Page 1 of 6 123 ... LastLast
Results 1 to 40 of 220
    Apr 16 2019
    PCV / Oil Separator replacement DIY writeup, pics and tips
    ADDENDUM: if the pictures go bad, you can still get them from here https://drive.google.com/open?id=17Y...-wo9cOHcPqzLJ0
    Before we start, a usual disclaimer - I am not a mechanic, do you at your own risk and do not do unless confident in your skills. This is not an official nor recommended guide. I'm not responsible for any damage or loss resulting from following this information.
    Credit: Thanks all members of Audizine and contributors on the net!
    Since we will be removing a fuel line and TFSI engine operates under a very high fuel pressure, begin with relieving the fuel pressure by pulling fuel pump fuse (it is in the driver’s side fuse block), then start the car and let it run until it dies. Then, remove the supercharger - https://www.youtube.com/watch?v=xyZLjJOxBvQ and https://www.audizine.com/forum/showt...l-photos-tips!
    A time lapse of PCV replacement:
    https://www.youtube.com/watch?v=1Lil3wf_2m4
    Shared wisdom:
    https://www.audizine.com/forum/showt...e-coolant-loss
    Special tools:
    10mm triple-square bit (2-3” long) from AdvanceAutoParts
    Also useful a band clamp removal tool, ¼” ratcheting wrench, a long screwdriver.
    Parts:
    PCV / Oil Separator 06E103547AC
    PCV-to-charger breather tube o-ring WHT004793A x2
    Coolant Connector Pipe 06E121065N (these tend to break while taking apart)
    Coolant Connector Pipe Oring N90316801 (I think 06E121065N comes with a new o-ring already)
    Head cover gaskets 079129717B x3
    Supercharger gaskets 079129717D x6
    Band clamp 9mm (got generic one from ebay)
    Injector O-Rings MAHLE GS33503 (possibly not exact fit, see note below).
    Possibly engine oil for an oil change
    Optionally - gas line adapter fittings x2 07L127065A/06E127065B/06E127065D, see comments from theweebabyseamus
    Picture 1. Here what we deal with after removing the supercharger.
    Picture 2. Major components that need to be removed. Yellow – fuel line. Red – cylinder head/crankcase breather hose. Purple – coolant pipe. Green – breather hose. Blue - intake manifold bottom section.
    Picture 3. Step 1 – drain as much coolant as you can. There are 4 fittings on the bottom that can be used to drain coolant – radiator drain plug, oil cooler, and two connections on X-pipe. The picture above is the drain valve on the radiator – it needs to be turned 45 degrees, then pulled out. PCV unit has 3 coolant passages and holds some coolant. If not drained, this coolant gets dumped into the crankcase and you are up for an oil change. That said, I’m not sure if it is actually possible to drain the PCV completely. Maybe drill a hole on top and suck it out? I did not drain any of the bottom fittings and ended up changing the oil before starting the engine.
    Picture 4. Undo the band clip. Squeeze the connector and detach the breather hose. Remove the band clip.
    Picture 5. Let’s remove the fuel line. Start by removing the fuel line guard plate.
    Picture 6. MAKE SURE YOU PULLED FUEL PUMP FUSE!!! The fuel system is primed every time you open driver’s door. You really do not want to re-pressurize the system while the line is out! Since there might still be a pressure in the system, wear some gloves, then wrap a rug around the fuel line nut and unscrew the nut very slowly. A little bit of fuel will come out.
    Picture 7. Put a rug under the line, hold the union nut with 19mm wrench and undo the 17mm nut. Just squeeze the two wrenches together. Do this on both sides. After that, undo the bolts holding the fuel line to the PCV and the valve cover. Carefully wiggle the fuel line out, making sure to not scratch the fittings. Do not bend the line!
    Picture 8. Loosen up the crankcase breather pipe. First, undo the zip tie.
    Picture 9. There is another zip tie and a band clamp behind the oil filter. I left the zip tie in place.
    Picture 10. Pull the pipe out. I could not figure out how to release the connector, so I just stuffed pieces of a gift card between the valve cover and the connector. Be careful, the pipe is expensive and is easy to break.
    Picture 11. Undo the torx screw holding the breather pipe to PCV and pry the pipe out a little. No need to remove it completely just yet (an likely not possible).
    Picture 12. At this point, we are ready to remove the coolant hard line. Start by undoing the torx bolt near the firewall.
    Picture 13. There are a few options. You can either use a long torx bit at an angle, or, as shown above, a screwdriver bit with a ¼” ratcheting wrench. I have fixed the bit in the wrench by using a heavy-duty mounting tape on the back side of the bit and a zip-tie on the front. In this way, the bit could move back and forth in the wrench, but stayed attached. You can put some pressure on the bit with your finger on the other side of the bracket. Once loosened, the bolt can be unscrewed by hand.
    Picture 14. Detach the hard line from the rubber heater pipe by the firewall. The hard line is attached to the rubber pipe using a 3” intermediate plastic union pipe. You can either undo the band clamp on the heater side or the metal C-clip on the hard line side. Both the band and the clip face down. You can see the band, but not the clip. I went with band clamp and then pried the rubber pipe with a long screwdriver. Looking back, this was probably a good choice since the hard line sits in the union pretty tight.
    Picture 15. The side of the hard line that goes into the plastic union.
    Once the heater pipe has been disconnected – wiggle the hard line’s bracket out of the metal bracket (the one where we just removed the bolt). After that, good luck pulling the pipe out of the engine block. I tried to rotate mine and the pipe did come out, but its flange remained in the block. When re-assembling, pushing the pipe back into the block was just as hard, so I’m not sure if it’s even possible to remove the line without any kind of damage. I would recommend buying a spare pipe, just in case. The new pipe comes with a new o-ring for the engine block side.
    Picture 16. If you are also doing the thermostat – you can try pushing the hard line from inside the thermostat housing (circled in blue). Credit – the picture is not mine, found on the web - @decksurgen from audiclubsg.
    Picture 17. Now on to removing the bottom section of intake manifold. You can remove either left or right side. The repair manual recommends the left, so that’s what I’ve done. You need to undo 8 nuts and bolts at the top (blue, in diagonal sequence) and unplug the fuel line control connector (orange). There is also a valve flaps vacuum line and connector (blue at the bottom of the picture). They are tough to get to and can remain in place – you can undo them once the section has been removed, but make sure not to break them.
    Picture 18. A closer view of the flap vacuum control unit thingy.
    Picture 19. Remove the cover by carefully (but forcefully) pulling up. It sits there pretty tight and might feel like it’s been held in place by another fastener. It is not. What’s holding it is the injector o-rings. Once removed, make sure all of the o-rings are still on injectors (in the picture above, the middle one is missing and was still in the cover). If an injector pulled up – you need to replace all o-rings and seals. Otherwise, replacing the top o-rings is fine (mine looked fine and probably could have been reused).
    Picture 20. Plug all of the openings. You really do not want to drop a tool into the block. Unplug injector connectors. Undo the knock sensor (note – the 10mm triple square socket in the picture does not work, you would need a longer bit).
    Picture 21. At this point, you should have enough space to wiggle out the pcv. Clean around, undo all of the bolts on the PCV, and take it out while unplugging the breather hose at the back. There is not much to hold on, so I bolted a large washer and used that as a handle.
    Picture 22. This is what you deal with at the bottom.
    Picture 23. Once out, you may or may not have the coolant in the chamber under the PCV due to coolant passages (circled purple). The oil passages (circled yellow) drain into the crankcase. Make sure to clean up the mess and remove any of the remaining gaskets. Credit: paul@audizine.
    Install:
    Install is the reverse of the removal. Couple things to pay attention to:
    1.Note the layering of stuff over / under the fuel line. Electrical goes on the bottom, then the fuel line, then vacuum lines.
    2. Make sure to not scratch the fuel line fittings when removing and installing back. It's a pressure fit, so it needs to be free of scratches. May want to wrap in shrink wrap or something. When installing back, you may want to push the line gently with a lever where it makes a 90-dgree turn to align the fittings with the ports in the heads. Make sure to not bend the line though.
    3.Before reinstalling the intake manifold, attach the vacuum line and the connector to the flap valve control unit. There is no space to do it once installed.
    4.When re-installing intake manifold, you need to make sure the flaps point vertically rather than horizontally. Our goal is to avoid them being stuck on the vertical metal divider that sits under the valves. It’s a good idea to keep checking/pushing on the flaps while tightening the bolts.
    5.There is no Audi part number for injector o-rings alone, just for a ‘rebuild kit’ that consists of an o-ring and a spacer. The kit is for a single injector and costs around $30. I went with MAHLE GS33503 kit which is like $9 for a set of o-rings for all 6 injectors. I measure the black rings in the kit with a caliper and they have the exact dimensions of the original o-rigs, although feel a little bit less soft.
    6.Injector orings should be lightly oiled with engine oil. The cover goes on pretty tight. I could not push it past the orings and instead forced on by gradually tightening the bolts on top.
    7.Once the cover and the fuel line has been installed, plug back the fuel pump fuse and prime the system by opening the driver’s door, and check for the smell of gas in engine bay. Also, once everything is back together, run the car and check for the smell of the gasoline. If your fittings are leaking - you might need the new adapter fittings.
    8. You will need to remove the PCV line from the old PCV unit and move it to the new one. The line is held in place with a non-reusable band clamp and the new unit does not come with a new clamp. I got a variety pack of clamps from fleabay, 9mm seemed to work fine.
    9. Repair manual calls for renewing breather hose o-rings. I could not find a part number for one. The old ones looked fine though.
    Picture 24. Closed flaps. You can play with opening the flaps by attaching a tube to the flap and sucking with your mouth or a syringe on the other end. That said, they can be pushed by hand just fine.
    Picture 25. Opened flaps.
    Picture 26. The vertical divider that can catch on the flaps.
    Torque specs:
    Fuel line: 27Nm at all 3 connections (using crowfoot wrench on a torque wrench). Re-tighten the union nut to 40Nm as well before reconnecting the pipes.
    Knock sensor bolt: 20Nm (torque has an impact on the function of the sensor)
    Oil separator / PCV bolts: 9Nm
    Coolant pipe bracket bolt: 9Nm
    Fuel line bracket bolts: 9Nm
    Fule line guard: 9Nm
    2 small torx bolts that go into plastic on PCV (one holding the fuel line bracket and the other holding the breather tube in the back) – 2.5Nm, basically hand-tight.
    Intake manifold bolts: 10Nm (tighten in diagonal sequence and in stages)
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    Good man!
    Veteran Member Four Rings Jroyalty7's Avatar
    Jan 10 2016
    Porsche Macan Turbo
    FL
    Nice write up!! Thank you!!
    Sent from my SM-G975U using Tapatalk
    Current: ‘21 RS5 Sportback B9.5 Nardo Grey
    Retired: ‘13 S4 B8.5 Phantom Black Pearl
    EPL Stage II DP Tune | EPL 57.60mm SC Pulley | 183mm Fluidampr Crank Pulley | S4Matty Ported SC and TB| Aquamist WMI 375cc Jet @ TB| AMS Alpha Heat Exchanger | Milltek Sport Non-Resonated CBE | ECS Kohlefaser Luft-Teknik Intake | Alu Kreuz | CR-15 | 034 Drive Train & Trans Inserts | Bilstein PSS10 | SPC Upper Control Arms | TSW Bathurst 20x10 | Pulley Ratio=3.177
    May 12 2008
    Interesting though, I have 40nm for the fuel line connections, and the two intake manifold checks are one-time use. A lot of people can reuse but I have in fact gotten leaks from it.
    Apr 16 2019
    Quote Originally Posted by theweebabyseamus View Post
    Do you mean you got the 'PCV line with non-return valve' leaking (06E103207P)? How does it manifest and how did you find out? Also, you have 40mm nuts on the fuel line? Mine are definitely way smaller.
    May 12 2008
    No, the union nuts on the fuel line connections show 40nm in AllData.
    Apr 16 2019
    Ah, shoot, you are right. 40 Nm it is, looked in a wrong place. Will edit the write-up. Oh well, pretty sure I have not disturbed mine. What about 'two intake manifold checks ' that you mentioned?
    Veteran Member Four Rings maty360414's Avatar
    Oct 13 2015
    SoFlo
    great write up.
    '13 S4 | EPL DP E40 | EPL TCU | AEM W/M | Tampa Ported S/C | 75mm TB | JHM 187 | MercRacing HX/Divorced | Becker TestPipes | AutoTech HPFP | Roc Euro Intake | BFI Engine Mounts | ECS Trans Mount | ECS F/R Diff Mount | H&R Super Sport Springs | 034 Rear Sway Bar | CR-15 | Drilled & Slotted Rotors | StopTech SS | Vertini RF 1.3 | Indy 500 | Sport Diff | BFI Shift Knob | Quattro Grill | ECS Spoiler/Diffuser | RS4 Bumper | J-Code | CWA100 |
    May 12 2008
    Oops, I meant connections. The piece that screws into the intake manifold, the brass one.
    Apr 16 2019
    Ah, I see. I had zero problems with mine, but might indeed be a good idea to get new ones just in case. I tried to not disturb the original adaptors by squeezing the counterhold wrenches together with one hand. This ensures the adaptor does not unscrew from the fuel rail.
    May 12 2008
    Quote Originally Posted by maksym View Post
    The issue is with the fuel line side as opposed to the intake manifold side. The cone the line meets can get scored and the deformation the fuel line male end makes into the brass can also have issues with repeated tightening.
    That being said, I don't think it's common to replace it, but having experienced putting everything back together and having the supercharger area smell like gas immediately, I replace it every time.
    Apr 16 2019
    Got you, thanks for the feedback! Added to the list of parts and tips.
    Oct 22 2018
    UK
    Wow, great work. Didn't realise it was so involved! Not sure I'd be able to tackle that...
    B8.5 Glacier White S4
    IG: @theworkerbee_uk
    Apr 16 2019
    Quote Originally Posted by theworkerb View Post
    It's really not as bad is it looks. Most of the time is spent cleaning and scraping old gaskets, with disconnecting the water pipe in the back the close second. Goes together much faster though.
    Oct 13 2015
    SoFlo
    how common is the oil separator damaged on a 2013 S4, i lost the coolant from the engine coolant tank all of sudden and i refilled it and never happened again. I floor the car and sometimes i feel like i have 200hp less.
    Apr 16 2019
    Quote Originally Posted by maty360414 View Post
    It is somewhat common if you read through the threads, but you should also consider that people posting to the site are the ones having the problem, not the ones with trouble-free cars, so the real scope would be hard to tell . That said, my car made it 10 years before developing a problem. Luckily, mine leaked from the top (as opposed from the bottom as reported by the OP), so no symptoms besides a lake of coolant in the engine bay. It does seem strange that you a loosing power intermittently though - are sure this is not something else, like worn out spark plugs, fuel pump, compression, etc? Do you see any trouble codes on the dash? Signs of coolant in the oil?
    EDIT: mine was loosing coolant at a much high rate when floored, and barely loosing any when driving slowly, which makes sense. More RPM = more pressure in the system.
    Oct 09 2013
    NC
    i just finished changing out the oil separator. This DIY is very very helpful.
    I just want to add some tips for getting the bolt that secure the hard upper coolant pipe and getting that pipe out. Just remove the wiring grommet at the end of the bracket and you can slide the connectors on the bracket toward the firewall.
    Once the bolt is off, you can pull up on the hard coolant pipe enough so the tab clears the bracket. With one hand pulling up on the pipe to clear the bracket, use a mallet to gently tap the hard coolant pipe back. I tap on the bend on the coolant pipe near thermostat. Tapping direction is toward the firewall. The coolant pipe will come out very easily. Remember to replace the pipe o-ring.
    Apr 16 2019
    Quote Originally Posted by Culi View Post
    I tap on the bend on the coolant near thermostat. Tapping direction is toward the firewall. The coolant pipe will come out very easily. Remember to replace the pipe o-ring.
    Ha! I guess you've got lucky. I did tap, hit, and rocked on the bend. Eventually, the flange just broke off in the block.
    Established Member Two Rings Tidi0x's Avatar
    Nov 21 2017
    Ashburn, Va
    Anyone got the images unbasterdized by photobucket? They were good a few days ago...
    13' B8.5 | APR DP | Bilstein PSS10 | 034 Engine Mounts | ECS Exhaust | ECS Carbon kit | MercRacing cooler | BBS CI-R | Avanti Hybris
    Apr 16 2019
    Quote Originally Posted by Tidi0x View Post
    Exceeded photobucket download limit. Here they are in a zip file, should be numbered the same way they appear in the writeup.
    Feb 18 2017
    Honda RC51
    Columbia, Maryland
    Props for doing this OP! I used Vaseline on the FI orings when putting back on, and the pipe going into the Tstat housing was a pia. I was able to take just the upper screw front that bracket and bend it back towards firewall for the tube flange to clear enough to pull out of the housing. Take your time with the coolant line out of housing. It was tight in there. Used a pry bar at the flange, and other hand on solid hose to wiggle as I pryed carefully. Finally popped out. Didn't have a new o ring and all is well, but mines a 15. DM if you have questions.... I've been drinking
    Sent from my SM-G950U using Audizine mobile app
    2015 S4, IE DP tune, 3.28 SC ratio, Merc HX
    Apr 16 2017
    Illinois
    Thanks for the nice guide OP.
    Anybody have an invoice from the dealer for this?
    Or a parts list that they can provide to supplement what the OP has provided?
    2012 S4 | DSG | Prestige | Stage 2 | 187mm Fluidampr | AWE Touring | Eurocode Sways | 034 Insert | CR-15 | Forge Charge Cooler | ECS Carbon Intake
    Feb 18 2017
    Honda RC51
    Columbia, Maryland
    Here's the invoice for my order of orings, pcv, Tstat, wpump (15 s4) 20191005_125246.jpeg
    Apr 16 2019
    Quote Originally Posted by hd1 View Post
    Yup. Mine is about the same, with a little bit more stuff.
    Thermostat Hose O-ring 06E121119C 2.5
    Expansion Tank Cap Seal 1H0121687A 3.86
    Expansion Tank Cap 3B0121321 aftermarket URO 3.23
    Coolant Temperature Sensor - 2 Pin 06A919501A 131.96 (kit from ECS)
    Sealing O-Ring N90316802 incl.
    Sensor Retaining Clip 032121142 incl.
    Torx Bolt N91068001 thermostat x7 incl.
    Genuine Volkswagen Audi G13 Coolant / Antifreeze - 1 Gallon (3.78 Liters) G013A8J1G incl.
    Thermostat 06E121111AL incl.
    Multipoint Bolt N91052201 for waterpump pulley x3 4.8
    Hex Bolt - N91071701 for water pump x7 7.56
    Supercharger Intake Manifold Gasket For VW Audi 079129717D 25
    Water Pump 06E121018D 122.5
    Cooling-Connector Pipe 06E121065N 28.25
    Engine Crankcase Vent Valve PCV oil separator 06E103547AC 132.5
    OIL DRAIN PLUG SEAL CRUSH WASHER X10 MADE IN GERMANY N0138492 7
    Fuel Injector O-Ring set MAHLE GS33503 8.21
    "Oil Filter WIX 57204 x2" 16
    O - RING. SEAL RING WHT004793A x2 7.38
    Cooler ASSEMBLY plug. Cooler plug. Intercooler Drain Plug 06E127535B x2 7.34
    Bolt x3 N10405604 thermostat 2.91
    Gaskets for the head 079129717B x3 7.23
    Castrol EDGE 5W-40 Advanced Full Synthetic Motor Oil, 5 QT x2 47.66
    Main coolant pipe washer x2 06E121119E 12.3
    Apr 16 2017
    Illinois
    Awesome, thank you both!
    Jun 21 2013
    DC
    How does the oil drain back into the block? I see the metal side on the oil separator, but I don't see any spot on the block in the pictures, despite OP circling exactly where to look. lol
    Feb 18 2017
    Honda RC51
    Columbia, Maryland
    Uhhhhh what?
    Senior Member Two Rings A.Bruno6's Avatar
    Jun 02 2015
    Ontario Canada
    Nevermind, I found it. Had to look at it in person as opposed to the pictures on my phone. I didn't touch this sensor/bolt during the PCV valve removal process.
    EPL Dual Pulley & TCU |3.19 PR| -- MercRacing Charge Air Cooler
    Senior Member Three Rings zatta's Avatar
    Sep 02 2018
    Ohio
    anybody got tips for getting the hrd coolant line out i got the devil bolt but i have no clue how to get it out now, i cant even find the clamps on the bottom.
    Apr 16 2019
    Quote Originally Posted by JS81 View Post
    Sorry for a late rely, Audizine sends notifications whenever it feels like it. The square chamber in the block under the PCV valve has two holes, one towards the front of the car and one towards the firewall. The holes are on the vertical walls of the chamber rather than the bottom, so you can't easily see them in the picture. Also, see page 15
    http://www.vaglinks.com/vaglinks_com...FSI_Engine.pdf
    Apr 16 2019
    Quote Originally Posted by zatta View Post
    On the firewall side, hard line connects to a plastic union with a push clip, and then the union connects to a rubber hose with a band clamp. Band clamp is easily visible. The c-clip is on the bottom of the hard line, you are not going to see it without a mirror. You can disconnect either side of the union, whatever works the best.
    If you are replacing thermostat as well - try pushing the flange of the hard line from inside the thermostat chamber. You can also rest a piece of wood against one of the brackets on the hard line and tap with a dead blow hammer. You can also put adjustable pliers around and try to rotate the pipe back and forth to loosen it up. Or just cut it in half and install a new one. It's about $40-$60.
    Sep 02 2018
    Ohio
    I cannot see the band clamp, I also have Q5 so it might be somewhat different that is why I’m confused.
    Apr 16 2019
    That's a bummer. Do you at least see where the plastic line changes into a rubber pipe?
    The band clamp might be oriented towards bottom as well. May be try to follow the end of the hard line with your hand towards the firewall and feel for any metal? Or follow with a strong magnet. Or sneak a cellphone under the pipe and take a picture (that's how I've done mine).
    Sep 02 2018
    Ohio
    Literally wasn’t feeling anything. Might just snap the line and get another one from ECS
    Feb 18 2017
    Honda RC51
    Columbia, Maryland
    This is the only pic that I have that may help you. Wish I had one of the union between hard pipe and soft hose..... Basically exactly what the last guy said, but I didjt have that hard of a time seeing the mesh wire c-clip and using a bright light/pic tool to pull it upScreenshot_20191023-220038_Gallery.jpeg
    Feb 18 2017
    Honda RC51
    Columbia, Maryland
    Does it need to be replaced? I just pulled mine back and pushed back in (hard pipe) after replacing pcv. Disengaged clip first bc I thought I needed to pull it out but then clipped back when I realized I didn't.
    Apr 16 2019
    It's probably fine. I've seen a few mentions that it 'might crack' here on Audizine, but no specifics. If it does crack, it is not leaking into the block, so no biggie. I think manual says the O-ring on the thermostat side needs to be replaced though. YMMV.
    Feb 18 2017
    Honda RC51
    Columbia, Maryland
    Yea I'd for sure replace the oring if you have advance time to order.... I didn't, and all is fine, but didn't have time to wait for it to come in, in middle of job.. 2015 with 85k.
    Sep 02 2018
    Ohio
    Actually managed to figure it out. It was just farther back than I originally assumed. And also, after I get that hard coolant line would i be able to wiggle the thermostat without taking the other hard line off?
    Feb 18 2017
    Honda RC51
    Columbia, Maryland
    From what I remember you had to take it off. Those plastic lines are delicate and thin out over time, so don't torque it too much... Also that front one is $$$
