Results 1 to 21 of 21
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Throttle body adapter for 75mm TB
    Who makes/sells throttle body adapter to fit 75mm (RS4? 077133062) on stock (60mm) intake?
    The 034 I found says "S4", which I think are 70mm (078133062) only.
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by vtraudt View Post
    Nick Audlee
    But I recommend that you have him weld a flange on it and bore the intake out to match the TB, otherwise, bottle neck is still a bottle neck.
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by vavJETTAw36 View Post
    That is a good idea since I have a spare manifold to play with. Will talk to my designated tig welder and look up some example photos how its done.
    Since flow losses are accumulative, any reduction of loss is a gain. There is a post from Issam somewhere where they tested various TB on small port SEM and engine dyno. Pretty realistic.
    05 Golf TDI
    Jul 04 2012
    Woodbridge, VA
    If it helps
    Feb 20 2010
    Brighton, MI
    Thanks. Will take a look at my spare manifold tonight to see if there is a natural 'cut line' the could be used for a weld on flange to avoid the step down flow losses.
    05 Golf TDI
    Jul 04 2012
    Woodbridge, VA
    I port matched the manifold to the flange using a 3 inch hole saw. The flange bore will guide the hole saw. You’ll still have to sand it smooth and polish a bit as the bits of aluminum will make the opening rough. But I found that to be the easiest way to port match.
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    Something to consider is if you find the 70mm flange only, like myself, is you simply clock the TB ~5mm over from the 70mm holes drill and tap and now have a universal multi-tb use adapter plate which helps with resale too. All plates are aluminum so easy to do, and will not need to be bored out itself as hole is still bigger then 75mm.
    At that time I didn't have a ~3" holesaw to portmatch the manifold so marked out a hole and a ~tungsten bit on a die grinder made short work of the cast aluminum manifold and smoothed it out as much as possible.
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by A1 A2 German View Post
    I hope to just cut the original (have a spare) manifold and weld on a flange (port matched to my 75m TB, drill/tab). That also opens up the diameter into the manifold (rather than stepping down, creating another flow loss).
    Probably better than spending $100 or so on a 4x4 inch plate of aluminum with a few holes in it.
    Either than, or make the adapter myself from 10mm alu bar stock. hole saw for rough work, then tungsten bit or put on lathe.
    05 Golf TDI
    Veteran Member Three Rings ChanceA4Parks's Avatar
    Jan 22 2018
    Ridgeland, MS 39157
    Get a router and router table. Aluminum is quick work for a router and it's incredible versatile. You can purchase flush bits to port match and step downs to widen a hole. The finished product doesn't have to be polished or sanded, because it will be as smooth as your guide part. I did a post a while back "kind of" showing how I do it. I've been able to "machine" my own 2.7t compressor housing to fit my RS6 turbos. I port matched an 2.7t cylinder head to a 2.8 head to match the rs4 mani. Next is the throttle body. I'll take a few more photos this time if anyone is interested.
    Sent from my SM-T700 using Audizine mobile app
    Only owned 1 Audi so far.....It won't be my last!!!
    Built 2008 Audi RS4 with a 2.7t swap. JE Pistons (9.0:1 83mm)and Pauter Rods. 2.8 heads with Supertech Valvetrain (stock size) and RS4 Cams. TTE780+ turbos, RS6 Throttle Body, Snow Performance Stage 2 Meth Injection, and Motoza Tuned. The Tuner Inlets and intercooling piping. ID1000 Injectors and 034 Surge tank. Just use your imagination on everything else!!!
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by ChanceA4Parks View Post
    For now I stick with my tungsten tool and a power drill. Not as 'nice' and probably more painful. Just not enough room for another tool setup.
    But you are right, alu is nice to machine (compared to turbine housings for example); did port match my current manifold to the AEB head I am running. And a few other heads (i guess first was a 3 liter swap into a Mercury cougar (with the Mazda/Ford 2.5/3.0 engine family).
    05 Golf TDI
    Jul 04 2012
    Woodbridge, VA
    Off topic but you seem to know a thing or two about taking down aluminum. What would be the easiest approach to polishing the inside of an rs4 throttle body y pipe?
    Jan 22 2018
    Ridgeland, MS 39157
    Start by working your way down grits with carbide bits(finer and finer). Then work your way down with (scotch bright style) ball drill attachments (harbor freight) and a heavy rubbing compound. Move to polishing balls on a drill with heavy then light rubbing compound. Finish with a good aluminum polish. Same will work with polishing any aluminum, but use sand paper and automotive scotch bright pads on large areas.
    Jan 22 2018
    Ridgeland, MS 39157
    I think I'll be able to mod the RS6 throttle body to work on the 2.7t. Ive got the tb sliding into the oem RS4 tbb. I should be able to use the original bolts and holes. It looks like a big enough difference to make some extra horses for sure. I also modded the 034 carbon y-pipe to accept a 102mm inlet and 75mm outlets. Im ready to drive this thing again
    Jan 22 2018
    Ridgeland, MS 39157
    Here's the RS4 pressure y (ported to match throttle body) ,the RS6 throttle body, and the RS4 intake manifold all playing nice together. I just need to port the intake to match tb. Polish everything and then moving on to the next task at hand.
    Feb 20 2010
    Brighton, MI
    Nicely done! What size is the RS6 TB (ID obviously)?
    05 Golf TDI
    Jan 22 2018
    Ridgeland, MS 39157
    Ill measure it to be exact but I want to say its 3.5" or 89mm.
    Jul 04 2012
    Woodbridge, VA
    How are you sealing the TB to the TBB?
    Jan 22 2018
    Ridgeland, MS 39157
    Im actually going to go the oem way. Oring on the inside edge of the tbb (I'll notch a small track for it to rest in. Slide the tb into the oring. Its actually pretty damn snug and sealed already. I'll rather be safe though.
    Jan 22 2018
    Ridgeland, MS 39157
    I changed how I am going to seal everything up. I will weld 90mm v-band clamps to both sides like I have done on the intake mani side. There is also a couple of pictures of how I used a router to port the intake mani to the new size. There's some measurements in there as well 20190531_020824.jpeg20190529_224218.jpeg20190531_020814.jpeg20190529_202609.jpeg20190529_202627.jpeg20190529_202604.jpeg20190529_202845.jpeg20190529_015332.jpeg20190529_015358.jpeg20190529_023051.jpeg
    Feb 20 2010
    Brighton, MI
    Sidenote: what is the tool in this photo? https://www.audizine.com/forum/attac...0&d=1559323458
    05 Golf TDI
    Jan 22 2018
    Ridgeland, MS 39157
    Its something like this-
    https://www.rockler.com/pattern-flus...ight-1-4-shank
    It attaches to a router. You have to make sure the bearing is on the side that is the closest to the router chuck.
