Hi Boys, i am fresh owner on B7 TFSI and i have boost problems, last week check car for error codes and found "P0299 - 002 - Control Range Not Reached" , N75 valve duty cycle was 0%, so i decided this valve is the problem. I bought new N75 valve and new diverter valve last revision, replace them, membrane on my old diverter valve was heavely damaged. Car working good, idle was stable, rev good, clear old errors no new one, but specified boost pressure is to low and duty cycle on N75 is 0.0%, and no boost?
Any suggestions???
720 /min Engine Speed (G28)
99.0°C Coolant Temperature (G62)
14.3 % Engine Load
2.06 g/s Mass Air Flow Sensor (G70)
6.3 % Cam. Adjustment Intake Bank 1
89.5 % Engine Load (spec. corrected)
0.0 % Boost Pressure Control (N75)
270.0 mbar Boost Pressure (specified)
890.0 mbar Boost Pressure (actual)
2880 /min Engine Speed (G28)
100.0°C Coolant Temperature (G62)
13.5 % Engine Load
7.61 g/s Mass Air Flow Sensor (G70)
39.2 % Cam. Adjustment Intake Bank 1
127.1 % Engine Load (spec. corrected)
230.0 mbar Boost Pressure (specified)
920.0 mbar Boost Pressure (actual)
