The attached Google docs spreadsheet lists out every speaker in the car by location along with guidance of the frequency response it's expected to play, the impedance of the driver, and how much power it's rated for. The factory driver power ratings are based on some units I found with power limits on the part number sticker, not on actual measurements. Nor do I know the amplifier's actual power outputs, but I'm assuming as long as your replacement drivers are rated the same or better, you should be fine. I tried pretty hard to isolate each driver to my microphone using a clay pot lines with foam placed over the driver during measurement but other sound still sneaks in. This is especially a problem on the door midrange as the door woofer vibrates the entire door panel.
Anyway I hope this is useful for anyone looking to do some upgrading. I myself am about elbow deep into this project on my own car and will dive head first into the rabbit hole this weekend.
https://docs.google.com/spreadsheets...it?usp=sharing
