Results 1 to 9 of 9
    May 23 2019
    Long Island
    A3 ECU tune noob
    What’s up guys names james. I Just recently leased a 2019 A3 and was reading up on the ecu tune by APR. now forgive me but I’m a complete noob with tuning and modding. It’s kind of why I’m not too upset I didn’t get an s3 or rs3. I just wanted to get into an Audi and see where things go once I get my feet wet. Okay, anyways, from what I read on the apr website, this ecu tune requires NO engine modifications and it will get me 60+ more hp and tq? My question is: is that 100% accurate? Are there ANY mods I would need? What are the real risk here considering it’s a lease? Will it void my warranty? Could I revert it back to stock without it being detected?
    Feb 13 2019
    yuma,az
    Warranty will be void. Stage1 you dont need any supporting mods, I wouldnt mod a lease but that's me, if you really want to wake it up, get a downpipe, intercooler and a stage 2 tune, and the dsg tune
    Sent from my SM-G950U1 using Tapatalk
    May 23 2019
    Long Island
    A have some friends with other car makes say they can just tune it back to stock if they have to bring it in for service. Is that possible with Audi? Also side note, I’m also a railroader
    Feb 13 2019
    yuma,az
    Quote Originally Posted by jmza3 View Post
    Vw/Audi can tell whether you flash back to stock or not, if your worried about warranty then get a downpipe and a jb4, you can make about st2 power with a jb4 and it easy to install and remove so if you go to the dealer just remove it, also probably should remove downpipe also if you went to the dealer depending on how cool your dealer is. Who do you work for, I work for union pacific
    Established Member Two Rings fasheen's Avatar
    Jul 07 2017
    CA
    There’s always a risk that the car will be flagged as TD1. There are countless threads that talk about this. Best bet to go under the radar about a tune is a JB1 or JB4 which is a piggyback tune. I have a JB4 installed in my S3 and simply take it out before services/warranty work.
    May 23 2019
    Long Island
    Long Island Railroad, id say a little less freight than you 😆
    May 23 2019
    Long Island
    Quote Originally Posted by fasheen View Post
    What’s the difference between a jb4 and apr tune?
    Jul 07 2017
    CA
    Not an expert by any means but from my understanding, you’d get more power out of an APR tune (because it reflashes your ecu) compared to less power out of a JB1 but it doesn’t reflash your ecu (hence keeping your warranty in place)
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    It has nothing to do with power output. The APR tune is software that writes over the factory ECU programming, which is detectable by Audi. The JB1/4 is a physical device which plugs into various sensors and alters their readings, in order to make more power. Once removed, it’s not detectable by dealerships (in theory).
