Hi guys, I just landed a new job with a new commute and of-course now I'm having car trouble. I appreciate any help trying to narrow down the problem
2008 Audi B7 2.0T FSI Quattro
Throwing Engine Trouble codes
- P0087 Fuel Rail/System Pressure 002 - Too Low - Intermittent
- P0301 Cylinder 1 - 001 - Misfire Detected - MIL ON
- P0300 Random/Multiple Cylinder Misfire Detected
The car turns on fine but will begin to shake. Especially after a few minutes of warming up. If i put it in drive and accelerate its shakes at low revs but eventually I can feel the turbo kicking in. The car still picks up speed but runs poorly. There's definitely a loss of power. Kinda feels like its delayed. Im assuming it is running on 3 cylinders. I drove it to work the other day and the gas mileage is also really bad. The car feels like its stressing itself more than it has to, to pick up speed. The car does not turn off but ive since stopped driving it.
I ran the ross tech VCDS for codes. Ill post a copy paste of them down below.
I checked the fuel lines and none of them look pinched or loose.
I changed all the Coil packs and spark plugs as soon as the problem happened. Also did an oil change and oil filter.
Im planing on removing the HPFP and checking the cam follower and changing the fuel filter.
Any sensors I should be replacing while im in there getting greased up?
I can hear the LPFP working when I turn the key.
I should also note that the HPFP, LPFP, Cam chain tensioner, are all less than 2 years old. I did them sometime 2017+
The only loose hose I found was one that connects to the back-right of the engine and leads to the back of the engine department. To the round thing to the right of the battery. The bracket keeping it tight seems to have snapped. I have no idea what this hose is for but its holding on for now.
Im at a loss at what I should replace first. I only really have a week and then ill have to hand it over to the dealership and their price gauging.
VCDS
Monday,06,May,2019,09:01:33:35445
VCDS Version: Release 18.9.1 (x64) Running on Windows 10 x64
www.Ross-Tech.com
Address 01: Engine Labels: 06F-907-115-AXX.clb
Control Module Part Number: 8E1 910 115 G HW: 8E0 907 115 D
Component and/or Version: 2.0l R4/4V TFSI 0010
Software Coding: 0104010A190F0120
Work Shop Code: WSC 06325 000 00000
3 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 276152 km
Time Indication: 0
Freeze Frame:
RPM: 1174 /min
Load: 58.4 %
Speed: 0.0 km/h
Temperature: 17.0°C
Temperature: 17.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.970 V
000769 - Cylinder 1
P0301 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 276152 km
Time Indication: 0
Freeze Frame:
RPM: 1284 /min
Load: 51.4 %
Speed: 0.0 km/h
Temperature: 17.0°C
Temperature: 17.0°C
Voltage: 13.970 V
000135 - Fuel Rail/System Pressure
P0087 - 002 - Too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 276329 km
Time Indication: 0
Freeze Frame:
RPM: 2909 /min
Load: 71.3 %
Speed: 82.0 km/h
Temperature: 54.0°C
Temperature: 28.0°C
Voltage: 13.716 V
Readiness: 0000 0001
