So since my rebuild I've chased down a few leaks. Fixed all but one. I seem to have a persistent leak on the back of bank 1. Leaking about 1/2 a quart every 200 miles or so (about 500 on the build so far). The CPS was leaking pretty bad but I fixed that with a new o-ring and some RTV for good measure.
It's definitely leaking from the top, down bank 1. Seems to get worse under high crankcase pressure. I finally pulled the trans as I could not distinguish if their was a leak at the rear main seal due to where the drips were originating. I havent pulled the clutch but the BH and clutch is dry. When its parked its leaving a drop or 2, but it's definitely worse when driving, evidences by the lovely splatter all the towards the rear of the car.
My question is, could a camshaft adjuster solenoid account for this much leakage? I'm thinking it might be coming through the actual sensor. Top of the engine is bone dry. Half moon seals and valve cover gasket is dry. Above the sensor is dry. I did not replace this solenoid when the engine was out.
Anyone have a leak at this location that can chime in? Thanks!20190524_172929.jpeg
Sent from my SM-G955U using Audizine mobile app
