Results 1 to 36 of 36
    Established Member Two Rings Atrevido's Avatar
    Mar 19 2018
    Florida
    Is an X-pipe just an X-pipe?
    I’m interested in buying an ECS X-pipe ($259) for my S4 and having it professionally installed. I stopped by a well rated indy muffler shop and asked for a quote: they said about $80
    and it could easily be done in less than an hour. My total cost would be around $340.
    The manager asked if I’d already bought the x-pipe and if not, he could fabricate one and install it for $300. He said “after all, an X-pipe is just an X-pipe”.
    So, is an X-pipe just an X-pipe? I’m interested in your thoughts, pros and cons, etc.
    2013 S4 / 6MT / Phantom Black / APR Stage II Single Pulley / Sports Diff / RS4 Grille / Sachs Performance XTend Clutch / ECS Lightweight Flywheel / ECS Transmission Mount Insert
    ECS X-Pipe / K&N / Modded Air Box / CR-15 / Osram CBI 5500K HID / Zimmermann / Akebono / Pirelli P Zero AS Plus 3 / Hard-wired Valentine V1 Gen 2
    Established Member Two Rings BlueSteW8's Avatar
    Apr 24 2011
    Supercharger Heaven USA
    Technically it is a "D" pipe, though x pipe works.
    Veteran Member Three Rings brs2c's Avatar
    Apr 26 2017
    GLS 450
    Nashville, TN
    The angle at which each side converges on the 'x' can make a slight difference on sound/performance, but for the most part...an x-pipe is an x-pipe. With the ECS X-pipe, you are paying for that ability to not have to weld it in place. Performance wise, you are actually better off to move the X closer to the front of the vehicle than the ECS, as you want the exhaust pulses to be able to balance as soon as possible (although I imagine the performance difference from moving 2' forward would be very small). Hope this helps.
    2013 S6 Prestige Monsoon Grey || SRM RS-7 Turbos, APR Catted Downpipes, SRM Long Intakes, DS1 Tune, SRM TCU, HPFP, SRM High Pressure Fuel Line, SRM Ethanol content analyzer, SRM Driveshaft Carrier V2, O34 Drivetrain Inserts, 034 Control Arms. || RS-Style Grill, BBS CI-R 20x10.5 Wheels.
    Previous
    2013 S4 || 3.5" Velocity Stack Intake, EPL Stage 2+, Fluidampr 183mm CP, iAbed TB, EPL TCU, AMS Alpha Cooler || VMR V804's (19x9.5 et45), 2-piece Rotors, 034 SB, 034 drivetrain & subframe inserts,
    Veteran Member Three Rings dimonblr's Avatar
    Oct 02 2018
    Boston
    This is ECS
    This is probably closer to what the fab shop will do for you.
    B8.5 S4 | B9 Q5 | IG: @dmzb8s4
    Veteran Member Four Rings XxSullyxX123's Avatar
    Mar 04 2015
    2020 Jeep Unlimited Wrangler Rubicon Recon, 2023 Honda Pilot Elite
    Somers, NY, USA
    Quote Originally Posted by Atrevido View Post
    To save $40 I wouldn’t have them throw something together that may not be as good as something that at least had some level of R&D put into it.
    2016 S4 P+ | Mythos Black | DSG | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | B&O | Carbon Inlays | Supercharged Badges ||| - SOLD
    2015 S4 P+ | Monsoon Grey | 6MT | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | Supercharged Badges | AudiGuard ||| - SOLD
    Jun 05 2015
    a few interesting items
    ECS part has the resale value on here.
    However, I'm pretty sure you won't notice a huge difference if your shop can weld pretty competently.
    Local shop in my town that did all my custom exhaust work over the years (well, most of it) has made resonator deletes and x pipes and mandrel bent intake tubes and even custom racing exhausts for motorcycles I've owned. They all worked perfectly and sounded as they should have and cost a fraction of what I would have had to pay otherwise.
    I've definitely had to spend a bit of time in each case explaining to the technicians what exactly they needed to do and where but none of it has been rocket science and their skills have been excellent.
    I am willing to bet ECS' costs on these came from making them bend in the right spots and look pretty(ish).
    My shop would probably charge $40-140 depending on how busy they were to do the same kind of thing on my car if I wanted it.
    Maybe you should see what other exhaust shops in your area will say?
    Sent from my LYA-L0C using Tapatalk
    Oct 30 2012
    Oxford, MS
    Quote Originally Posted by brs2c View Post
    I was told that a good way to determine the placement of a crossover pipe (H- or X-) was to use a crayon on the exhaust. First, draw a line with the crayon down the exhaust, second, go for a regular drive, and third note where the crayon quits melting. The point where the crayon quits melting is where the crossover is supposed to go. I have no idea who invented that rule of thumb, if it is any good, and if cheap Chinese crayons are acceptable or if you have to use Crayola. Our cars are tight such that things go where they fit.
    Apr 18 2014
    Nashville, TN
    I would definitely pay a bit more to get the ECS X pipe for the easy bolt-on installation, in case if you ever want to go back to stock.
    Much better to go with the part that was created by the company that did the research and development.
    Current - 2021 A6 45 TFSI Premium Plus
    Sold - 2015 S4 manual Premium Plus
    Mar 19 2018
    Florida
    This is why I truly appreciate this thread: the wide variety of opinions and personal insight.
    A sincere thank you to everyone for your feedback, I'm pretty sure I'm going the ECS route.
    Mar 20 2015
    McKinney,TX
    Not sure of the shop or what they offered, but most shops do not use stainless steel such as what is offered by ECS
    Apr 18 2014
    Nashville, TN
    https://www.audizine.com/forum/showt...034-Motorsport
    Check out the thread that I created a while ago. We have two options for the direct fit X pipe. The 034 one looks nicer with added braces, but if you look at it closely at the "X" portion, you can see one of the two pipes is straight. The ECS one is truly X-shaped. For that reason, I think I will go with the ECS one. It may not make any difference, but know what I am saying?
    Mar 19 2018
    Florida
    Quote Originally Posted by jungy4 View Post
    I know what you're saying, and ordered the ECS this morning.
    Apr 18 2014
    Nashville, TN
    If you get it installed, can you let us know how it went in terms of installation process and sound? I am debating.
    Established Member Two Rings JimmyJamesS4's Avatar
    Sep 08 2011
    Grayslake, IL
    Get a magnaflow x pipe and have them weld it, no rasp
    Sent from my SM-G965U using Audizine mobile app
    04 a6 2.7t
    mods: APR BiPipe, unitronic stg2 chipped, snow performance w/m, Custom CAI, ST Coilover
    Mar 19 2018
    Florida
    Will do. It's out for delivery, and should be installed by early next week.
    Mar 19 2018
    Florida
    The ECS X-pipe arrived yesterday and was installed first thing this morning. Of course, I had to take her out for a nice long test drive, and I tell you what, she sounds nice!
    Quiet at idle, but when you give it gas you can’t help but think this is what it’s supposed to sound like. Just a little throaty, and a bit of rasp, but definitely not obnoxious.
    I won’t be upsetting the neighbors any time soon. Most importantly, no drone at all.
    That being said, I have two major shout outs. First to ECS: I ordered the part Tuesday morning for $259.95 delivered. The very next morning it went on sale for 15% off, or $220.96.
    I emailed ECS customer service requesting the discount and they responded less than 24 hours later. They took the 15% off the price and gave it to me as a store credit.
    The second shout out is for G Exhaust of South Florida. They’re clearly car enthusiasts who enjoy their work. I saw them do a complete cat-back exhaust on a Nissan 370Z in
    less than 45 minutes. (Maybe that’s normal, but I was definitely impressed.) My X-pipe didn’t take more than 30 minutes and they made sure everything was tight and aligned.
    It cost $80 and I was out the door. While I was there I spoke with 2 other guys who spoke highly of G Exhaust and were repeat customers. That says a lot.
    Apr 18 2014
    Nashville, TN
    Thanks for the review and picture. Did it come with instructions that provided measurements on where to cut? I have read somewhere that their measurements were a bit off. I think I am ordering mine soon.
    Mar 19 2018
    Florida
    jungy4,
    It did not come with any instructions, only hardware. It took two guys: one to hold the new ECS in place directly below the existing OEM parts, and a second guy to mark
    where exactly to cut behind the resonator. Immediately aft of the baby resonators are easily-removed clamps, so there's no need to make any marks upstream
    of the resonator. The second guy made his marks on the OEM exhaust exactly where the ECS X-pipe ended. After that it was remove & replace.
    I can't imagine laying on my back in the hot sun and trying to do that by myself, and give a lot of credit to those of you that have. I hope this helps.
    Apr 18 2014
    Nashville, TN
    jungy4,
    Any chance of posting soundclips? That will be much appreciated.
    Jun 05 2015
    This thread has inspired me to buy a generic x pipe for my A6 and have a shop weld it in. We will compare pricing and sound thereafter.
    Dec 29 2011
    Vancouver
    Quote Originally Posted by rrated View Post
    Ie. MF 11385
    Jun 05 2015
    No like a generic stamped one
    Mar 19 2018
    Florida
    Before I bought the X-pipe I watched the following vids, and these are pretty accurate regarding the sound:
    https://www.youtube.com/watch?v=ffS7oQWvUr4
    https://www.youtube.com/watch?v=dOtnAX6whSM
    https://www.youtube.com/watch?v=hdy3uikTYBU
    Apr 18 2014
    Nashville, TN
    What year A6?
    Jun 05 2015
    Senior Member Two Rings kevinz's Avatar
    Aug 17 2016
    2015 S4::2010 Q7 3.6
    so, is the benefit just the sound? or is there a performance improvement?
    2015 S4 6MT Sepang | EPL stg2 | aFe Pro 5R | ported air box | 034 intake hose | RS grille | AG590 19x9.5ET40 | PS4S 265/35/19
    Jun 05 2015
    Quote Originally Posted by kevinz View Post
    Supposedly helps with scavenging to get exhaust moving faster if done properly
    Apr 18 2014
    Nashville, TN
    I doubt there is any performance gain. Just one of the simple ways to get more sound out of our silent stock exhaust.
    Mar 19 2018
    Florida
    +1. Performance gains, if any, would be minimal. This upgrade was strictly for the sound, and I'm very happy with it.
    For performance gains I'm pretty sure you'd have to do a complete exhaust replacement and look to AWE, Borla, etc.
    Sep 07 2014
    Bump. Want to see if OP has any regrets thus far with the xpipe? I see a bunch of them for sale in the classifieds. Wondering if I should just put that money towards a catback. Just don't like the look and attention of an aftermarket catback.
    Mar 19 2018
    Florida
    No regrets at all, and the best part is the cold start: it sounds niiiiice!
    Veteran Member Three Rings BR11S4's Avatar
    Apr 29 2019
    Cincinnati, OH
    I just got mine last night. Need to get it installed. Cant wait!
    Sent from my SM-N950U using Audizine mobile app
    Veteran Member Three Rings king_j's Avatar
    Sep 09 2009
    Minneapolis
    Op, have you had a car with an aftermarket exhaust before?
    If so, how would this compare?
    The x pipe is louder than stock, but sounds like it has no tone.
    Nothing to make it sound nice, just louder and a bit of rasp. This is based off vids only, have not heard it in person.
    2006 A4 2.0T Q. S-Line 6MT - Arctic White
    JHM stage 1, 034 hfc, Europaparts exhaust.
    Miro 111 18x8.5 et 35, 034 RSB.
    Mar 19 2018
    Florida
    king_j,
    Sorry, but the last time I had a performance exhaust on any of my cars was on an '87 Monte Carlo SS. The exhaust from a small block Chevy sounds a LOT different
    than from my '13 S4, so I wouldn't be anywhere near comparing "apples to apples" for you.
    Feb 25 2013
    MKIII Jetta,Integra GSR built B18C1T, Mazda RX8
    United States / Georgia/ SE
    It’s worth it. I have had the x pipe for about 2 years and love it. It sounds similar to a z car with exhaust. Yeah it’s a little raspy but I think it adds to the character. Thankfully it’s quiet when it needs to be and not bothersome on long commutes. I highly recommend.
    Florett Silver Metallic, Black Optic, Sport Diff, B8.5 S4
    Veteran Member Four Rings Charles's Avatar
    Jacksonville
    Getting an X Pipe doesn't have to cost $300 (after install). I picked up this guy thinking my Borla was catback, but it wasn't, so now it's sitting in the box. If anyone wants it, $20 + shipping
    https://www.summitracing.com/parts/jex-sxp4ss
    2013 S4 - 200mm crank pulley (3.162 ratio), 034 Stage 2+, USP intake, MercRacing HX, Sachs XTend clutch, SS clutch line, Borla exhaust, gutted cats
