Hi - I need to replace the turbo/waste gate/exhaust manifold assembly on my B8 due to a leaking wastegate. It has been in the Audi dealer and a local garage and they both diagnosed the same thing. I have decided to do the job myself and have the new assembly and installation kit from ECS and I'm ready to start the job.
There are a great set of step by step instructions in the Audizine B8 A4 DIY: K04 Installation thread on this forum and I posted some questions there a few weeks ago without response so I thought I'd ask here:
1) The instructions in the K04 thread is for those upgrading to a K04 turbo, but I am assuming all the steps are the same as someone just replacing the turbo with an OEM one. Is there another thread or web link detailing the steps? This is the best one I have found so far. https://www.audizine.com/forum/showt...4-Installation
2) Since I am not replacing the cat or down pipe, can I just undo the four turbo to cat bolts and replace the turbo? Is there enough room to get the turbo out? If not can I undo the four turbo to cat nuts and unhook the hangers to drop the exhaust?
3) Do I have to remove the O2 sensor from the cat?
4) From reading this, it seems to be a real PITA if the nuts come off the studs holding the manifold to the block. Any tips there to ensure the studs come out with the nuts? I am guess there is not enough room to get an impact wrench in there and heating the nuts would make the nuts more likely to thread off the studs. Soaking the studs and not the nuts with PB blaster?
5) is there a link to all the torque settings for the bolts during reassembly?
Thanks,
Paul
