    I've ordered an OBDeleven tool and it'll be here tonight. Do you know how I need to scan using that tool?
    Mar 28 2015
    To add to the conversation. The compressor has a variable displacement it goes from close to no pumping to full depending on a pwm signal from the control unit. To get it to charge you need enough initial pressure to set turn off the low pressure switches and a signal to the compressor. You can add charge if you have air in the system but the results will be poor. Air and moisture reduce efficiency and the moisture will cause acids to form and kill the system ( I know your vacuuming system, this is for others that might not know).
    The sign of a pumping system is that the pump has a low enough pressure on the inlet side to draw from the can and you have a high pressure on the outlet. The scanner will help tell you if the pump is getting a signal or not. If it is and you have no pressure then the pump is suspect. As you get to the point where the system is taking a charge the cans of refrigerant will get cold and their pressure will drop. To keep things going you need to keep the cans in a pan of warm water.
    As others have pointed out the first thing is to find out why the system is not pumping. A quick reality check it to compare the gauges with the car off, both valves open and the can valve shut. They should read the same pressure. Use that reading as a baseline to see what the pump is doing. It's not uncommon for the gauges themselves to be off by 5 to 10 psi. Use the off pressures to make sure your not just seeing a pressure based on the gauges not being accurate.
    Veteran Member Three Rings john_gonzo's Avatar
    Feb 03 2009
    Florida
    5spdJunkie, have you verified the compressor is turning? The compressor pulley turns all the time. The center of the pulley should also be turning all the time. The center of the pulley is attached to the compressor shaft with a coupler. When the compressor goes bad (requires high torque), the coupler shears. When that happens, the center of the pulley no longer turns while the belt is driving the outer part of the pulley.
    Mar 14 2014
    North Texas
    Got some codes
    Trouble codes:
    00710 - Defroster flap motor locked or has no voltage supply
    Passive
    00819 - High pressure sensor Signal too low
    Passive
    00819 - High pressure sensor Signal outside tolerance
    Passive
    Measuring AC block 001
    (N280) 0 current
    (N280) 0% duty cycle
    High pressure signal(g65) - 95%
    Refrisgerant circuit pressure 33 bar
    Mar 14 2014
    North Texas
    Anything else to look at based on those codes?
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Your codes look like they're conflicting with the actual data. Can you clear them and see what comes back?
    Sent from my Pixel 3 XL
    Mar 14 2014
    North Texas
    I cleared the codes and 819 came back immediately. How are they in conflict?
    Aug 12 2009
    Dirty Jerz
    Signal too low code but it is showing 95% without the system running?
    Mar 14 2014
    North Texas
    What would cause N280 duty cycle to be 0% ?
    Mar 14 2014
    North Texas
    Anyone? I don't understand what this duty cycle value means or what drives it
    I'm about to do timing belt and I'm thinking about doing a compressor/drier while I'm in there.
    Nov 03 2010
    2019 Audi A5 Sportback, 1986 MB 560SL
    Fallbrook, CA
    (N280) 0 current
    Your pressure reads 33 Bar? That's like 480 PSI, which sounds awfully high to me. That's engine running? Maybe a blocked expansion orifice? I think that you need to go to AutoZone or wherever to borrow a gauge set, and confirm that pressure.
    Is the N280 the control valve for the compressor? Duty cycle typically means time ON vs. Time OFF, so I would assume that 0% duty cycle means the control valve is not turning ON, therefore not allowing the compressor pistons to move in their cylinders. And that may be due to the high-pressure sensor signal being maxed out. You might try letting some refrigerant out to see if that sensor lets the compressor run.
    Nov 03 2011
    All Over!
    Personally, I always leave air con recharging to the experts.
    It’s a specialist job, which requires specific tools, and pre-charge procedures which may be outside the scope / capabilities of a basic charge-from-a-can setup.
    1986 Type 85 Audi 90 quattro
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    Your G65 sensor or the wiring to it is broken, (the one you replaced). ECU won't turn on AC if its getting crazy results.
    You sure you plugged it in after you changed it? no damaged wiring?
    Veteran Member Four Rings RENOxDECEPTION's Avatar
    Nov 04 2012
    2000 B5 A4 1.8TQM, 2000 B5 A4 1.8TQM
    Reno
    Just charged a b6 yesterday that was being problematic only accepting 5oz of refrigerant, and if you have the same pressure in both the high and low side (mine was charging to 80psi and no further), I had a spare high-pressure switch on hand, as soon as I swapped in the new one, the compressor started and high side started actually pressurizing, accepting more low side refrigerant (to a total of 17oz).
    about the duty cycle, since the B6 uses a swashplate style compressor (as opposed to compressors with clutches), it controls the angle of the swashplate using a pwm solenoid rather than simple on/off operation of a clutch. the benefit is that it can infinitely vary the load the engine and a/c compressor are under for better efficiency.
    Nice little gif for fun:
    the solenoid would vary the angle of the plate and the center shaft.
    2000 Audi A4 B5 1.8TQM AEB/06A
    1998 Audi A4 B5 4.2QM (Thread)
    2000 Audi A4 B5 1.8TQM K24 Turbo, AEB Wideband
    Mar 14 2014
    North Texas
    Quote Originally Posted by 5ktq View Post
    I'm sure I plugged it in but not sure the wiring isnt damaged. How would I check?
    Nov 03 2010
    Fallbrook, CA
    I just had a new Sankyo compressor and expansion orifice installed in my A4, which had been without AC for about a year. The swashplate variable-stroke arrangement shown above is key to the system working with only a simple orifice, to discharge liquid refrigerant into the evaporator as a cold gas. The pressure difference between the high and low sides is controlled by varying the compressor's displacement. It's nice to have cold air again!
