Scanning the car shows 2 errors as seen below:
I've read through similar threads, and checked the pipes are properly connected as per those threads, but still getting the error.
I did try trace the pipe further towards the left side of the car, and it seems to lead to a bulbous object. Where the pipe is securely connected, but wobbles a bit (Highlighted by red). My next step is to try seal this better with a bit of tape to test if the errors go away, but I'm curious. Is the bulbous object the SAI pump (Highlighted by orange)?
Code:
Address 01: Engine (------CEUC) Labels:. 06E-907-551-CGW.clb Part No SW: 4G0 906 014 HW: 4H0 906 014 Component: 4.0l V8TFSI / X62 0012 Revision: NCX62--- Coding: 0A2500326526010A0000 Shop #: WSC 55167 002 1048576 ASAM Dataset: EV_ECM40TFS0114G0906014 001014 ROD: EV_ECM40TFS0114G0906014.rod VCID: 5FCB1B3B46CFB2B284-800A 2 Faults Found: 7656 - Secondary Air Injection System: Bank 2 P0492 00 [101] - Insufficient Flow Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 89828 km Date: 2019.05.18 Time: 09:12:05 Engine speed: 934.00 /min Normed load value: 16.5 % Vehicle speed: 0 km/h Coolant temperature: 27 �C Intake air temperature: 25 �C Ambient air pressure: 860 mbar Voltage terminal 30: 13.122 V Unlearning counter according OBD: 40 AFS dm: 48.6 kg/h Median injection timing: 1.234 ms Engine operating condition: Idling Engine operating condition-Test_Program_Channel 87: 5 Brake actuated status-Bits 0-7: 144 Tumg: 18.8 �C Psr w: 508.05 hPa Engine torque: 100.5 Nm 7654 - Secondary Air Injection System: Bank 1 P0491 00 [101] - Insufficient Flow Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 89828 km Date: 2019.05.18 Time: 09:12:05 Engine speed: 934.00 /min Normed load value: 16.5 % Vehicle speed: 0 km/h Coolant temperature: 27 �C Intake air temperature: 25 �C Ambient air pressure: 860 mbar Voltage terminal 30: 13.122 V Unlearning counter according OBD: 40 AFS dm: 48.6 kg/h Median injection timing: 1.234 ms Engine operating condition: Idling Engine operating condition-Test_Program_Channel 87: 5 Brake actuated status-Bits 0-7: 144 Tumg: 18.8 �C Psr w: 508.05 hPa Engine torque: 100.5 Nm Readiness: 0000 1000
