Results 1 to 4 of 4
    Established Member Two Rings yanni6556's Avatar
    Jul 03 2016
    Sydney Australia
    3.0 Camshaft Position Sensor error g163
    Hey,
    So i decided to scan my car today, seems i have a new code.
    17800 camshaft position sensor bank 2 (G163)
    p1392 -001- open short to plus - intermittent
    and
    18010 - power supply terminal 30
    p1602 -002-voltage too low intermittent
    Just wondering where on the motor that sensor would be. As far as i understand bank 2 is on the left side of the motor when facing foward from inside the cabin.
    Thanks
    Veteran Member Three Rings 2004a4b630QT's Avatar
    Mar 30 2015
    '04 A4 3.0 QTip
    Could be a failing cam pos sensor. They are at the back of each head held by a single hex scew (5mm I think) and have electrical connectors. Remove plug and screw and gently wiggle it out. They look similar to abs wheels sensors.
    The second one sounds like the code I got when my battery terminal connection was loose. It might also be related to failing alternator regulator (brushes).
    I'd clear them and see if/how soon they come back.
    May 28 2019
    Dover plains New York
    hello 2004a4b630QT I have a broken electrical connector on an intake cam sensor and don't remember what positions the wires were connected
    Nov 03 2010
    2019 Audi A5 Sportback, 1986 MB 560SL
    Fallbrook, CA
    Quote Originally Posted by yanni6556 View Post
    Intermittent "short to +" can mean a flaky ground connection for that sensor. Often, when a sensor looses the ground reference, the output signal will be the same as its power wire voltage.
