Results 1 to 10 of 10
    Oct 29 2016
    CA
    B8.5 S5 headlight bulb
    Hey, I’m looking for a headlight bulb for a 14 s5, I checked online.. but cant seem find the oem color to match the other side. Shoot me a price.
    Veteran Member Three Rings PEM's Avatar
    Jul 17 2014
    NoVA
    You should just replace both bulbs at the same time. Even if you get the same bulb, color will still most likely not be the same.
    Oct 29 2016
    CA
    Ahh got it, thanks
    Veteran Member Four Rings Neil F's Avatar
    Jan 13 2017
    marlton/nj/usa
    Quote Originally Posted by PEM View Post
    Not necessarily. One of my bulbs went out and I did some reading on what the stock color temperature was. Posts indicated D3S - Philips HID X-treme Vision +150% 42403XV2C1 matched. Note of course they come in a two pack. I did only replace the one burnt out bulb and it is a match. If it had not I would have done them both (Glad it was a match as pulling the housing was a bit of a PITA)
    2014 Estoril blue Cab Chestnut brown interior
    Jul 17 2014
    NoVA
    Hence "most likely not be the same". These lights do have an x amount of hours to break in before they're at their true color and brightness. At least that was the case for my aftermarket bulbs.
    Sent from my SM-G955U using Tapatalk
    Established Member Two Rings S5_SID's Avatar
    Apr 07 2018
    2011 S5 Quartz Gray Cab
    Orange County, CA
    I went with deautoled headlight bulbs and could not be happier. The bulbs are brighter than stock, with color matched to eyelids. I went through replacing one bulb and the color was off due to the other bulb being older.
    Keep Deep Sea Alive!
    Deep Sea Diver 🇺🇸
    2011 S5 Cabriolet • Quartz Gray Metallic • 3.0T •B&O•Sport Seats• Peelers•Carbon Inlays•Mods to come...
    Senior Member Two Rings AWEs5's Avatar
    Jul 18 2017
    Gardena CA
    Glad I saw this post. My left just went out a few days ago. This code will go away if I just replace it right?
    2013 Audi S5 Premium Plus | H&R springs | AWE S-Flo CF intake | AWE Touring Exhaust 102mm Diamond Tips | AWE non-resonated downpipes |
    Jul 18 2017
    Gardena CA
    2013 s5 by the way.
    Jan 13 2017
    marlton/nj/usa
    Yes replace the bulb and the bulb out indication will stop
    Jul 18 2017
    Gardena CA
    Quote Originally Posted by Neil F View Post
    Thank you!
