Results 1 to 22 of 22
    Senior Member Two Rings A4s-line's Avatar
    Mar 18 2009
    2015 S3, 2018 SQ5
    Cleveland, Ohio
    SQ5 265/35/21’s
    Hey everyone,
    I am looking to get new 21inch wheels and I’ve currently selected a 265/35/21 vs a 265/40/21 or the stock 255/40/21. Anyone have this setup on a car or have an opinion of what to expect?
    Thanks
    Senior Member Two Rings Blkdoutv's Avatar
    May 25 2018
    2017 RS7 Performance 2018 SQ5 2016 A3 2.0T
    Texas
    Just bought some 265/35/21’s the other day to replace the stock tires. I’ll post pics when I get them on.
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    You'll get:
    Better handling (rougher ride)
    More torque (lower mileage)
    Less un-sprung weight (more wheel-well gap)
    After your odometer shows you've driven 10K miles on them, know you'll have only gotten 9.7K (~2.5%) of actual driving. That's unnecessary depreciation.
    If you're getting new wheels, get 21x9.5 with 285/35. That will get you back to the right RPM's, look good both on the wheel and on the car without poke, and provide much better grip. Check out the Wheel and Tire thread. Just today there are new pics of that exact size wheel and tire and it looks spot-on with the gen.2.
    Mar 18 2009
    2015 S3, 2018 SQ5
    Cleveland, Ohio
    I was worried about more wheel gap but from some online tools it looks very minimal. Not sure if it’s better to loose out on mileage or pay extra for tires :)
    Apr 26 2014
    DFW
    IMHO. . .they put smaller tires on at the factory than what they were designed for. It saves them a ton of $$ and helps wind out that warranty a little quicker. That's a win-win for them. On the stock wheels, 265's fit the wheel better, look better, handle better, and the speedometer is more accurate. Just sayin'...
    Mar 18 2009
    2015 S3, 2018 SQ5
    Cleveland, Ohio
    But you mean 265/40/21?
    Apr 23 2013
    Tulsa
    Do 285s fit on these wheels? There's not many options in/around the factory tire size but stepping up to 285 and 295 yields many more good All-Season options
    Mar 18 2009
    2015 S3, 2018 SQ5
    Cleveland, Ohio
    They are 29x9 so probably not
    - - - Updated - - -
    Sorry 21x9
    Apr 23 2013
    Tulsa
    Yeah that's pretty narrow for a 285. I think my Vette has 285s on the front and it's on a 9.5 inch wheel.
    Quote Originally Posted by A4s-line View Post
    - - - Updated - - -
    Sorry 21x9
    Mar 18 2009
    2015 S3, 2018 SQ5
    Cleveland, Ohio
    Just got these installed.
    265/40/21 looks like 40's are good:)IMG_0928.jpg
    Veteran Member Four Rings BG SQ5's Avatar
    Feb 21 2016
    '07 CBR1000RR
    PA
    SQ5 265/35/21’s
    Most definitely 40s are the way to good. 265/35r21 shouldn’t even be in the discussion.
    '15 SQ5 Daytona Gray
    APR stage 2 104 oct (e40) - BG TCU (via HPT) - CTS s/c & FD 187 crank - Autotech HPFP - aFe filter/034 tube/modified box - MercRacing h/x - AWE Touring
    21" Forgestar CF10s w/295s - KW Street Comforts - 034 mounts, RSB & end links - ecodes - deAuto LEDs - P3 w/ECA - VCDS
    11.340 @ 120.63 (673 DA) - street trim
    11.012 @ 124.22 (-1346 DA) - track trim
    Instagram: @bg.sq5
    May 06 2015
    Minnesota
    Currently running 265/40/21 on our SQ5. Fitment is perfect.
    2013 Estoril Blue S4 - gone but not forgotten
    2014 SQ5 - gone but not forgotten
    2015 Mini Cooper S
    2021 Hyundai Santa Fe
    Mar 29 2019
    So Cal
    What brand/model tires are people going with in 265/40/21? I have the OEM SQ5 wheels and am looking to move up to 265/40/21 next time around. Live in SoCal so I don't need all season tires. Just a good summer tire with low road noise, ideally.
    2014 Audi SQ5
    EPL Stage I ECU | 034 Silicone Intake | AFe Dry Pro Filter w/ Airbox Mod | Snow Screen Removed
    EPL TCU upgrade | 034 Transmission Mount Insert | Supreme 15mm/20mm spacers
    Hoen H11 Fogs | DeAutoLED Interiors & Reverse Lights | OEM Q5 Rubber Floor Mats | Armrest Organizer
    Mar 18 2009
    2015 S3, 2018 SQ5
    Cleveland, Ohio
    I bought P p-zero's and so far I like, granted it's only been a couple of days. Are OEM's 21x9? I thought they were 8.5 if so you might be limited with 255's but not 100% sure about that.
    Mar 29 2019
    So Cal
    They are 8.5s but people have been able to run 265s apparently
    2014 Audi SQ5
    Mar 18 2009
    2015 S3, 2018 SQ5
    Cleveland, Ohio
    Looks like the P-zero's will run off of 8.5, see the link but I also think it's tire specific.
    https://www.discounttire.com/buy-tires/pirelli-p-zero
    Senior Member Three Rings QwertyD's Avatar
    Oct 04 2017
    United States
    You'll be able to fit 265.40.21 on the stock 21 rims even though its 8.5 inch wide. Itll be a little tight but I run spacers with it so itll be no problem
    Sent from my SM-G975U using Audizine mobile app
    AKA: Dhoang57
    Oct 04 2017
    United States
    Its beefier with the 265's and looks better in my opinion.
    AKA: Dhoang57
    Nov 25 2014
    Alabama
    Reviving... Are spacers required running 265/40 21 on stock wheels or will they fit with no rubbing? If required what size spacers f/r is minimum?
    Sent from my SM-G955U using Audizine mobile app
    2018 SQ5 | Monsoon Gray | Prestige
    Oct 04 2017
    United States
    Spacers are not required for 265.40.21 but itll be a little tight. I run 15 front and 20 rear spacers on my 265.40.21 pilot sport.
    AKA: Dhoang57
    Veteran Member Three Rings 1S32K16's Avatar
    Jul 07 2016
    Quote Originally Posted by Dhoang57 View Post
    Do you have pics of your setup with the spacers? Looking to add some spacers to my recently picked up SQ5 with the 21 oem wheels and the air ride. I would run the stock pirellis for now and down the line look for bigger tires.
    2019 Quantum Gray SQ5 with black optic package, 20% Rayno Ceramic tint, TAG Motorsports Painted Front Reflectors, BMC Air Filter, JB4, 034 Trans Mount, OEM Black Badges, 21’ BC Forged RZ39, Redstar 200cel DP, ODIS factory lowering
    2016 Monsoon Gray S3 with black optic package, Emmanuele design springs, rear sway bar and endlinks, 19' Forgestar CF5's
    Nov 25 2014
    Alabama
    Thanks Dhoang! Yeah pics would be great too if you have some. I don't mind spacers, just don't want to go too big and end up with it looking like a donk.
