https://www.goapr.com/products/tcu_u...dq250_mqb.html
APR is pleased to present the ultimate transmission control unit (TCU) upgrade for the DQ250 DSG and S Tronic transmission!
APR’s TCU Upgrades are the best modifications one can make to the DSG or S Tronic transmission. The upgrade allows the transmission to hold higher torque levels with faster acceleration and quicker shifts. Each driving mode is optimized for the higher power levels provided by APR’s engine upgrades. The upgrade allowing the end user to customize launch control and manual mode to their liking, and adds various features only found on higher end vehicles!
Feature List
Faster Acceleration
Increased clamping pressure, optimized shift points, and better launch control all result in faster acceleration.
Quicker Shifts
Increased clamping pressure and optimized shift times results in a faster shift under various scenarios.
Optimized Shift Points
Drive mode is optimized for fuel economy while sport mode is optimized for faster acceleration with APR’s various hardware and software upgrades.
Increased Clutch Clamping Pressure
Increased clutch clamping pressure beyond factory torque levels to support higher output.
Smoother Daily Driving
Optimized part throttle / daily driving shift maps to provide a smoother and more enjoyable driving experience.
User Definable 3-step Launch Control
Launch control is enabled on all models, with ESP on or ESP off. Three user defined launch control RPMs are set at the time of install. Launch control response is also optimized for faster engagement and stronger take-off.
User Definable Manual Mode
The automatic manual mode upshift and kick-down switch downshift can be enabled or disabled at the time of install.
Raised Torque Limiters
Non-physical transmission torque limits are raised to allow for higher output while retaining critical protection limits.
Downshift Lockout Optimized
Manual downshifts are permissible in all gears so long as the next gear is below redline.
Temperature Management Optimized
Allows for limited torque during over-temp conditions vs total immovability.
Gear Display Activated
Shows the current gear in the factory multi functional display in both drive and sport mode.
DirectPort Programming
The TCU Upgrade installs in minutes without opening the TCU and can be uninstalled at any time.
