Results 1 to 35 of 35
    May 13 2019
    2014 Audi S4 and a few Porsches
    NYC area
    oil consumption...is it an issue?
    I have a 2014 S4 with about 86k miles. The car has been flawless and problem free--really, nothing has gone wrong or needed repair. I follow the regularly schedule maintenance regime, all at Audi dealers (I know I am paying up for it), and the only things I have changed are brake pads twice and rotors once (both done at independent shops). About a month ago, just before I brought the car in for the 85k service, I got a low-oil light for the first time ever. So I added a quart. That's that. A few weeks later the car had the 85k service, which of course includes an oil change. Today, after less than 1,500 additional miles, the low-oil light reappeared.
    I assume the dealer topped off the oil at the recent service (for better or worse, I did not check it; never have).
    Are these cars known to start to consume oil? If so, any way to address it now? I recognize adding a few quarts every 10k miles is no big deal. It's not what I am used to, but still no big deal.
    Looking forward to hearing any thoughts.
    Thanks so much.
    Apr 04 2017
    10 S4, 01 S4, 14 328d
    Chicago IL
    My car shows no real issues and I add a half quart roughly every 2000 miles. I believe mine consumes more than most, but it hasn't been definitively linked to any problems, although I strongly wonder if I have a bad PCV.
    Veteran Member Four Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    I've found certain oils to burn much faster than others, it's possible whatever the dealer used burns faster than what u had.
    Don't interpret that as faster burning oil being worse for your engine, it just has different properties.
    Personally I've found Castrol edge to burn pretty slowly
    FBO B8. ~ 10.95@126 ~ 2.96s 0-60 ~ full weight street tires.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Almost all oil consumption issues with this engine are due to a faulty PCV valve. Based on your mileage and history.I would bet the ranch that the PCV valve is bad. To replace it requires removing the Supercharger. You can also expect the t stat to fail shortly,I recommend replacing the PCV valve ,T stat ,water pump and coolant tube. If you expect to keep the car for some time, have the oil in the in the SC changed as well. Your 2014 should have the revised version PCV valve ,so replacing it with the same type will not require ant VCDS change
    Sep 28 2013
    B8S4, C300 4matic, Honda CR-V
    I've had oil issue before with a few Audis I've owned. First time was PCV, but the second Audi had drain plug leak being soaked into the padding of splash shield. I've never had an oil mark on my parking spot because it was all absorbed. Checking the drain plug might be worth it, but PCV is more likely.
    interior and license plate LED lights, E-code headlights with 6000k bulbs, AWE catback, H&R OE springs, APR Stage 2, 19" BBS RGR (summer), stock 18" with 15mm and 20mm spacers (winter), carbonio intake, lots of VAG mods, 35% tints all around, lots of road rash, 034 transmission mount insert, SPC ACS, Spulen rear diff mount, Bilstein sport shocks, CR-15 strut brace bar
    Apr 04 2017
    Chicago IL
    Quote Originally Posted by Dr GP View Post
    I've seen more than a few instances where people change their PCV and continue to burn oil at the same accelerated rates. So while its a possible culprit, I think you're making too large of a blanket statement here.
    Veteran Member Four Rings Silver Streakin's Avatar
    Mar 05 2004
    B8 S4, 17 Expedition EL, 2009 328ix coupe
    NoVA
    5k intervals and I usually add around 3500-4000 into it. 1/4 to 1/2 qt to get back into full on both the stick and MMI.
    Check your oil often. It's in the MMI.
    Like others said, if it's more than that, then look into the PCV. But you'll need to check oil more often to know if you have an actual issue.
    And I'd recommend more frequently changing it. 10k is long, especially if you're not stock.
    2011 S4, 6M, BB/panda, Sport diff, ADS, B&O | UniTronic stage 3 Dual Pulley | MercRacing HX | RocEuro intake | AWE Track & DPs resonated | H&R c/o w/Bilstein B8 rears| 19" VMR 710 & 19" Peelers | 034 trans insert | AK brace | CR15 bar | DEVAL CF Diffuser
    SOLD 2007 S4 DTM, Phantom Black Pearl, manual | JHM | FI | H&R | VMR | 034
    RIP 2001.5 A4 1.8TQMS, Silver/Ebony | APR stage 3 | STaSIS Tracksports | StopTechs
    SOLD 1995 90
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Buy a dipstick, so you will know accurately the actual level of oil.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Mar 28 2016
    Castrol tends to burn. Switch to Liquimoly or Motul and that will help.
    Established Member Two Rings B8S4inKC's Avatar
    Jul 31 2018
    Lawn Mower
    Kansas City
    Quote Originally Posted by hilmar2k View Post
    +1 for Liquimoly
    Current: 2019 S4
    Gone but not forgotten: 2011 S4 (6 MT)
    Aug 23 2018
    Yorkshire England
    I have a 2009 A6 with the same engine. Mine was using a litre of oil every 400 miles. I had the PCV swapped about 18 months back and it made no difference but did fix a coolant issue.
    After trying various piston soaks to try and free the piston rings i found that a strong engine oil flush before oil change made a difference. I can't remember the make of flush that I used, my local mechanic gave it to me.
    But i now get 700 miles to a litre.
    I've resealed chain cover and I need to replace cam cover gaskets.
    All that and some regular high rev runs can help.
    If i can get to the 1000 mile mark before topping up i will be a happy fellow.
    I've had the car for 2 and a half years by the way.
    Sent from my SM-G960F using Audizine mobile app
    Aug 17 2010
    Vancouver, BC
    Another PCV solution to oil consumption story here. Had the Supercharger ported last year and did the PCV at the same time. Prior consumption was about a US quart per 1500 miles (since new) down to zero in 5000 miles since the swap. Experiencing the same level of oil consumption on our mostly stock 3.0T Q5 so planning to do the PCV on that one too, maybe even sneak in a supercharger port job while the Mrs. isn't looking!
    2011 S4 (Cdn Spec) premium, 6MT, Quartz, Eurocode SS, APR Ultracharger, DP Stage 2 & CPS, Carbonio intake & exhaust, Ported S/C by Matty
    2013 Q5 3.0T S-line, EPL Stage 1 (the missus' car) 2007 RS4 (sold)
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by GandalfTheIbis View Post
    There obviously can be other reasons for this and other engines to burn oil. However ,based on what I have been seeing on the B8 S4 Forums since 2009, the PCV valve is the most likely and most common cause of the issue.The vast majority(including myself) have seen a major reduction of oil consumption after replacing the PCV valve,This is especially true with the earlier cars that do not have the updated PCV valve, It would be my first step.If it doesn't solve the problem,you probably are looking at something more serious.I would also switch to a higher viscosity oil as well.At least in warm weather.
    Apr 04 2017
    Chicago IL
    @OP, try pulling your oil cap off. Rotate counter clockwise so that you know it’s loose and then when you pull up if it feels like it takes more than 3-4lbs or pressure then it is likely you have a bad PCV. If it pulls off easily then it’s probably okay.
    Senior Member Three Rings nitro_rider2001's Avatar
    Dec 11 2008
    DFW
    Had a catch can on my B7 A4 and it fixed this issue.. currently starting to see a bit more oil consumption after going dual pulley last month. Do you guys recommend going catch can route on this platform as well?? or just replacing PCV
    2016 Glacier White RS7 - Unitronic Stage II | TS1 Turbos | Unitronic Downpipes | Milltek Non-Res Exhaust | Boosted Euro (Mirza) TCU Tune | KW HAS | Dillinger 3 piece wheels
    2014 Ice Silver S4 6MT - Gone
    2007 Brilliant Black A4 S-Line Ti 6MT - Gone
    1999.5 Volcano Black A4 5MT - Gone
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Either or both should help. I believe more owners have replaced their PCV valve then have added a catch can.
    Aug 23 2018
    Yorkshire England
    Just a quick update.
    After replacing chain cover seals I now have achieved over 1000 miles between top ups. How much over I still don't know, it's still going. 🤞
    Dec 31 2017
    VA
    I had the same issue last week. 2013 B8.5 S4, had 85k Audicare service done recently and after 1500 miles received a "low oil warning - add 1 quart." First time I had received the warning in 3 years of ownership. I added a quart of Castrol and it's ok for now. If I do have to replace PCV, T-stat, and water pump, what are the estimated costs?
    Also I am APR stage 2 DP, TCU tune and CPS. Upgrades were completed last summer at a reputable Euro shop. Car had about 75k miles when I had it tuned.
    May 22 2015
    Colorado Springs
    Guys, unlike BMW, Audi was nice enough to leave oil dipstick tube. So, go get oil dipstick and do manual check often.
    Also, move away from that POS Castrol 5W40. Castrol 0W40 is much better option due to lower evaporation loss and especially Castrol Edge 0W30, except price of 0W30 fluctuates a lot.
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Quote Originally Posted by edyco View Post
    I was running edge 5/30, but wanted to change to 5/40. Didn't have it the day I picked up oil, so got 0w40. Well see how it is.
    Sent from my VS995 using Audizine mobile app
    May 22 2015
    Colorado Springs
    Quote Originally Posted by Jayz691 View Post
    0W40 is much more sophisticated oil.
    Which Edge 5W30 were you running?
    Jan 21 2018
    frackville, pa US
    Honestly, I can't rem which variety it was. Either reg castrol edge, or the high mileage. Its also in a b7 a4, I just came across this thread. I was getting a bit of consumption before with mobile 1. So switched to castrol. Wanted to run 5w40 in summer, but like i said, they were out.
    May 22 2015
    Colorado Springs
    May 22 2015
    Colorado Springs
    That Castrol 5W30 should not get into European engines, of any variety, under any circumstances. No wonder you had oil consumption.
    That is so called energy conservibg, ILSAC GF-5 oil. Always make sure there is VW502.00 on the back label and preferably MB229.5 approval.
    Junior Member Two Rings Langley1023's Avatar
    Jun 03 2019
    Manchester NH
    Definitely start with buying a dipstick. I just bought a 2016 S4 and had a low oil light issue. Sometimes it's the hood latch, PCV valve, oil level sensor, etc. I took mine into Audi to have everything looked at because it's still under the warranty. It was actually caused by the previous dealership putting an extra 3/4ths a quart of oil into my car. Why that triggered the low oil light is beyond me, but the sensors are sensitive. Anyways, it's been fine ever since they drained some oil out of the car. Best of luck!
    Established Member Two Rings Sleipnir's Avatar
    Feb 02 2019
    California
    An often overlooked aspect of excessive oil consumption in VAG cars are the piston rings. VW/Audi installed looser piston rings in a lot of their engines to gain better fuel mileage. Basically, they traded fuel consumption for oil consumption.
    But...my family has driven VAG cars for decades. I don't remember a single one of them NOT having a spare quart of oil in the trunk.
    These cars burn oil, it's just a fact of life. 🤷*♀️
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by Sleipnir View Post
    AFAIK, 3.0ts burn oil, but not at the alarming rate caused by piston rings as in the 2.0t engines, which warranted a lawsuit and rebuild.
    I'm on 5w-40 molygen now, and I don't seem to have burned much at all in the past few thousand miles. Highly recommend that oil. I burned through motul very fast.
    Veteran Member Three Rings Audi Advocate's Avatar
    Mar 26 2005
    2012 B8 S4, 2012 A3 Wagon
    Quote Originally Posted by Morritse View Post
    2nd ^^^^
    … I use MOTUL Synthetic and my (tuned) 2012 eats a quart every 2 months or more when driven hard/tracked.
    Current #1 2012 S4 3.0T DSG Technik with Unitronic Stage 1+, Milltek res., KW V2 coilovers, StopTech BBK, Alu Kreuz, H&R Rear Sway, BBS CH-R's, Michelin PS4S, Disabled wink, De-badged, ZIZA LED's, 30% tint and fancy aluminum pedals - Current #2: Wife driven 2012 A3 2.0T Progresiv- stock
    Jul 21 2004
    South Florida
    The 2.0t burned oil because of poorly manufactured and designed pistons and rings. I was one of the people that was burning a quart ever 200 miles... yes every fuel stop i had to put a full quart in.
    Ive never known the 3.0t to have excessive oil consumption issues that wasnt related to a bad pcv. Going through one quart between a 7k or 10k mile oil change is not excessive imo and in line with many cars from other manufacturers.
    Mike
    2018 Audi S5
    Gone-
    May 22 2015
    Colorado Springs
    Quote Originally Posted by Audi Advocate View Post
    2nd ^^^^
    If you see change with consumption using Motul, do not get surprised or worried. Motul recently changed formula, and unfortunately it’s not for better.
    Jul 21 2004
    South Florida
    I have the same minor consumption with motul 300v double ester as i have with m1 0w40. No change in startup rattle either. No big deal as i wasnt expecting anything magical.
    2018 Audi S5
    Gone-
    May 22 2015
    Colorado Springs
    Quote Originally Posted by bhvrdr View Post
    300V I think is not changed. X-Clean and X-Cess are completely reformulated and they are not anymore majority PAO based.
    As for 300V, did you do UOA? They are great on track but not so much for regular OCI due to oxidation.
    Jul 21 2004
    South Florida
    I talk to the folks at Motul and they said it is perfect for 5000 mile oil change intervals if you happen to not be doing a track day that month
    Similarly a lot of people thought you had to change rbF 600 brake fluid every 6 months or so and motul said it's actually no different of a change than any other fluid and once a year is fine
    Sent from my SM-G935V using Tapatalk
    2018 Audi S5
    Gone-
    Nov 27 2015
    UK, West Berks
    Just an observation: Audi did revise the oil control ring (at least according to the SSP) in the evo version of the V6 engine (which did not make it into NA S4/S5), which does imply that someone felt that there was improvement to be had over the previous engine.
    2015 monsoon grey S5 sportback (yes the one with 4 doors)
    - MRC stage 2 (189mm Vdamper/Fluidampr crank pulley)
    Veteran Member Three Rings SouthernBoy's Avatar
    Jun 03 2014
    Virginia
    Not for me. I change the oil every 5,000 miles, which works out to around once a year, and what comes out measures out to what went in. In other words, it burns no oil that is noticeable or measurable.
    In the final seconds of your life, just before your killer is about to dispatch you to that great eternal darkness, what would you rather have in your hand? A cell phone or a gun?
