I tried to connect my elm327 Bluetooth scanner to the OBDII port and it would not initialise, I believe it is a hardware issue with the port as I have had connection issues with my Ross-Tech cable and an odd code like pin30 low voltage. So how do I remove the port so I can confirm wiring to all the pins are snug, in the unlikely event I have to replace the OBDII port are they available as a spare.
