Results 1 to 17 of 17
    Mar 29 2019
    So Cal
    Sway bar end links? Moog for the back... OEM up front??
    Heya,
    I was wondering what people were using for front sway bar end links. I know Moog is the way to go for rear on a daily driver or if you just want silent end links (all the spherical seem to eventually cause "clunks" and have to aggressively be greased). That's what I am getting when I add the 034 RSB.
    What about fronts? Someone had mentioned the Macan front end link, Porsche #4M0-411-317 https://parts.porschewoodlandhills.c...link-4m0411317
    But it looks exactly the same as the SQ5 OEM one it came with. Same part number and everything, Audi (4M0-411-317)! https://www.audiusaparts.com/oem-par...MtMGwtdjYtZ2Fz
    2014 Audi SQ5
    EPL Stage I ECU | 034 Silicone Intake | AFe Dry Pro Filter w/ Airbox Mod | Snow Screen Removed
    EPL TCU upgrade | 034 Transmission Mount Insert | Supreme 15mm/20mm spacers
    Hoen H11 Fogs | DeAutoLED Interiors & Reverse Lights | OEM Q5 Rubber Floor Mats | Armrest Organizer
    Dec 08 2018
    Northeast
    I used moog. Bought from Rockauto.
    Mar 29 2019
    So Cal
    Quote Originally Posted by WideSuppie View Post
    I don't see a set of Front end links from Moog either on their website or Rockauto's.
    Like I said in the original post, I know Moog is the way to go for rear. I am looking for front recommendations.
    2014 Audi SQ5
    Mar 29 2019
    So Cal
    Wow, no one has changed out the front sway bar end links?
    2014 Audi SQ5
    Veteran Member Four Rings elijahallen's Avatar
    Nov 12 2006
    Michigan
    Eurocode has front adjustable end links, I just ordered a set of their front and rear bars and have the 034 rear end links and will probably add the eurocode fronts if I feel they are needed but am gonna try the front with stock links to start and go from there.
    2014 Porsche 911 turbo S, 2022 RS3 Uni DP, mid pipes, Racingline Piggyback(SOLD), 2018 RS3 Uni Stage 3 Iroz built motor(SOLD), 2017 Q7 APR stage 2 DP, 2016 Audi Q5 TDI Malone stage 2, 2013 Q5 3.0t DP stage 2(sold), 2016 SQ5 DP stage2 (SOLD) ,2014 Q5 tdi Stage 2(SOLD),2008 Porsche Cayenne S stock(SOLD),2011 B8 S4 DP stage 2+(SOLD),2001 B5 RS4 clone Built motor 600hp(SOLD),3 B5 S4 Avants Stage 3+(SOLD),95 S6 Avant RS2+(SOLD),94 S4 K27 built motor(SOLD),91 Coupe AAN RS2 Conv. Built motor.
    Mar 29 2019
    So Cal
    Quote Originally Posted by elijahallen View Post
    Do you know if the front OEMs are metal or plastic like the rear? I linked the part I think is the OEM Audi part above and it appears to be metal and the same part as the Macan (same part #).
    2014 Audi SQ5
    Mar 29 2019
    So Cal
    Ah! For some odd reason they don’t list the 2014 SQ5 (2015 - 2017 yep). That’s why I couldn’t find it. Thanks.
    2014 Audi SQ5
    Mar 29 2019
    So Cal
    Hmm... is there much advantage to switching out the OEM SQ5 front end links with the Moogs?
    It doesn’t sound like anyone changes them out. From the photos the OEM appears to be metal with a rubber bushing, where the rear OEM is plastic (at least not metal) and there is and advantage to switching to the metal and polyurethane bushing Moog end link.
    2014 Audi SQ5
    Mar 29 2019
    So Cal
    Ah! So I figured out what really is stock OEM. It's a plastic front end link https://www.europaparts.com/sway-bar...k0411317d.html Verified this when I finally got my lazy ass out to look with a flash light. Couldn't see them the first time... didn't think to just turn the wheel all the way to one side...
    This sight also happens to have the Macan OEM for the cheapest I have seen https://www.europaparts.com/sway-bar...4m0411317.html
    I already ordered the MOOGs and received them and they are half the price with ($25) with free shipping ($10 for the Europaparts to CA). Kind of wish I had gotten the Macan as they are aluminum. But next time maybe.
    The big reason for switching out the OEM ones for me is that I am dropping the car with the KW SC coilovers and have heard that the OEM ones don't hold up well to a lowered "stiffer" suspension.
    Think I am going to Krylon the Moog as they are not stainless steel. I guess I will go yellow to match the horrendous KW colors.
    2014 Audi SQ5
    Mar 07 2004
    2025 Q7, 2018 TTRS, 2022 Q5
    Charleston, W.V.
    I have a set of new in the box Moog front end links and the mounting hardware. I purchased them for my Q5 TDI and never installed them.
    Mar 29 2019
    So Cal
    Quote Originally Posted by BarryT82 View Post
    Where is a good place to source the mounting hardware?
    2014 Audi SQ5
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    Local Audi Dealership will have them
    Is the all-metal / aluminum revision the way to go now? Do the plastic ones have a high fail rate on stock system?
    Quote Originally Posted by wrcardon View Post
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Dec 27 2014
    2013 Audi Q5 3.0T
    I got the Porsche all aluminum ones for the front
    Current:
    70,xxx Miles
    182,xxx Miles
    Dec 27 2014
    2013 Audi Q5 3.0T
    Is it a common theme for the 034 RSB Links to clunk prematurely?
    Current:
    70,xxx Miles
    182,xxx Miles
    Senior Member Two Rings sQ5inSD's Avatar
    Apr 26 2020
    Las Cruces, NM
    I changed mine to the metal version from the plastic OE types when I installed new coilovers. Honestly, I cannot tell any freaking difference - as long as the links are not broken it really does not make much difference. People get really wound up about metal vs plastic but to me that is just hype...
    Dec 27 2014
    2013 Audi Q5 3.0T
    Quote Originally Posted by sQ5inSD View Post
    I’d have to agree, I picked up the 034 billet links for the rear. I think it’s more of a appearance thing but my plastic links were creaking
