This car is driving me nuts! I really need some help and/or direction.
This problem started in April when I returned home from hazmat training. I noticed a stumble around 2000 rpms while driving on the freeway @ 60mph. I changed all coil packs, plugs, no change. I was thinking spark, fuel, air. No codes. I then swapped out coil packs and the problem resolved for 3 weeks. Then, a new problem with code P0341, p1338. So I swapped out my Camshaft and crankshaft position sensors. No change. Then, I swapped my bank A with bank B camshaft sensors. No change so it's not the sensor. I still got theP0341 code.
Since then, I changed my ECU to the stock ECU, no changes.
I exposed the passengers side valve train to find no obvious damage to the chain tensioners, plastic pads the chain rides on were in tact. 16 rollers between exhaust & intake with notches on the cams lining up.
I ran my VCDS Lite which did not show me much. However, I was able to look at the camshafts in relation to each other. I know that they should be the same while the engine is running. They were not in sync, different values were observed while the car was running.
I made a jumper from the bad camshaft position sensor and checked the voltage with KOEO and KOE- running. One wire was ground, one was battery power - 11.58, and the signal wire read 5v while the car was running and with key on engine off. I put my ohm tester on the signal wire with the audible beep and when the car was running, I would get an intermittent beep as the signal wire grounds momentary for the signal.
In regards to the camshaft position sensors, I followed Rollerton's advise. Unplugged bank 1 and drove it, then plugged it back in, no changes. I cleared the codes, no changes.
Then, I unplugged bankA and B Camshaft position sensors, car would not start.
I replaced the engine speed sensor/crankshaft position sensor, no change. This find is kind of interesting....
When I checked the voltage to the engine speed sensor/crankshaft position sensor, I found the ground wire, and both signal and voltage supply wires , voltage supply wire and signal wire both have 2.48v. This with Key on,engine off AND key on, engine running. I ran the Ohm meter with the audible beep when it was grounded and I got no intermittent beeping on the signal wire when the car was running.
Consequently, I'm not working right now due to rotator cuff surgery.....Which SUCKS in itself! And I just had a second surgery to my hand. Messed up thumb due to a judo injury 25 years ago. I ignored years ago which is now causing me pain, so I had the fixed. Makes it hard to type. Kids are bummed as I can't play video games for another month :( So, since I am not able to work right now, funds are tight so for now, I can not afford to purchase VCDS for me till next year when I get back to work.
I am busting my arse to get my car running. I have an F350 truck, but it's really hard to drive with a messed up L shoulder and a cast on my R arm, hence, I'm not driving for another month :(
Anyways, wondering if anyone has any thoughts how to resolve this issue my A6 is having?
My current thought is to remove both valve covers to make sure both cylinder heads camshafts are mechanically correct. Possibly could be bank A's camshaft tensioner is defective. I did test this with a test wire & I can hear it clicking...but maybe the tensioner is weak?
