Page 1 of 3 123 LastLast
Results 1 to 40 of 93
    Junior Member Two Rings seaniscoolikeA4's Avatar
    Feb 26 2018
    Endicott, NY
    2.0 Stock Exhaust: Muffler Delete vs. Resonator Delete
    I'd like to keep the stock exhaust but I'm looking for a little more sounds without the rice. I've read different discussion regarding front resonator vs. central resonator delete. A few blips about muffler delete only. Anyone have any experience with any of these configurations? I feel like based on what I've read I'm leaning towards muffler delete only but I'd love to hear an example of each (front res only, central res only, and muffler delete) if they're out there.
    Stock exhaust diagram for reference: https://imgur.com/YlJhBBy
    2014 Ibis White A4 S Line 6MT Quattro
    APR Stage 1 | CR-15 Front Strut Brace | ECS Luft-Technik FMIC | Hard Charge Pipe | ECS Turbo Muffler Delete | AEM Cold Air Intake | 034 Motorsport Trans Mount Insert | NGK Iridium Spark Plugs | Red Coil Packs
    South Bend Stage 2 Daily Clutch | South Bend Single Mass Lightweight Flywheel | ECS Stainless Steel Clutch Line | RS4 Honeycomb Grille | BFG DV+ | ECS Weighted Knob
    Established Member Two Rings colorado.a4's Avatar
    Dec 04 2018
    I went with center res delete first, liked it for a while then decided I wanted it louder... it still was decently aggressive with out any drone. now I have nothing but stock cat, and I personally like it that way, it’s all about what you like.
    IG @Colorado.a4
    Veteran Member Three Rings weagle1856's Avatar
    Dec 15 2015
    Audi TT 225, Audi A4 Avant, VW CC, BMW X5
    Denver
    Quote Originally Posted by colorado.a4 View Post
    For center res delete, did you have to cut and replace, or is it possible to swap it with a pipe that connects from the downpipe to the back of the exhaust?
    Sent from my Nokia 9 using Audizine mobile app
    Veteran Member Three Rings NathanGreatScott's Avatar
    Apr 05 2017
    '16 Ford Flex Limited
    Western PA
    Quote Originally Posted by weagle1856 View Post
    You can definitely just delete it with a straight pipe, but the center resonator is large and eliminates a lot of drone. I think if you deleted that all together you'd have some of those issues.
    If I were to do my exhaust again, I'd probably swap both resonators out for smaller bottle style ones (or delete the first one all together and swap the center only) and then put a magnaflow muffler on the rear. My current set up is OE Cat> bottle res in downpipe (replacing small OE res)> Magnaflow muffler (replacing large OE res)> straight pipe to tips (deleting rear muffler). I think keeping two resonators would help eliminate the drone I experience at times and also cut down on the raspy tones at high rpms. I'm installing an HFC soon so that should add the volume I want and a little more throaty goodness
    Established Member Two Rings the-quattro-man's Avatar
    May 16 2018
    Sunshine State
    I did the resonator delete first and kept everything else stock. I liked it first then it got really boring (lol).
    This is my setup now - Eurocode test pipe > OE downpipe with magnaflow resonator > straight pipe (using my resonator delete pipe) > small vibrant bottle resonator (acting as muffler) > connect to dual tips. It sounds great not too loud at cruising speed. But when you get on it, it wakes up and has a very deep and throaty sound.
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    I'm curious if there would be any sound difference with swapping the two stock rear/back mufflers on my avant with magnaflow mufflers. Leaving everything else stock.
    I'm as cool as a cucumber in a bowl of hot sauce.
    Senior Member Three Rings Quattro420's Avatar
    Apr 08 2015
    2003 Jetta tdi 5peed 2000 b5 a4 1.8t 5aq, 2005 Passat tdi wagon2.0l, 2000 sierra 5.3l
    Ontario Canada
    I agree with everyone on here so far about the center res, I have stock exhaust with center res cut out and it has a nice sound but I want more it’s become boring. I get complements on how my car sounds but I want more, thinking about adding a down pipe
    Veteran Member Three Rings IHave2Turbos's Avatar
    Aug 17 2015
    i have a thread somewhere but i did hfc -> cts downpipe (front res delete) -> stock center res -> rear muffler delete and it wasn’t loud at all. slight low rpm drone but i have a manual so no issue . posted sound clips as well but the wind noise was basically louder than the exhaust.
    C7.5 S6
    Mods : OEM+ Stage3 / DS1 ECU / SRM TCU / CTS HX
    B8 A4
    Mods : HPA\\\ K04 / Manifold / HFC / Tune | CTS FMIC / DP | CR-15 | ECS Inserts
    Retrofits: MMI3G+ / RVC / AHH / Color DIS / Cruise Stalks
    Aug 17 2015
    C7.5 S6
    B8 A4
    Mar 27 2019
    Straight pipe it all the way
    Aug 17 2015
    you definitely need one resonator in the system or you will hate life cruising around town
    C7.5 S6
    B8 A4
    Mar 27 2019
    Depends on who you are...
    Aug 17 2015
    California
    Quote Originally Posted by BeerBrent View Post
    Yes, the stock mufflers at the back do a lot to cancel low RPM drone. They have a J pipe inside the muffler (I have a cutaway picture from the S4 guys, mufflers are nearly the same). A magnaflow in it's place will sound deeper and get you a little drone (which might sound good/deep).
    Quote Originally Posted by Shuga View Post
    This is really true. I can't believe some of the comments in here saying their car sounds great with just a cat, or with just a magnaflow muffler. This would drone like crazy and be super loud and obnoxious
    To the OP: this question is very difficult to answer and is highly subjective depending on if you are 17 and this is your first car or if you are 35 and sometime driving professionals around. All we can do is post our experiences but even then, some people think straight piped sounds good, which I think sounds terrible.
    Here's my experience:
    Went from stock exhaust to HFC + downpipe (first) resonator deleted. I loved it. It sounded way more aggressive than stock, but was not too loud or annoying and had very little drone. After 2.5 years, a stage 2 tune (tune will make your car sound great as more air flows through the engine), and K04, I finally wanted more sound.
    I cut off the stock muffler at the rear and welded on a Magnaflow. WOW, holy drone city. It was loud, lots of drone. It sounded great when I really got on it, but after 5 months I couldn't handle the drone anymore. I wanted to keep the tips that were welded onto the Magnaflow and didn't fit the OEM muffler, so I kept the MF back there. I put the stock downpipe back on including the first resonator. WOW this eliminated a ton of drone and really quieted things down. I still get a semi-deep tone from the MF at the back but a lot of the annoying drone was killed by the first downpipe resonator.
    I would never delete the center large resonator. ECS has a delete pipe they sell and they have videos. IMO they sound raspy and terrible. This resonator does a lot to kill drone and shape the sound. I would keep it.
    In hindsight, my exhaust was perfect with the addition of an HFC and downpipe resonator deleted. I should have stopped here. I would describe this as a little raw, a little drone, but overall it sounded pretty good and aggressive and is not annoying in anyway while cruising.
    I am satisfied with HFC, stock downpipe, stock large center res, and MF muffler. It sounds a little tamer and quieter than above, but still a deep sound from the MF.
    The HFC, downpipe res delete, center res, and MF muffler was too extreme and too much drone.
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    ^ Thanks ^
    Mar 27 2019
    As someone stated above it is personal preference. But imo loud pipes save lives
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Mar 27 2019
    Quote Originally Posted by JeriQo View Post
    Smart man
    Jun 04 2016
    A
    I have; 200cel HFC Downpipe, First res delete, stock centre res and stock rear muffler.
    Just like most here, it’s nice but getting boring and want a bit more. Without having to replace the whole system (imo it’s such a waste as 4cyl just can’t beat the sounds of 5cyl, 6cyl, V8, V10 & V12.)
    So I am about to replace the large rear/centre resonator with a Hotdog (bottle) type resonator. as I don’t want the Honda Fart canon Tinny sounding drone that appears midrange. Hopefully the hotdog style res will do something about it.
    I’ll keep you all posted as I don’t think anyone here has done that before?
    Nov 26 2018
    Quote Originally Posted by Quattro420 View Post
    When I did a center res delete (the big one underneath the rear seats) due to a leak in the stock one, it sounded like utter ass and droned like crazy. On a cold start the car sounded like a tractor. Had a magnaflow muffler welded in place there and it sounds much better.
    Edit: Currently have 034 HFC, stock downpipe and front res, center res replaced by magnaflow 11226, stock rear muffler.
    2013 B8.5 A4 Quattro 6MT | 034Motorsports HFC | IE Stage 2 Tune
    Feb 26 2018
    Endicott, NY
    Quote Originally Posted by A4x View Post
    Thanks for the info. This is an my daily driver. I'm 33. Trying to keep it professional but would like a little more sound than stock. I'm also looking into having the rear converter to duel exhaust. I think that's where I'll end up starting. Stock cat ---> stock DP ---> Cent. Res ---> Straight pipe to duel rears. It sounds like you had this setup less the front res and it was too much drone? You think it would be too much with both resonators? If I want more from there I'll likely delete the front res.
    I'd love to get into HFC territory (currently APR stage 1) but I'm in NY. I've read many a horror story about people having to do all sorts of shit to get their emission codes straight to pass inspection. I want more power but not at that cost. If anyone has any suggestions on how to make it work in a state like NY I'm all ears.
    Mar 27 2019
    Yawn if you’re in NY you’re not going to pass inspection with out jumping through hoops. Just the way it is and the cost of the game.
    May 16 2018
    Sunshine State
    Quote Originally Posted by seaniscoolikeA4 View Post
    That's why I moved from NY to FL many years ago. I hate emission inspection. Here in FL no inspection, plenty of E85 juice, lots of tuning shops and you can pretty much mod your car to death and not worry about it.
    Cheers
    DAILY DRIVER - 2014 B8.5 A4 Quattro S-Line | IE Stage 2 Tune | Eurocode Test pipe | ECS Valved Cat-back Exhaust | TR8 Intercooler | Solo-Werks S1 Coilovers | RS4 Grille | ECS Trans Mount | Silicone Charge Pipes | Macan calipers
    WEEKEND WARRIOR - 1990 MK3 Supra 1JZ | PTE 6266 CEA Turbo | Custom everything else | 526 WHP @ 22psi
    Mar 27 2019
    Quote Originally Posted by the-quattro-man View Post
    Cheers
    All you have to worry about is that hot FL sun that’ll burn your clear coat haha
    Aug 17 2015
    California
    For any of you engineers out there who might know a thing or two about sound pressure waves, the geometry and internals of mufflers can give you an indication of what it does to the sound of your exhaust.
    Here is a stock S4 muffler cut open. I assume the A4 mufflers are similar based on the shape and hey, it's Audi. They design things the same way, just scale it up or down. You can see there is a J-pipe circled, which will reflect a certain wavelength back into the exhaust to cancel frequencies out (low frequency drone).
    Here is the stock downpipe/front resonator cut open. It is a simple straight through design that will absorb a lot of low frequency sound. The size of it also tunes out one frequency and it's harmonics as they come in the inlet and reflect off the wall back onto itself.
    Here is an overall view of the stock A4 exhaust. You can compare the size of the resonators and the muffler. As you can see, the center resonator is the largest. I tend to think that large resonators give the exhaust a deeper sound, but I've never seen a cutaway of this to really know how the exhaust is routed. If anyone can help cut one open, that would be great!
    Senior Member Three Rings Seal1968's Avatar
    Apr 04 2015
    Ontario
    Mine came with centre resonator deleted with a straight pipe back and a muffler with split to dual exhaust. Drones at lower rpms. I will likely add a small resonator to get rid of that. To me its annoying, and can drown out the tunes. (very bad! lol)
    To each his own.
    Mar 27 2019
    Quote Originally Posted by Seal1968 View Post
    To each his own.
    Turn the radio up
    Jun 04 2016
    A
    Quote Originally Posted by snaky69 View Post
    I wonder if the Aftermarket Magnaflow (not straight through type oval resonator) is any louder than the OEM large rear resonator?
    Larger mufflers and resonators are said to be quieter but offer more deeper tone. But less Bark on WOT aswell.
    If you said it sounded like 'Ass' then I wonder if my proposed HotDog Style resonator (pictured) will be suffice?
    Because the next one up from that is a cylindrical barrel type, which is straight through but fatter than the hotdog. Said to be quieter than a hotdog but louder than the oval ones such as your Magnaflow
    To each his own.
    Did it have the front resonator delete?
    as mentioned above, I will be replacing the 2nd larger resonator with the hotdog (smallest) type resonator. Ill give you feedback.
    (im just hoping I dont regret it or regret going one step quieter with the Barrel/cylindrical ones:
    Mar 27 2019
    It’s not going to be loud at all
    Jun 04 2016
    A
    Sorry, what is?
    or were you referring to me?
    it does appear that the CDNC Ea888 GEN II 2.0T TFSI are not loud engines.
    also, can anyone confirm what material the OEM pipework is for the exhaust?
    The hotdog resonators in either Stainless Steel or Mild Steel are not much difference in price.
    Ive heard that Stainless steel + mildsteel joints are not reliable... and better off to flange both dissimilar metals. (or use couplings/bands)
    if the OEM pipe is mildsteel, it be easier to just buy a mildsteel one
    Nov 26 2018
    Quote Originally Posted by doublespeeded View Post
    Any resonator will be better than none. Usually the bigger they are the deeper the tone. It wasn’t so much the tone as the drone that bothered. It was drone city in the cabin.
    Nov 26 2018
    Sorry, what is?
    OEM is stainless. Likely 409 grade.
    Jun 04 2016
    A
    its funny that a Golf R and S3 (both 2.0T) can delete all resonators (I believe they only come with one) can sound decent. (I assume its due to the single large resonator at the rear with dual outlets that compensate).
    I can see most people here don't mind productive noise :), just the tinny Honda/ distorted/ tinny drone... But as you said, any resonator is better than none. But whether a small one will cut out the drone, is my concern. in saying that, majority of the aftermarket exhausts (predominantly JDM vehicles with Canon exhausts) have the hotdog/small type resonators. I previously had a 4 Cyl EVO IX with a Titanium canon rear muffler and stainless pipework and a hot dog resonator... there was no drone.
    Thanks for verifying.
    The resonator that I will be using, it states that its a '304 Grade Stainless Steel'. will that easily weld together or be compatible? (I assume that would be more compatible than Mild steel?)
    My intention honestly, is so that the engine can offer a bit more noise, and to hear the DSG gear changes more (I noticed the gear change sound is more noticeable after the front resonator delete)
    Nov 26 2018
    409 is readily welded to 304 with no problem, filler material should be 309 ideally but any stainless would work.
    Apr 04 2015
    Ontario
    Turn the radio up
    I like where you are going with this sir!
    Feb 26 2018
    Endicott, NY
    Here's an idea... thoughts?
    Modify stock A4 exhaust with split after the central res. Passenger side is straight pipe only. Maintain stock drivers side w/ muffler.
    Example: https://imgur.com/hHRREjV
    Dec 15 2015
    Denver
    Best response in this thread.
    Active Member Two Rings cdmx's Avatar
    Apr 01 2009
    2004 Audi a4 3.0 Quattro, 2002 toyota 4runner sr5, 1994 bmw 325ic
    Charlotte, NC
    Ecs tuning resonator delete with aero resonator.
    Sounds WAY better then straight piping.
    I’m actually thinking about selling mods to put back to stock..
    2009 AUDI A4 2.0T QUATTRO IBIS WHITE
    Mar 27 2019
    Quote Originally Posted by cdmx View Post
    Some people aren’t about that life
    Jun 04 2016
    A
    Im interested in your set up.
    So that resonator pictured, replaced the 2nd larger OEM resonator.. how about the rear muffler, downpipe and the first resonator??
    Jun 04 2016
    A
    I cant seem to find the ECS tuning product or link to what you have there.
    But anyways, as mentioned, I'm interested in your set up, so can you let me know what your exhaust pictured consist of?
    Also, ive just ordered one of these.. a 2.5" inlet/outlet (to suit OEM pipework) and 3.5" dia body width Hot-Dog Style resonator in Stainless Steel 304...
    once I replace the 2nd rear resonator with this, ill be able to provide feedback with my experiences to anyone on this forum interested.
