Results 1 to 9 of 9
    Sep 28 2017
    Attleboro
    P2006 and p2007 code
    Hello , I hoping someone can help me out. I'm getting two codes.
    P2006 witch is turning the mill on.
    P2007 that is intermittent
    First I cleared codes and they returned within 20 miles of driving. Their is no rough idle and seems to run fine.
    I check all vacuum lines that run from the solenoid to the actuator. Didn't find any leaks.
    I looked all around engine bay for any broken vacuum lines and didn't find anything.
    I check the solenoid with vacuum and it holds pressure. I then applied power and it released vacuum. All seems well with the solenoid
    I then check both actuators and both hold vacuum.
    My next guess would be the sensors?
    Any help would be appreciated.
    Thanks
    Mike
    Sent from my SM-N960U using Audizine mobile app
    Veteran Member Four Rings Rodizzle's Avatar
    Jun 17 2015
    Bayarea
    You could check your sensor by using a multimeter. Check the Intake Manifold Runner Position Sensor electrical terminals 2 to 3 for resistance.
    Specified value are anywhere from 7-25 ohms (@ ~ 20° C)
    Then check the Intake Manifold Runner Position Sensor electrical terminals 1 to 3 for resistance.
    Specified value are 244 [+/- 40] ohms .
    Anything out of that range I’d just replace the sensor
    Sep 28 2017
    Attleboro
    Thank you I will try that tomorrow!
    Sep 28 2017
    Attleboro
    Quote Originally Posted by Rodizzle View Post
    I check the ohms on the sensors.
    Bank 1 is 140
    Bank 2 is 134
    I check ohms at the connection terminal
    Bank 1 and 2 are both 189
    That is telling me both sensors are bad ?
    Jun 17 2015
    Bayarea
    I’m not saying they’re bad but it’s a start to figure out your issues .
    You could also check Intake Manifold Runner Control valve by :
    Disconnect the Intake Manifold Runner Control Valve electrical harness connector. (2)
    Check the Intake Manifold Runner Control Valve terminals 1 to 2 for resistance.
    Should be 25 [+/-] 10 ohms.
    Sep 28 2017
    Attleboro
    I just checked the connection terminal and I get .OL
    On the solenoid I get 22 ohms
    Jun 17 2015
    Bayarea
    I’m kind of leaning to your sensor being faulty or about to fail , specially having both 2006 and 2007 codes (both banks)
    Maybe someone else could comment on this
    Sep 28 2017
    Attleboro
    That's what I was thinking too. But I would think I would get another code showing a circuit fault?
    At first I thought vacuum line or actuator. All seems to be working like it should. I cleaned the intake runners and put vacuum through the actuators mutiple times and all seems to work . I'm putting it back together. I'll see if I get another code along with it after a bit of driving.
    Thanks for help
    Sep 28 2017
    Attleboro
    So after replacing both actuators , sensors and solinoid I was still getting the p2006 p2007 code. I found the the heater valve was leaking vacuum. It would not operate. Replaced it and 80 miles later so far no more codes.
    Hopefully this helps someone else !
