Results 1 to 17 of 17
    Mar 29 2019
    So Cal
    KW Street Comfort (SC) Coilover dampening settings?
    Heya,
    Those of you with the KW Street Comfort (SC) Coilovers, what have you used for dampening settings on your Q5/SQ5?
    I have read that a lot of people just go with the factory setting (middle - 7) on the Qs, but have definitely seen people change the settings on the other B8 platform cars to "firm up" the suspension a bit as they out the of box setting wasn't enough for them.
    I ask because the KW SC is really a pain to change the dampening on. You basically have to remove the strut mount again to get to the dampening adjustment allen key hole. Trying to avoid doing a readjustment if possible and just "get it right" the first time.
    I have a 2014 SQ5 and it's daily driver but I want a bit more aggressive feel vs. stock US especially on the dampening side. Looking to lower about 1.75-2" I think.
    2014 Audi SQ5
    EPL Stage I ECU | 034 Silicone Intake | AFe Dry Pro Filter w/ Airbox Mod | Snow Screen Removed
    EPL TCU upgrade | 034 Transmission Mount Insert | Supreme 15mm/20mm spacers
    Hoen H11 Fogs | DeAutoLED Interiors & Reverse Lights | OEM Q5 Rubber Floor Mats | Armrest Organizer
    Jan 30 2019
    Vancouver
    I think the only answer here is trial and error. I would jack up to the 9 and go from there. Might have to adjust a few times but I think it's worth it when you have it dialed in just right.
    2016 SQ5
    2016 Audi Sq5
    May 06 2007
    Michigan
    I left mine in the default middle position after dropping 2". I would only consider a firmer setting if I plan on tracking it regularly. As a daily, it is a compliant ride and I can take corners as if I were in my S4.
    2013 Daytona Grey RS5
    Prev
    2014 Ice Silver SQ5
    2012 Monsoon Grey S4
    2010 Brilliant Black A5
    2003 Denim Blue A4
    Mar 29 2019
    So Cal
    Quote Originally Posted by mlux24 View Post
    Did you use the spacers in the rear? I bought the 30mm for the rear per multiple people’s recommendations. I am looking for about 1.75” in the front and 1.5” in the rear. My stock suspension sits a bit higher in the front.... must be my golf clubs in the trunk at all times.
    2014 Audi SQ5
    May 06 2007
    Michigan
    Nope, no spacer. Digging the ride height as is...not sure if my golf clubs have dropped it even further. Maybe I should go remeasure? hah.
    Prev
    2014 Ice Silver SQ5
    2003 Denim Blue A4
    Mar 29 2019
    So Cal
    That’s only a 2” drop!? Look lower than I expected.
    2014 Audi SQ5
    Senior Member Three Rings KillerQuattro's Avatar
    Dec 15 2016
    Englewood CO
    Trial and error is a costly endeavor in this case. You cant just get under the car and re-adjust. You have to pull everything back off. Unless you want to drill a small hold in the engine bay to allow access to the top of the struts. I read up on this and had considered it, but never actually did it.
    I think out of the box it lowers about 2.4". I didn't use the spacers on mine either. It does sit pretty low. I would buy the spacers and install them regardless of your plans. Plans change, and I have to admit, I wish I could bring up the rear of my ride about 5-10mm.
    I went with the settings from the factory. Right down the middle. I don't feel that it needs to be any stiffer. In fact, at first I wish I had gone softer, for a more OEM feel. I ended up staying with it though and it has softened a bit.
    If I wanted to seriously address body roll, I would prefer a rear sway bar first, and go with factory dampening settings.
    Good luck!
    Current: 1995 urS6 Avant. RS2 manifold, Stage 1 chip, Apikol FMIC, custom exhaust.
    Sold: 2013 Q5 3.0t- EPL Stage 2, 183mm CP, KW Coils, Eurocode Alu Kreuz, 034 inlet/AWE filter, EBC Brakes w/ SS lines, Hartmann HRS6 20x9, MF #11385 (center res) and Vibrant Ultra-quiet resonators out back.
    Sold: 2007 Ibis Avant- 2.0t 6mt, JHM HFC, TT DP, JHM HPFP, GFB+, B5 perch mod, 19x9 RS6, Hawk slotted rotors and performance pads.
    Sold: 1992 urS4- Garret 3071R, 034 tuning, RS2 goodies, 993TT BBK
    Veteran Member Four Rings buggravy's Avatar
    Jun 25 2016
    Mountain bikes and snowboards
    Calabasas, CA
    Quote Originally Posted by wrcardon View Post
    I think I mentioned this in another thread, but I feel pretty confident that a 2" drop is the minimum that you are going to get in the rear even with the spacer. There was another user on here that had this set up. I talked to him about it pretty extensively as I was thinking of buying his when he parted out his SQ5. With the spacers on, and the adjustment threads at the limit of what he and the shop felt was safe, he was at roughly 30.5" FTG all the way around, which is 2" down in the rear, maybe even a little over 2".
    '23 S4 Prestige - Chronos Grey
    '24 Q4 55 e-tron Glacier White
    '24 Q5e District Green
    TOTALLED: '21 Q5 P+ - Glacier White (wife's)
    SOLD: 21 S4 - Mythos Black
    SOLD: '19 SQ5 - Quantum Gray
    TOTALED: 21 SQ5 - Ultra Blue
    SOLD: '19 e-tron - Typhoon Gray
    SOLD: '16 SQ5 - Sepang Blue w/Black Optics
    IG: @gravysq5
    Mar 29 2019
    So Cal
    Quote Originally Posted by KillerQuattro View Post
    I am considering drilling and adding a rubber grommet. KW makes extenders with the purple crank so I could run the extender through the grommet and into the engine bay in the front and somewhere into the rear too. Would need 4 of them @ ~ $50 each. They make different sizes so I guess I would have to guess if I want to do it in one fun install.
    KW Rebound Extension-10mm Wrench-300mm Long
    https://www.amazon.com/dp/B06X1CV1B7..._rGE7CbMEZ88Z4
    2014 Audi SQ5
    Dec 15 2016
    Englewood CO
    Why would you need 4? Shouldn't you need just 1 and estimate the size needed? I'm pretty sure it's just a longer version of their tool. You don't leave them in place while you drive.
    So drill the holes add the grommets and adjust with the tool through the grommets whenever you would like. Seems like a pretty good compromise so long as you do a nice job.
    Mar 29 2019
    So Cal
    The way I have seen it done with other brands is to leave them in permanently because it’s hard to get them to seat if there is some distance to cover. They are flexible so they kinda flop around. If you seat them in place during instillation and leave them pushed through a hole in a rubber grommet they make for super easy adjustment. Yeah, I could try to save money but I feel like this is one of those things where I would be kicking myself if I cut corners down the road and had to spend a ton of time trying to get the extender on the top of the coilover.
    Unfortunately, I haven’t seen anyone do this on a Q so I don’t know how long of extender I would need. Will probably buy several sizes on amazon and return the ones I don’t use.
    2014 Audi SQ5
    Dec 15 2016
    Englewood CO
    Ok I got you now. That makes more sense.
    Mar 29 2019
    So Cal
    In case anyone is looking to install the dampener extensions in the future, KW customer service got back to me super quick. Here is the hex size for the front and back "the front struts will use a 9mm extension. The rears would use an 8mm."
    The front looks super accessible as the strut mount is compact and right under the engine bay metal... so I will probably use the shortest one which is 100mm. The rears... i am not sure yet. Again the strut mount is short, but it's hard to tell what length is best. Looks pretty accessible if you pull the felt cover in the trunk off (there are two panels which remove on each side, one to access the MMI equipment and on the passenger side there is an indented pocket). Might go longer to make sure the knob is really easy to reach. The extensions are all the same price no matter the length.
    2014 Audi SQ5
    Senior Member Two Rings pickle.rs's Avatar
    Jul 18 2018
    IG @pickle.rs
    Any update here? Curious to know which extensions you went with, as I want to run these as well so i can easily adjust. Currently unhappy with the out of the box settings on my Q5. Rear bounces all over the place.
    I also seem to bottom out more than I think is acceptable just driving on the freeway, hitting transitions from asphalt to concrete (overpasses) and many other times where it really shouldn’t...
    2014 Audi RS5 | Capristo exhaust. 034 inserts. RMR Trans Cooler. JHM Stg 2 ECU+TCU. Bilstein B16 iRC, SPC control arms, CR-15, Alu Kreuz, GMG sways, JHM Lightweight Crank Pulley, Girodisc rotors and Magic pads, 034 motor mounts. P3 Gauge. ECS Stainless Steel brake lines. TAWChicago paddle shifters. Apple CarPlay.
    Also: 1990 MK2 VW GTI; 2015 Audi Q5 TDI
    Mar 12 2017
    N.C. USA
    Slightly different set up here. I have H&R lowering springs with Bilsteins B8s. My remarks are for the distance of cut offs of the bump stops. Installer took 1 1/2" off the stops & I have no problems with bottoming out. Great setup for my Q5. Just my .02.
    2020 Q5 prem plus Matador red/Beige
    Jul 31 2016
    PA
    The KWs I would think have their own bump stops so don't know that the comment above applies to you.
    That said, I don't know what the post ended up resulting in, but the rears I don't think would be accessible from the cabin since I don't think the mounting location penetrates all the way through to the interior. I can't remember now from when I did mine, but pulling one of those panels and looking in, it didn't look like it.
    The rears at least are super easy to pull though.
    The fronts you would have to remove or make a hole in the noise insulation.
    Quote Originally Posted by toasteronfire View Post
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Jun 15 2021
    VW Bug, VW Bus, FJ Cruiser
    Monterrey MX
    Did anyone get the SC's dialed in and install the extentions? I'm very annoyed at how bouncy my SQ5 feels, to the point where I feel sick after driving it a few minutes. I'll probably go the rebound extension route before removing them and going back to stock. How many clicks should I choose to get a less bouncy feel?
