Hi all,
I have a fairly new to me 2013 Audi S7. After a month of ownership I am starting to get several faults when starting the car in in the morning. These faults go away when I drive the car for 20 min and then restart it.
I get the following errors:
1. Audi active lane assist : currently not available
2. Acc and Audi braking guard : unavailable
3. TPMS Tire pressure : System malfunction
4. Sport differential : System fault (this one alarms me the most)
5. Air suspension : System fault
This is obviously not normal. I’ve video taped this occurring at least once on my phone.
VIN: WAUW2CFC9DN098586 Mileage: 100083km-62188miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
22-AWD -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
82-Heads Up Display -- Status: Malfunction 0010
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
8E-Image Processing -- Status: Malfunction 0010
Address 01: Engine (------CEUC) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 014 B HW: 4H0 906 014
Component: 4.0l V8TFSI / H62 0009
Revision: NCH62---
Coding: 1A2500326546000E1000
Shop #: WSC 29708 001 1048576
ASAM Dataset: EV_ECM40TFS0114G0906014B 001009
ROD: EV_ECM40TFS0114G0906014B.rod
VCID: 2142716F30518242F2-8074
3 Faults Found:
11504 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 00 [032] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 99317 km
Date: 2019.05.01
Time: 09:03:22
Engine speed: 145.50 /min
Normed load value: 12.2 %
Vehicle speed: 0 km/h
Coolant temperature: 10 °C
Intake air temperature: 12 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 9.400 V
Unlearning counter according OBD: 38
Tumg: 11.3 °C
Outside air temperature via CAN: 11.3 °C
Engine oil temperature: 10.4 °C
Time since ignition off: 65535 s
Adjustment requirements for basic setting-Bits 0-7: 50
Rear cat conv temp main cat conv model value: 11.24 °C
Coolant temperature at engine start: 10.5 °C
9025 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 00 [096] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 99451 km
Date: 2019.05.05
Time: 09:57:28
Engine speed: 1288.00 /min
Normed load value: 16.9 %
Coolant temperature: 18 °C
Intake air temperature: 19 °C
Voltage terminal 30: 13.452 V
Unlearning counter according OBD: 39
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
4172 - Manifold Pressure / Boost Sensor (G31)
P0236 00 [172] - Implausible Signal
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 99775 km
Date: 2019.05.05
Time: 17:32:44
Engine speed: 674.00 /min
Normed load value: 10.6 %
Coolant temperature: 61 °C
Intake air temperature: 53 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 13.758 V
Unlearning counter according OBD: 40
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 4G1 927 156 S HW: 0B5 927 156 J
Component: 0B5 40TFSINAR H01 0010
Revision: --H01---
Coding: 000001
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL501021 001015
ROD: EV_TCMDL501021.rod
VCID: 3D7AAD1FACE9C6A2F6-8068
1 Fault Found:
8448 - Implausible Data Received from Engine Control Module
U0401 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 39
Mileage: 99317 km
Date: 2019.05.01
Time: 09:03:26
Engine speed: 1271 /min
Transmission input speed: 1271 /min
Transmission output speed: 0 /min
Engine torque: 8 Nm
Transmission fluid temperature: 18 °C
Accelerator position: 0.0 %
Clutch status: Beide Kupplungen offen
Voltage terminal 30: 14.000 V
Voltage_5V_CAN_pressuresensors-Param to DOP: 4.904 V
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 J HW: 4G0 907 379 J
Component: ESP PREMIUM H09 0361
Revision: -------- Serial number: --------------
Coding: 65B64F03A66DF2C04B00
Shop #: WSC 29087 001 1048576
ASAM Dataset: EV_ESPPremiAU57X 004028
ROD: EV_ESPPremiAU57X_004_AU57.rod
VCID: 3874BC0B83CBE38A25-806C
3 Faults Found:
0604 - Tire Pressure Warning
C102D 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 175
Mileage: 98468 km
Date: 2019.04.22
Time: 16:49:12
VzRef: 43
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 01
F-Type: 28
Uz: BB
0787 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 199
Mileage: 98877 km
Date: 2019.04.28
Time: 11:50:17
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 00
F-Type: E6
Uz: 86
0732 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 12
Reset counter: 199
Mileage: 98877 km
Date: 2019.04.28
Time: 11:50:19
VzRef: 00
Bit Info 1: 80
Bit Info 2: 6F
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 01
F-Type: 04
Uz: 96
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 AF HW: 4G0 820 043 AF
Component: KLIMA 4 ZONEN H13 0076
Serial number: 09011300040390
Coding: 688320BE5D
ASAM Dataset: EV_AirCondiComfoUDS 002036
ROD: EV_AirCondiComfoUDS_002.rod
VCID: 63CE3B676ACDD052A0-8036
1 Fault Found:
0369 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 173
Mileage: 98420 km
Date: 2019.04.22
Time: 07:05:10
Voltage terminal 30: 13.87 V
Outside air temperature: 9.5 °C
Engine speed: 1296 /min
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H19 0440
Serial number: 00000000000000
Coding: 7601010101
Shop #: WSC 24634 002 1048576
ASAM Dataset: EV_AdaptCruisContrAU57X 002015
ROD: EV_AdaptCruisContrAU57X_002.rod
VCID: 28546C4B536B730AB5-807C
10 Faults Found:
22016 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 173
Mileage: 98420 km
Date: 2019.04.22
Time: 07:05:10
Control Module temperature: 8 °C
Voltage terminal 15: 13.935 V
Velocity_vehicle_reference: -0.01 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
22272 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 173
Mileage: 98420 km
Date: 2019.04.22
Time: 07:05:10
22528 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 173
Mileage: 98420 km
Date: 2019.04.22
Time: 07:05:10
22784 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 173
Mileage: 98420 km
Date: 2019.04.22
Time: 07:05:10
23040 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 173
Mileage: 98420 km
Date: 2019.04.22
Time: 07:05:10
23552 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 173
Mileage: 98420 km
Date: 2019.04.22
Time: 07:05:10
23808 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 173
Mileage: 98420 km
Date: 2019.04.22
Time: 07:05:10
24064 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 173
Mileage: 98420 km
Date: 2019.04.22
Time: 07:05:10
24320 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 173
Mileage: 98420 km
Date: 2019.04.22
Time: 07:05:10
105472 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 199
Mileage: 98877 km
Date: 2019.04.28
Time: 11:50:18
Control Module temperature: 9 °C
Voltage terminal 15: 10.376 V
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372NAD000BZ
Coding: 0004FC
Shop #: WSC 51376 000 1048576
VCID: 3874BC0B8BCBE38A25-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Component: E221 - MFL H08 0010
Serial number: 24 03 2016 C0073084
1 Fault Found:
01426 - Controls in Steering Wheel (E221)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 5
Reset counter: 40
Mileage: 98200 km
Time Indication: 0
Date: 2019.04.09
Time: 14:39:22
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 932 L HW: 4G8 920 932 L
Component: TBenRdwAccNv H76 0515
Revision: 28460208 Serial number: 658101212596020
Coding: 038F01079F530008020300
Shop #: WSC 29088 001 104857
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K.rod
1 Fault Found:
16776969 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 173
Mileage: 98420 km
Date: 2019.04.22
Time: 07:05:09
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
Component: 4 Wheel Drive H15 0013
Serial number: 000712120001257
ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
ROD: EV_AllWheelDiffeQSPFR.rod
VCID: 27566F775E757C72BC-8072
1 Fault Found:
0377 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 11
Reset counter: 199
Mileage: 98877 km
Date: 2019.04.28
Time: 11:50:18
