Originally Posted by
rtmeikle
My car (2013 Prestige) has adaptive headlights. When the car is first started, they go up and down, AND left and right. Cars without only go up and down. That's the easiest way to check. The left/right movement is just as obvious and pronounced as the up down, so you'll know if you have it.
It also has cornering lights, which are in addition to the moving high/low beams. This is an additional bulb that lights when making a sharp turn, like pulling into a driveway. I'm not sure if all S4s have that or not. But it's a separate feature from the adaptive headlights.
Hope this clears it up.
Thank you. This post corroborates the information that I just received from Audi of America. The
cornering light is the yellow halogen light that turns on when you're turning at slow speeds or have your turn signal on and the
adaptive headlights will actually adapt to curves in the road between speeds of 6 and 68 miles per hour.
Audi also provided me with my monroney label and confirmed that I do indeed have the
adaptive headlights. What I
don't have is a left-right sweeping upon start up, only up-down. That makes me think that I may have something wrong with my car that is causing them to not function.
Is there any way to detect this?
