Results 1 to 9 of 9
    Junior Member Two Rings
    May 05 2017
    red deer,alberta
    Torque wrench for oil filter and drain plug..recommendations
    I did an oil change on my B8 S4 yesterday . My two torque wrenches are 1/2" snap-on (click-style) and a 3/8" Westward.......they both started at 25ftlbs.....so above the recommended torque for oil filter (18ftlbs) and 6mm allen drian plug (22ftlbs). What torque wrench do you use? Does Schwaben have a torque wrench that is suitable for the lower ratings? or could I go to a snap-on 1/4"drive to get lower (18-22ftlbs)?
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    Oil filter is 22 ft-lbs. But yeah a good 1/4” drive would do the trick also.
    Registered User Two Rings
    Apr 03 2018
    Los Angeles, CA, USA
    Stahlwille makes awesome wrenches (and they supply Audi’s factory&dealers), and are pretty expensive but totally worth it. Eg https://vw.snapon.com/SpecialToolsDe...temId=63420183
    We’re using this (and the 40-200Nm one) and they’re amazing!
    Otherwise there’s tons of others that are cheaper, can’t comment how good they are.
    Senior Member Three Rings Jk79's Avatar
    Sep 20 2018
    Chicago
    Harbor Freight actually has very good torque wrenches in a variety of Inch, Ft and Nm ranges under $20. While I normally don’t buy automotive tools there they are tested to be extremely accurate.
    2018 RS5
    2014 S4 - EPL Stage 2+ (SOLD)
    May 05 2017
    red deer,alberta
    Thanks very much for the info......the Stahwille makes some impressive gear. I ended up going with a Schwaben brand,as it was one that a local german shop carries. I'm hoping the quality is ok.
    Veteran Member Four Rings TFSI's Avatar
    Dec 16 2009
    Some car
    MD
    Harbor freight lol
    3/8 version starts pretty low and under 15 bucks
    Sent from my SM-G973U using Audizine mobile app
    Jul 21 2004
    South Florida
    As an fyi imo it only makes sense to buy tq wrenches from home depot. They still offer lifetime warranties on them where lowes and most others lowered the warranty on precision items to 5 years or less. At some point you will need to replace your torque wrench and ive had home depot just walk me back and pick out a free replacement. Its saved me a couple hundred in free replacements so far
    Mike
    2018 Audi S5
    Gone-
    Senior Member Three Rings MME1122's Avatar
    Mar 26 2016
    2011 Jeep Liberty
    I have this one: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Certainly not professional grade but it's affordable and it's never let me down in 3 years so far. It's been good for every job I've done on the car. The oil filter and plug are a little towards the low end, ideally you want to be using a torque wrench in like 25-75% of it's range. But those parts aren't critical enough to need absolute accuracy, it's not like building an engine.
    Veteran Member Four Rings Silver Streakin's Avatar
    Mar 05 2004
    B8 S4, 17 Expedition EL, 2009 328ix coupe
    NoVA
    1/4 turn past snug.
    or HF. Someone on YouTube did a comparison and HF was spot on the big boys. Use it for a few years , then just use it as a breaker bar.
    2011 S4, 6M, BB/panda, Sport diff, ADS, B&O | UniTronic stage 3 Dual Pulley | MercRacing HX | RocEuro intake | AWE Track & DPs resonated | H&R c/o w/Bilstein B8 rears| 19" VMR 710 & 19" Peelers | 034 trans insert | AK brace | CR15 bar | DEVAL CF Diffuser
    SOLD 2007 S4 DTM, Phantom Black Pearl, manual | JHM | FI | H&R | VMR | 034
    RIP 2001.5 A4 1.8TQMS, Silver/Ebony | APR stage 3 | STaSIS Tracksports | StopTechs
    SOLD 1995 90
