Results 1 to 40 of 60
    Veteran Member Three Rings jd_rs3's Avatar
    Dec 18 2018
    Longmont, CO
    DIY 4 inch Intake Elbow for APR Turbo Inlet System or Factory Pipe
    Purchase this filter: Green Filter #2893 (or whatever 4" ID filter your heart desires). I like this one because it's grey and dual cone, so it sucks in air right from the factory air ducting. https://www.amazon.com/Green-Filter-.../dp/B00DDTN1XI
    **If you want to retain the factory air ducting lid, choose a shorter filter, like this one**
    Green Filter 2899
    https://www.amazon.com/Green-Filter-...gateway&sr=8-1
    **If you want to retain the factory 3.5" turbo inlet pipe, choose a filter with 3.5" ID, like this one**
    Green Filter 2896
    For 4" intake parts (APR Turbo Inlet system), this is what you need:
    www.siliconeintakes.com
    10% discount code: "link987"
    (1x) 4" 60 degree silicone elbow
    (1x) 4" straight silicone hump hose
    (2x) 4" stainless steel coupler
    (2x) 4.25" worm gear hose clamps
    For 3.5" intake parts (Factory turbo inlet), this is what you need:
    (1x) 3.5" 60 degree silicone elbow
    (2x) 3.5" stainless steel coupler
    (2x) 3.75" worm gear hose clamps
    ***BONUS CONTENT*** 5" SETUP ***
    If any of you are feeling froggy and want to take your 4" APR to the next level, try this, hehe
    5” to 4” hump hose reducer (x1)
    https://www.intakehoses.com/reducing...d-to-4-id.html
    5” intake joiner (x2)
    https://www.intakehoses.com/aluminum...-x-4-long.html
    5” 90 degree elbow (x1) *you will need to cut to ~60 degrees*
    https://www.intakehoses.com/rubber-e...e-no-ribs.html
    AFe 5" #21-91062 filter (dual cone): https://afepower.com/afe-power-21-91...y-s-air-filter
    or
    KNN 5” #RU-3107HBK filter https://www.knfilters.com/ru-3107hbk...-on-air-filter (only down side is, it's not dual cone)
    For the recirculation valve, grab one of these breather filters:
    K&N part #62-1370, which has 1" ID, 1.5" tall (comes grey / un-oiled or red / pre-oiled)
    https://www.amazon.com/62-1370-Vent-.../dp/B00029WXTA
    K&N part #62-1420, which has 1" ID, 2.25" tall (comes grey / un-oiled)
    https://www.amazon.com/62-1420-Vent-...omotive&sr=1-1
    S&B part #26-1370JR, which has 1" ID, 1.5" tall
    Yes, it's big (TWSS)
    Step 1: Remove lid from air intake ducting
    Step 2: Drill 3/8" hole into hump hose
    Step 3: Attach PCV hose and barb fitting
    ***Make sure barbed fitting is not covered by stainless steel joiner to ensure proper vacuum on this port!!***
    Step 4: Work from APR pipe outward using water with a few drops of dawn soap to keep things lubricated for adjustment purposes. Loosely clamp everything in place until you reach desired fitment and orientation, then tighten everything down.
    **Rememeber not to over tighten clamps to carbon fiber intake tube as you can crush it!!*
    Step 4b: Install stainless steel coupler into filter and connect to 60 degree silicone elbow. Do not insert the coupler too far into the filter, as it will restrict airflow. Insert approximately 1" (the filter inlet flange depth):
    Step 5: Use black piece of door edge guard or rubber to protect air filter where it touches air intake ducting. https://www.amazon.com/gp/aw/d/B01BW...b_b_asin_title
    Step 6: Install breather filter on recirculation valve:
    Step 7: Relocate trans fluid vent to existing tab:
    That's it!
    Finished product:
    Confirmed filter does not touch hood when closed!
    Videos:
    https://photos.app.goo.gl/wnountBSrKvX9YKo9
    2018 nardo gray rs3 - sold
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    Looks pretty nice to me, big fat pipe, big fat filter. Thanks for sharing. ETS also will build a custom elbow or custom hose, you just have to send them the dimensions. The little tiny rubber guard to protect the filter can also be replaced with the door guards that you put on the edge of the door sill. They sell them cheap on 15ft rolls.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Sep 17 2018
    Dallas Texas
    Does it feel like it makes a difference over the stock box with a panel?
    Dec 18 2018
    Longmont, CO
    Yes! When I drove the car last night for about 20 mins, I lit up the tires at launch like never before. My butt Dyno is not calibrated but I can positively say this intake, combined with pendulum support on a stage 2 e85 car made a considerable difference.
    That being said, I don't have a comparison between the APR inlet system with stock air box vs APR inlet system with my diy elbow. Some guys have seen 25rwhp on back to back Dyno pulls by just cutting the stock airbox. I guess we'll see what APR power increase claims are with their open filter design and can safely assume this system makes very close if not the same increase as that.
    Mar 13 2016
    San Jose, CA
    DIY 4" Intake Elbow for APR Turbo Inlet System
    Quote Originally Posted by jd_rs3 View Post
    Stuff.
    Great write up. What JD elbow are you referring to?
    Edit: Oh, your custom solution. Haha.
    Dec 18 2018
    Longmont, CO
    Quote Originally Posted by tateltot View Post
    Lol. Distracted this morning. Typo .. will fix
    Dec 18 2018
    Longmont, CO
    Reference to APR open system.
    https://youtu.be/HspYoAfrt5s
    No air ducting at all with their system, not even bottom portion. Not sure why.
    Aug 29 2017
    Tucson, AZ
    jd_rs3,
    I recently took the car to the dragstrip and removed the oem filter panel and it made no difference which tells me that the biggest restriction is perhaps the shape of the air box itself. I believe that going open filter will benefit the flow. I just don't know why APR hasn't released their open filter cone yet, I mean, they already made the difficult part which is the piping, all you have to do now is slap a big cone filtered a cheap plastic square box to isolate the engine bay heat.
    at 3100ft elevation
    Dec 18 2018
    Longmont, CO
    Quote Originally Posted by S3DUDE View Post
    jd_rs3,
    Interesting! I will eventually do some Dyno pulls but not sure how much difference it will make. Still, the fact the stock air box has a vacuum actuated flap in it to increase flow with air from the engine bay tells me that it has to be at least in certain situations, ie, heavy load, somewhat of a restriction.
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    All the photos of the prototypes don't have any shielding from heat nor ducting from the front, it's just a massive cone filter in the OE box location. Will be interesting to see if they've added either of these for the production model.
    Veteran Member Three Rings ChanceA4Parks's Avatar
    Jan 22 2018
    Ridgeland, MS 39157
    I just received the aluminum to build something like this for a 2.7t. Nice build
    Only owned 1 Audi so far.....It won't be my last!!!
    Built 2008 Audi RS4 with a 2.7t swap. JE Pistons (9.0:1 83mm)and Pauter Rods. 2.8 heads with Supertech Valvetrain (stock size) and RS4 Cams. TTE780+ turbos, RS6 Throttle Body, Snow Performance Stage 2 Meth Injection, and Motoza Tuned. The Tuner Inlets and intercooling piping. ID1000 Injectors and 034 Surge tank. Just use your imagination on everything else!!!
    May 16 2017
    MD
    Thanks for posting this! I ordered some stuff to try my own diy.
    How secure is the PCV with just the barb fitting? That's the only thing that I'm iffy on.
    Dec 18 2018
    Longmont, CO
    Quote Originally Posted by hilltop804 View Post
    Secure. Trick is to make sure hole is not too big!
    Mar 13 2016
    San Jose, CA
    Quote Originally Posted by jl87 View Post
    The general belief is that the IC cools down the air anyway, though you would probably get a bit more hot air sitting in traffic without ducting. Not sure we’ll have conclusive results that ducting = power.
    Veteran Member Three Rings sleeperwagon's Avatar
    Nov 07 2007
    18 RS3, 22 AMG GLC43, 97 AA M3 Sedan, 03 Dinan M3 Convert, 88 E30 M3
    Northern Ohio
    didnt need any elbow tube. just another option for everyone. didnt need anything but the cone and a ziptie. i kept the bottom portion of the orginial airbox in thinking it draws outside air???? no clue. plus i wanted the air filter to sit on something i could ziptie it to. ECS tuning air filter btw20190517_182007.jpeg
    Sent from my SM-G960U using Audizine mobile app
    3m clear everywhere, completely debadged, tenntech rear spoiler, tint, window spoiler, APR stage 1+, APR IC, APR inlet with tube, APR Springs, homemade intake, unibrace, milltek 2nd-ary Cat Deletes. E85 right now. BC Forged wheels, whaletail, V8Bait lights....Splitter group buy and lwt battery on its way
    Oct 02 2017
    link to ECS filter?
    Mar 13 2016
    San Jose, CA
    Quote Originally Posted by sleeperwagon View Post
    Haha. If it works, it's not dumb.
    Aug 01 2017
    Cali
    Good job OP. any clip on sound? How do you like it so far?
    My hunch is APR’s design probably will look very similar to yours but you did at the fraction of the cost. Haha.
    Dec 18 2018
    Longmont, CO
    Quote Originally Posted by J_3_f_f View Post
    Yes here is a link to videos. Should give you a good idea on sound. I love it
    Jun 02 2018
    Blackpool
    One of my friends made this for me
    Dec 18 2018
    Longmont, CO
    Quote Originally Posted by DodgyRS3 View Post
    That's pretty cool! You might consider a dual cone filter so that air will go right into the intake tract. How tall is the filter you are using?
    Here's a grey, dual cone filter with a 3.5" ID : https://greenfilter.com/store/2896 It is 6.5" tall, including flange.\
    If you prefer green: https://greenfilter.com/store/2459
    Mar 13 2016
    San Jose, CA
    Likely with a carbon elbow, I suspect.
    - - - Updated - - -
    Maybe it just doesn't make a difference at speed with the turbo sucking in its own air?
    Jul 25 2010
    WI/IL
    FB Post Here "Coming Soon"
    Dec 18 2018
    Longmont, CO
    That's at least a 5" ID filter! Big honker! Curious to know the cost and if there is any benefit over what I've already done.
    I updated the first post to include:
    -4" ID filter options for those wanting to retain factory air ducting *lid*
    -3.5" ID filter options for those wanting to retain factory turbo inlet piping
    -3.5" parts list for those wanting to retain factory turbo inlet piping
    -Info and purchasing links to all filters mentioned
    Dec 18 2018
    Longmont, CO
    or
    KNN 5” #RU-3107HBK filter https://www.knfilters.com/search/pro...rod=RU-3107HBK (only down side is, it's not dual cone)
    Nov 13 2018
    west
    Props man. This forum needs more DIYs
    Mar 13 2016
    San Jose, CA
    Agreed. We need a dyno battle! :)
    Dec 18 2018
    Longmont, CO
    Who's going to try the 5" DIY?
    How much do we anticipate the APR system costing? I think the 4" elbow/filter setup I posted is about $150
    Jul 25 2010
    WI/IL
    Hard to say on cost. The rear APR 4" CF tube is ~250, and an APR filter for a B8.5 S4 (similar cone filter, though probably smaller) is $75. That leaves the CF elbow and hardware for install.
    Your setup will be significantly cheaper and will probably perform similarly I would think.
    Veteran Member Three Rings MichiganRS3's Avatar
    Apr 30 2015
    Michigan
    I suspect the APR part to be $449-499.
    `18 Mystic Blue Pearl Effect RS3
    10.6 @ 129mph / 2.82s - 0-60 - Stage 2 e85
    Established Member Two Rings Audi TTRS's Avatar
    Jan 17 2019
    Quote Originally Posted by MichiganRS3 View Post
    I'm thinking 599-799. Hoping for way less though.
    2018 TTRS stock
    Apr 30 2015
    Michigan
    Quote Originally Posted by Audi TTRS View Post
    2018 TTRS stock
    https://www.facebook.com/APRMotorspo...type=3&sfns=mo
    60% of $900 is $540
    So maybe $499-$549
    May 08 2015
    uu
    no way it should cost ~300$
    Apr 30 2015
    Michigan
    Quote Originally Posted by s316 View Post
    I don’t disagree that’s what it SHOULD cost.
    Back on topic:
    The DIY ones are usually OK. I always used thin wall aluminum tubing from Woolf Aircraft bent to the correct angle when I was making them for Grand Prix GTP’s back in the day. I’d polish them and they looked pretty nice. Black powder coating was about $50.
    Example of the tube and bend
    https://catalog.woolfaircraft.com/it...5-450-045-6061
    Nov 13 2018
    west
    I like the marketing, show an inlet and tube that's 749$ plus your new part. Someone comments $900 and you say 60% cheaper, not specifying just cone and little elbow.
    So, $1200+ for their set up, which at least includes an inlet, vs other full intake options.
    Dec 18 2018
    Longmont, CO
    My guess
    $750 for turbo inlet system
    "60% less than 900" for the filter elbow $360
    Total $750+$360 = $1,110
    Nov 13 2018
    west
    [QUOTE=jd_rs3;13692990]$750 for turbo inlet system
    ahhh right math got switch so the 540 was the 60% to be removed. It's early here. Haha.
    I mean... $360 area sounds... fair for their R&D and it being carbon. Definitely the most attractive price for the entire intake tract to the turbo.
    Dec 18 2018
    Longmont, CO
    $360 is not unreasonable for carbon and a nice looking overall system. Plus, judging by the pics it looks like this includes a mount below the filter portion and of course provisions for PCV and Recirc valve hoses. For $1100 including turbo inlet, I am cool with it.
    Jul 25 2010
    WI/IL
    Quote Originally Posted by myrder View Post
    Was thinking this too. $250 for the main rear 4" CF section and then ~$360 for a tiny CF elbow and filter, hardware,etc?
    Mar 13 2016
    San Jose, CA
    So JD, when does the JD-branded billet mounting bracket come out? ;)
