Results 1 to 12 of 12
    Active Member Two Rings jtravis's Avatar
    Dec 25 2013
    2016%20GTI%206MT
    Mount Gilead, OH
    How does a tune affect Drive Select?
    About to go stage 1. 2013 6MT
    (no tuner vs. tuner talk in this thread unless it specifically pertains to Comfort vs. Dynamic modes)
    Search the forums, couldn't find the exact answer.
    Once tuned, how will the tune affect the throttle response in Comfort vs. Dynamic modes? Will Comfort mode still have less of a throttle response than Dynamic?
    I ask because it's been a rough week at work and my entire body has been moving slow in the early mornings. I normally just set and forget my Drive Select to Dynamic, but when the old muscles aren't firing fast Comfort mode is so much easier to drive first thing in the morning.
    Jul 11 2016
    2001 BMW R1200C, 2001 SeaPro w/115 OP
    Englewood FL
    Yes, comfort will still have less throttle response than dynamic. I really didn't feel tuning changed much regarding dynamic vs comfort. I've heard (and myself felt) that comfort seems especially doggy after you're tuned, but I honestly think it's more that dynamic is just way more....dynamic, so comfort feels....extra comfy
    '15 S4 | Sepang | Alu Kreuz | CR-15 | 034 DP ECU/TCU | XLR8 196.5mm | HPFP | Merc HX | 034 rear sway | 034 Full inserts | Dinan Coilovers | ECS Kohlefaser Luft-Technik |
    Dec 25 2013
    2016%20GTI%206MT
    Mount Gilead, OH
    Does a tune affect each of the Drive Select settings then? or just the Dynamic setting?
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    I can only speak from my car (6MT) and tune (Stage 2 EPL) but there was definitely no change to any of the drive select characteristics.
    Feb 01 2009
    New York
    Quote Originally Posted by jsh139 View Post
    Do you mean that changing the drive select from comfort to dynamic made no difference in response..etc? Or do you mean that it works just as it did before the tune? Comfort is softer and less responsive?
    I’ve been wondering this too!
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Quote Originally Posted by 04v8s4 View Post
    It works just as it did before. Comfort has less throttle response than Dynamic. Steering is lighter in Comfort, etc. The Individual settings still work. Nothing was changed, the car is just quicker, haha.
    Veteran Member Three Rings dimonblr's Avatar
    Oct 02 2018
    Boston
    I did not notice any changes between what Drive Select does for throttle response and steering input with the APR Stage 1 ECU tune.
    Comfort is what I keep my Drive Select in 98% of the time, and with that I still get early upshifts and comfortably soft steering. Dynamic stiffens up the steering and holds gears longer just as it did prior to flashing the ECU with an APR Stage 1 tune.
    It is my basic understanding that the Stage 1 ECU tunes from any vendor will hold the wastegate closed longer to achieve increased performance, and do not have any direct affect on the Drive Select mechanism. The TCU tune may be a different story. I do not have that and cannot speak to it.
    I don't even know what Dynamic would do for a MT S4 besides steering input stiffness.
    B8.5 S4 | B9 Q5 | IG: @dmzb8s4
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Quote Originally Posted by dimonblr View Post
    It does everything it does in a DSG car, just nothing with the shift points :)
    Apr 28 2019
    Baltimore,MD
    Doesn't the car rev match in dynamic mode on down shifts with a 6MT?
    Oct 02 2018
    Boston
    Which is one of the four things it changes. 1 - Steering, 2 - shift points, 3 - fake sound, 4 - sports diff (if available). At least that's all I have as my car isn't optioned with the adaptive suspension.
    Quote Originally Posted by JoeAWD View Post
    Really?? That would be a neat feature.
    Veteran Member Four Rings fmzip's Avatar
    Aug 21 2017
    Exactly, same here EPL Stage 2
    BMW M850i
    Feb 18 2017
    Honda RC51
    Columbia, Maryland
    6MT with Stage 2, and no change with sports diff activated or not. I almost always leave in Dynamic because it feels faster due to more RWD.
    2015 S4, IE DP tune, 3.28 SC ratio, Merc HX
